smog pump??? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 10 Old 06-13-2007, 10:23 PM Thread Starter
overANDover1
overandover1
overANDover1's Avatar
smog pump???
my truck a 1990 dodge 150 excab...318 with a 518 trans. anybody have any thoughts on removing the smog pump? how to, and any pros or cons???
overANDover1 is offline
post #2 of 10 Old 06-14-2007, 07:09 AM
Dodgevanman
Do It In A Van
Dodgevanman's Avatar
Only remove it if you don't have emissions testing where you live.
Don't know of any "cons" of removing the smog pump.
Nate Breece
5.2L Magnum
2008 Grand Caravan SXT
3.8L
Member of:
Dodgevanman is offline
post #3 of 10 Old 06-14-2007, 12:39 PM
B-300
4 Wheel Power Disc Brakes
The "cons" that I know of are:
1) The catalytic convertor is more likely to become clogged due to overheating. This is because the air pump injects air into the exhaust upstream to help oxidize unburnt hydrocarbons (HC)before they get to the convertor.
2) It's illegal to do so. I experimented on my '78 van and found no loss of power or mileage with the air pump connected so it's still on.
Ram Van/Wagon Club Member #4
B-300
B-300 is offline
post #4 of 10 Old 06-15-2007, 09:15 PM Thread Starter
overANDover1
overandover1
smog gone...shhh!
thanx guys, we dont have any emissions testing in fl. it's getting custom duals so the cat is gone too.......thanx again.
post #5 of 10 Old 06-16-2007, 08:10 AM
threetwos
AirFuelEddie
Wanna sell the old pump. I would like to use it on my 360 Magnum.
threetwos is offline
post #6 of 10 Old 12-13-2007, 02:01 PM
DodgeThis_AZ
DodgeThis_AZ's Avatar
If you still want one, I'm about to take the smog pump off my brothers RAM with a 360.
2006 Dodge RAM 3500 Laramie SRW • Brilliant BLACK • SRT-10 RAM Air Hood • Red Painted Calipers
Banks Power BigHoss Kit • 4” Lift Kit • BFG A/T Tires • Custom Skid plates • Mopar iPod Adaptor
Upgraded 56g Fuel Tank • 115gal Aux. Fuel Tank • Custom Sliders • Slotted Brake Rotors
Warn 16.5ti Winch • Line-X Bed Liner • 18k Firth Wheel • Radar Detector
Buckstop Front & Rear metal Bumpers • Duel Antenna CB
I try to keep it at 2,000 RPM on the highway, but while merging, there is no point in trying to get great mileage if you are about to become a hood ornament for an 80,000 lb Freightliner coming at you.
DodgeThis_AZ is offline
post #7 of 10 Old 12-13-2007, 03:46 PM
threetwos
AirFuelEddie
How much you want for it? Why do you want to take it off? Under acceleration it's not used anyway, it also helps to scavenge the crankcase which aids in keeping oil from leaking and prolongs ring life. The pump itself may use 1-2 hp at the most and then only at rpm's that the truck probably never sees. I would leave it on.
post #8 of 10 Old 12-13-2007, 04:00 PM
DodgeThis_AZ
I just got done taking the belt off the two smog pumps this truck has. The thing burns fuel like mad so any thing I can do to keep it from doing so I will. If the mileage doesn’t change I mite hook them back up.
I don’t see any point for them to be there at all. Its a rather weird set up. I've never seen an engine with two smog pumps like this truck has. This whole engine set up is different from what the computer says too. Book says it should be a 4BL carb when its TBI, no cats, no 02s, yet two smog pumps. I'm lost.
If my bro doesn’t want the pumps back on, I'll see if he wants to sell them, give them away, or what ever. Will know when he comes to get the truck next week I think. Do you have the mounting brackets for them? The mounting bracket that these are on also holds the P/S pump and reservoir.
post #9 of 10 Old 12-13-2007, 04:02 PM
threetwos
AirFuelEddie
No I need the brackets too. It's going on my stroker motor,(512)
post #10 of 10 Old 12-14-2007, 02:23 AM
DodgeThis_AZ
All right. I will see what I can do if my brother dosent want them. Theres a bone yard a few miles from here, I will call them and see if they have any 360s with smog pumps I can steal the brackets off of. Or even the whole set up if their cheap enough.
    1998 24v diesel seems weak joshuafiscus 2G Dodge Ram Diesel Talk 3 01-27-2007 09:47 PM
    Problem code baseball401 1G Dodge Durango General Talk 2 04-17-2005 12:56 AM
    P0601 Error jgonick 1G Dodge Durango Performance Talk 7 06-11-2004 01:33 AM
