2001 Caravan Power Window is Stuck - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 5 Old 06-15-2007, 07:19 PM Thread Starter
jackster20
Question 2001 Caravan Power Window is Stuck
Hi,
Has anybody heard of this problem before? The drivers side power window will roll down but then won't roll back up when the button is pushed again. In the past, I'd have to wait a little while for the button to push the window up little by little. This would be repeated until it was up all the way. Now it just plain-ole won't work.
Thanks.
jackster20 is offline
post #2 of 5 Old 06-15-2007, 08:15 PM
RickMN
RickMN's Avatar
These vans are known for having bad window regulators. You can buy one from the dealer or get an aftermarket one from www.rockauto.com. They're a little bit of a pain to put in, involves drilling out some rivets and disconnecting things, but you can probably do this one yourself. Put aside an afternoon. Take your time. Wear leather gloves when working inside the door. Buy some brewsky's for the after-party.
I'm a retired ASE Master/L-1 Technician. I still keep current with the latest automotive technology. My blog now has over 1000 in-depth repair articles, TSB's, and wiring diagrams:
RickMN is offline
post #3 of 5 Old 06-16-2007, 12:15 AM Thread Starter
jackster20
Hey, Thanks! That's a nice website. I haven't seen that one before. They even have tech articles for troubleshooting. I'm going to try some other stuff out tomorrow.
I hot wired the motor and while it will go down every time, it will only go up when it's in the mood...just like when using the switch. I hear a click from the motor and that's it. Trying repeatedly doesn't work. I have to wait an hour or so and then maybe it'll go up. When it does go up it moves up like normal for a few inches then just stops. I even tried pulling and pushing on the window and mechanisms while 12 V was applied but that doesn't help either.
post #4 of 5 Old 06-28-2007, 02:43 AM
login
Window regulator is the problem. Can get them new on ebay cheap. Auto zone if I remeber soemone proper has motor that is lifetime warranty. Do not quote me...
Just changed mine complete with cable assembly. See other post for tips...
No drilling rivets on that madel year. Very easy. Snap the window into the gold clips as very last step.
login is offline
post #5 of 5 Old 06-28-2007, 09:31 AM Thread Starter
jackster20
Thanks. I'll look into that if my motor fails again.
I tested the motor and it would only work intermittently in the up position. A new motor solved that problem. I'd have to say that removing the old motor was a B word. There's a "round" nut inside a rubber grommet that the motor bolts are attached to. When trying to remove the three bolts the nuts would spin with it and so would the grommet. I finally pried/forced the grommets through the holes and had to get some new hardware from the hardware store. Works great now.
Thanks again!
    1996 Dodge Grand Caravan LE AC/Heater Blower, Relay and Resistor Block Problems 101 HeadlessHorsemn Dodge Caravan General Talk 4 01-16-2006 06:55 AM
    2001 Durango power window MelissaK29 2G Dodge Durango General Talk 3 01-14-2006 11:57 AM
    Power Steering Fluid Almond Pale Ale 1G Dodge Durango General Talk 17 03-28-2005 09:01 PM
    Pricing for 2005 Chrysler and Dodge Minivans RAM MAN Rumor Mill & Gossip Talk 0 02-05-2004 07:06 AM
