Dodge Cummins ECM plugs wiring diagram - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 3rd Gen (02 – 08) Forums > 3G Dodge RAM Diesel Talk
me1magoo
  Question Dodge Cummins ECM plugs wiring diagram - Posted: 05-16-2007, 08:21 PM
me1magoo's Avatar
Post #1
OK, I think I have asked about this before, but surely someone has to have this by now. I need a diagram or schematic or at least pin description for all of the pins on the ECM plugs on an 05 Dodge with the Cummins engine. I have access to Cummins schematics and pin diagrams for every other engine, but they don't release the info for the engines they sell to Dodge AND they make them different so that the pins don't refer to the same controls. I want to add a few things like a switch to manually turn on the cooling fan and I want to have a few other things eventually that are available on the Cummins ISB engine, but have to be accessed or controlled directly at the ECM plug. Also I want to run a switch separately to a common control panel for these items in the dash and integrate my ground signal for the high idle enable switch (ground that bypasses the $300 clutch switch Dodge wants to sell those of us with the manual trans).
SO, does ANYONE have a link to a Dodge Cummins ECM wiring diagram? OR if you have one on your computer or on disk, please email it to me- PM for my email address if you have this. Thank you.
Mat
'05 3500 SRW CTD 6 Speed Manual QC LB 4X4 SLT
-Valair Organic/ Feramic 500 HP clutch w/ heavy duty hyd kit
-AeroTurbine 4040L Performance Muffler w/ Resonator
-Meg's 4" Polished Chrome Exhaust tip extension
-WigiDigit block heater bumper plug
-Bilstein 5100 "Silver/Black" shocks all four corners
-AEM Brute Force CAI polished finish
-Bully Dog Triple Dog downloader
-Autometer dash cubby hole 3 gauge pod
Di Pricol 1600* pyrometer- preturbo thermocouple installed in top of exhaust manifold
Di Pricol 60 PSI Boost guage- fitting installed directly in intake elbow
Di Pricol 100- 280* engine oil temp- sensor directly in oil filter housing
*The perfect match to the Dodge instrument cluster- they really look factory!
-Overhead 3 gauge pod
Di Pricol fuel lift pump pressure- sensor in billet aluminum fuel filter cap
Di Pricol fuel rail pressure- uses factory sensor to 27k psi
Di Pricol rear diff temp- still need to install diff cover with port to hook up
-Mag Hytec rear diff cover w/ sensor
-Valley 16K fifth wheel w/ clamp rail installation kit
-Ram LED lighted hitch plug
-Uniden CB radio mounted on side of center console w/ thru the glass antenna in right corner of rear window
-Tekonsha "Voyager" brake controller mounted in front of 4WD shifter
-Spray in "TOFF" Bed Liner
-AutoVentShade Smoke Bugshield & Window Ventshades
-Westin Signature Series Step Bars- Chrome
-Mopar Black splash guards front and rear
-Air Horns- 4 horns, two compressors under left side of front bumper
-Smith & Wesson .40 semi auto w/ two 14 rd magazines (just in case they don't hear the horns!)
'11 Crossroads Cruiser CF33LF 35' fifth wheel, front BR, full size bath, center living with rear living/ BR and loft above rear- all the options, dual A/C's, power awning- all the good stuff
NickBeek
 Posted: 05-16-2007, 08:31 PM
City: Upstate SC
Post #2
Go to this web site http://www.hemitruckclub.com/ and scroll down the left side of the page. You will see links to download the manual of your year truck. Be ware this is a full shop manual it will take a long time to download. It has gas and diesel combined in one manual. There is a block diagram with pin outs on it. It doesn't show someof them like the one for the fast idle. If you glean any info from it please share the love.
What I say is my own opinion, Take it or Leave it.
Nick-
2006 Ram 2500 SLT Cummins 4x4 LWB 6 Speed, High Idle, Smarty S06, 6" Grand Rock miter cut stacks, silencer ring mia, torque tube gutted, CFM+ horn, SB Con OFe.
me1magoo
 Posted: 05-16-2007, 09:00 PM
me1magoo's Avatar
Post #3
I have read and read that manual. I just can't find an actual diagram or pin description for the ECM. I have even tried looking for testing or actuation functions for special functions like fan engagement, but to no avail. I hope someone just has a pin out description for the Dodge version Cummins in 05 so that I can just use that. I really wish that they would not have messed with them and just let us have the same ECM pin pattern as the other Cummins engines.
Mat
six pack
 Posted: 05-16-2007, 10:56 PM
six pack's Avatar
State: AB
Post #4
Module-engine Control C1 - 60 Way Cav Circuit Function
1 K139 18db Wastegate Solenoid Control
2 - -
3 - -
4 D72 18wt/lb Ccd Bus (+)
5 D71 18wt/db Ccd Bus (-)
6 K65 18br/lb Fuel Pump Relay Return
7 K20 18br/gy Gen Field Control
8 K314 18tn/yl (a/t) Ttva Motor (+)
9 - -
10 - -
11 K2 18tn/bk Ect Signal
12 K181 18br/yl Fuel Rail Sensor Signal
13 - -
14 - -
15 K21 18db/lg Intake Air Temperature Sensor Signal
16 - -
17 - -
18 K23 18br/wt Apps No. 1 Signal
19 K31 18br Fuel Pump Relay Control
20 K315 18tn/or (a/t) Ttva Motor (-)
21 - -
22 K24 18lb/br Ckp Signal
23 K914 18rd/wt Sensor Ground
24 K44 18db/gy Cmp Signal
25 K668 18lg 5 Volt Supply
26 C918 18bk/lb A/c Pressure Signal
27 K853 18db/br 5 Volt Supply
28 K29 18wt/br Apps No. 2 Signal
29 K690 18dg/yl Sensor Ground
30 K11 16wt/db Injector Control No. 1
31 G123 18vt/lg Water In Fuel Sensor Signal
32 K916 18br/or Sensor Ground
33 K167 18br/yl Apps No. 1 Return
34 - -
35 K312 18or (a/t) Ttva Position Sensor Signal
36 K14 16br/tn Injector Control No. 4
37 - -
38
39 - -
40 K13 16tn Injector Control No. 3
41 - -
42 K852 18br/vt 5 Volt Supply
43 K37 18lb Boost Pressure Sensor Signal
44 - -
45 - -
46 K58 16br/vt Injector Control No. 6
47 - -
48 - -
49 - -
50 K12 16br/db Injector Control No. 2
51 - -
52 K975 18br/or Sensor Ground
53 K915 18vt/rd Fuel Rail Sensor Return
54 F855 18pk/yl 5 Volt Supply
55 - -
56 K38 16gy Injector Control No. 5
57 K229 16tn/pk Injector High Side Driver-bank 2
58 - -
59 K227 16br/lg Injector High Side Driver-bank 1
60 - -
Module-engine Control C2 - 50 Way Cav Circuit Function
1 - -
2 - -
3 K615 18vt/wt Inlet Air Temperature Sense
4 - -
5 K176 18br/or Intake Air Heater No. 2 Relay Control
6 K174 18br/yl Intake Air Heater No. 1 Relay Control
7 K31 18br Fuel Pump Relay Control
8 - -
9 T41 18yl/db (a/t) Park/neutral Position Switch Sense (t41)
10 K161 18br/lb Fan Speed Sensor
11 B22 18dg/yl Vehicle Speed Signal No. 1
12 G6 18vt/gy Oil Pressure Signal
13 T6 18dg (a/t) Tow/haul Overdrive Off Switch Sense
14 T118 18dg (a/t) Governor Pressure Solenoid Control
15 T9 18dg/tn (a/t) 3-4 Solenoid Control
16 D21 18wt/br Sci Transmit (ecm)
17 - -
18 T38 18yl/br (a/t) Governor Pressure Sensor Signal
19 D20 18wt/lg Sci Receive (ecm)
20 A209 16rd Fused B(+)
21 Z902 16bk Ground
22 - -
23 F856 18yl/pk (a/t) 5 Volt Supply
24 K900 18db/dg Sensor Ground
25 T75 18yl/lb (a/t) Torque Converter Clutch Solenoid Control
26 N4 18db/wt Fuel Level Sensor Signal
27 - -
28 D25 18wt/vt Pci Bus
29 T54 18dg/or (a/t) Transmission Temperature Sensor Signal
30 A209 16rd Fused B(+)
31 T515 18yl/db (a/t) Transmission Control Relay Control
32 F202 18pk/gy Fused Ignition Switch Output (run-start)
33 K854 18vt/br 5 Volt Supply
34 - -
35 K616 18br/yl Inlet Air Pressure Sense
36 V32 18vt/yl Brake Switch No. 2 Signal
37 B29 18dg/wt Brake Switch No. 1 Signal
38 - -
39 - -
40 A209 16rd Fused B(+)
41 C13 18lb/or A/c Clutch Relay Control
42 - -
43 K160 18br/or Fan Clutch Control
44 T14 18dg/br (a/t) Output Speed Sensor Signal
45 T13 18dg/vt (a/t) Speed Sensor Ground
46 V37 18vt S/c Switch No. 1 Signal
47 K25 18db/vt Batt Temp Signal
48 K400 18br/vt Apps No. 2 Return
49 Z902 16bk Ground
50 Z902 16bk Ground
1970 Challenger R/T convertible
1972 383 Swinger
Cummins 6.7L MegaCab owner member#1.
See Pics Here!
My Challenger
My Gallery
Don't forget to nominate and vote for the vehicle of the month categories, it couldn't be any easier with the following links.Vote Here
Nominate Here
me1magoo
 Posted: 05-17-2007, 08:16 PM
me1magoo's Avatar
Post #5
That is absolutely the best thing that ever happened to me- today at least. THANKS!!!!!!
Mat
me1magoo
 Posted: 05-17-2007, 08:28 PM
me1magoo's Avatar
Post #6
OK, a little more technical..... Plug C2- Pin 43 K160 is an 18 gauge wire, color is Brown and Orange- it is the Fan Clutch Control. The question is- is this a 12V output to the fan clutch? I figure it is variable to control the fan clutch at different speeds, BUT maybe it is just a 12V output to turn it on full speed when needed if the Viscous control does not engage it enough???? Can I just splice in and apply 12V to this circuit to make the fan engage at full speed? Would I need to put a diode in it to keep the 12V signal from feeding back into the ECM plug when I provide that 12V from an outside (battery/ switch) source?
Mat
Farm Boy
 Posted: 06-02-2008, 03:34 PM
City: Kansas flat lands
State: KS
Post #7
me1mango,
Did you figure anything out on the fan clutch? I think I am having trouble with mine, and I would like to check it. I know you wrote this a year ago, but I figured you had it worked out by now.
Thanks,
farm boy
'05 RAM 3500 4x4 4dr CTD 6spd
'03 RAM 2500 4x4 4dr CTD auto
'07 Nitro / Ram Pricing RAM MAN Rumor Mill & Gossip Talk 2 08-30-2006 08:30 AM
Dodge in Hot Pursuit of Police Car Market with HEMI®-powered 2006 Dodge Charger FreeLantz Rumor Mill & Gossip Talk 42 06-04-2006 04:22 PM
All-new 2007 Ram 3500 Chassis Cab FreeLantz Rumor Mill & Gossip Talk 1 03-02-2006 03:35 PM
2006 Dodge Charger and Dodge Magnum Police Vehicles RAM MAN Rumor Mill & Gossip Talk 0 10-20-2005 06:08 PM
Press Kit: 2004 Dodge Car Product Line-up RAM MAN Rumor Mill & Gossip Talk 0 08-01-2003 02:42 PM
