Go Back   Dodge Talk Community Forum > Dodge Vehicle Forums > Caravan Talk
Vengance
  Installing winch in van, need advice - Posted: 05-20-2002, 11:26 AM
State: MO
Post #1
I'm installing a Superwinch 3500 (a 12v winch with wired remote, for pulling our racecar onto and off the trailer) in the rear of our '96 Grand Voyager.
I have the winch installed (sits just in front of the thing you turn to lower the spare), but I don't have it wired up yet. I'd post pics of it, but the host I use for images is banned, and shows up as astrisks.
My question is this: should I run a wire all the way to the battery, or can I splice something for a shorter trip to +12Vdc, like ther rear accessory outlet? Even better would be to just get a plug at Radio Shack, and plug the winch in whenever I need it, but I'm concerned about current draw. I don't want to pop a fuse or worse trying to winch the racecar onto or off the trailer.
Any help is appreciated.
-Vengance
1996 Neon ACR
1996 Plymouth Grand Voyager SE
2002 Dodge Avenger
Registered users do not see this ad or IntelliTXT ads. Please Register today! Its quick, easy and free!
angldrkns9
 Posted: 05-20-2002, 12:15 PM
Caravan driver =)
City: New York
State: OTHER
Post #2
I know this isn't quite a response you're looking for, but what is a Superwinch 3500?
2000 Dodge Grand Caravan SE FWD
Mods: APC Exhaust, Altezza Euro Tail lights, 5% Tints Front, 5% Limo Tints Back, Eibach Pro-Kit Lowering Springs, Rear entertainment System, Bosch 4+ Plugs, Carbon Fiber Dash Kit, Blue Underbody Kit Lights, Custom K/N Cold Air Intake, Tornado Air Product, Focal Utopia 136 W, JL Audio XR-570, JL Audio VR-690, 2 JL Audio 12W6 V2 in Customer Sealed Enclosure, MTX Thunder 8100D Amp, MTX Thunder 6304 Amp, Alpine IVA-801, Alpine CHA-S634, Alpine DHA-S680, 5.6'' Headrest LCD Screens, APC Side Markers, Flowmaster 40 Series, Viper Alarm System 500 Series w/ Glass Breakage Sensor, StarTech DE Projection Headlights, Eagle Ultra-Grip Winter Tires, Silver Grill, Magnecor 8.5mm Spark Plug Wires, Hella Micro-De HID Fog Lights, 7000K Hella HID H7 Driving Lights.
Future Mods: Alpine Navigation System, 18' Tenzo Racing Rims & Performance Tires, Turn Signal Mirrors, Brembo Brake System, Hood Scoop, 56mm TB, Koni Shocks and struts.
Admin
 Posted: 05-20-2002, 01:43 PM
Admin's Avatar
Ron Wilson
City: Earth
State: OTHER
Post #3
With the current draw of a winch you will need to have heavy cable run directly from the battery to the outlet. Not sure of the guage wire (which would be based on the current draw and run length)...perhaps others can chime in with that info
You will need to put in a breaker or fuse as close to the battery as possible. This is your protection to avoid a melt down and should not be overlooked. The info that comes with the winch should detail that for ya..
Superwinch also has a website at http://www.superwinch.com/
Hope this helps!
05 Hemi Ram 2500 QC SB RED Laramie 4X4 - More to follow
01 Durango 4X4 RED RT
INTERIOR:
Wabasto Elec Sunroof, JoshuaTree Wood Trim Kit
EXTERIOR:
Muth Signal Mirrors, Keystone Hood, Keystone Wing, Westin Safari Bar, PIAA 520 Lights, Westin Tail-light Guards, GTS Headlight Covers, Tinted windows, 3" PA Body Lift, 1 " Bel-tech Shackle Lift, 16x8 Chrome Eagle Claws, LT305/70R16 MT Radial Claws, RS9K Shocks, Clear Signals, HO Lamps
ENGINE/GO-FAST:
Clear Image coated headers, Random cat, Spintech Muffler, Custom Pipes, Fastman TB, Fastman massaged Mopar M1 Manifold, Custom RamAirBox Intake routed through the factory foglight locations, MSD 6A Ignition, MSD Wires, Accel Coil, NKG Plugs, B & G Flash, Just for You Wire Looms, Mopar valve Covers, 180 Stat, more to come.....
08 Sunburst Orange Avenger SXT
1965 WM300 FF Power Wagon - Restoration Project
Ron Wilson
Owner - DodgeTalk.Com LLC
Online Community For Dodge Enthusiasts
Designer Award!:  - Issue reason: Sorry, under wraps still :)Technical Contributor Award!:  - Issue reason: Still a secret!
Sprinter networking with "FleetBoard" RAM MAN Chrysler LLC Press Releases 0 10-15-2003 04:26 PM
Sprinter now also available as a freezer van RAM MAN Chrysler LLC Press Releases 0 10-15-2003 04:17 PM
hidden winch? removable winch mounts? marcopv 3G RAM - 4X4 Talk 2 03-28-2003 01:22 AM
Dodge Commercial Vehicle Sprinter Van RAM MAN Other Dodge Vehicle Talk 7 02-15-2003 11:25 AM
Bad Van? What to do? Scott in GB Caravan Talk 6 11-12-2002 04:55 PM
