Do I have 4 Wheel ABS or Rear ABS.... - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 14 Old 05-10-2007, 04:58 AM Thread Starter
Airbornejohn007
I need to figure out if my truck has 4 Wheel ABS or just rear ABS...
I'm in Iraq and I'm trying to order extended brake hoses for my lift....
Here is my VIN# 1B7HF13Z4YJ133982
Any help with this would be greatly appriciated.
AirborneJohn
2000 Dodge Ram 1500 Quad Cab Sport 4X4, 5.9L V-8
Waiting in the garage for when I get home from Iraq:
6.5" RCD L/A Suspention Lift
4.5" Superlift Rear Leaf Springs
3" P/A Body Lift
P/A Gap Guards
Thuren Trac Bar
Dual Front Shock Mounts
Dual Steering Stabilizer
Bilstein 5100 shocks
37X13.50R17 Mickey Thompson Baja Claw Radials
17X9 M/T Classic Locks
Bushwacker Extend-A-Fender Flares
4.56:1 Yukon Gears
Detroit Locker (Rear)
Power Stop Cross Drilled Rotors
Hypertech Power Programmer III
Edelbrock Ceramic Headers
Mopar Magnum Valve Covers
Mopar 13.25 Air Cleaner Assembly
13.25 X 4" K&N Air Filter
MSD 6AL
MSD Blaster 2
MSD 8.5MM Wires
Mega Viper Transmission,
soon...
Crown Performance S/S brake lines
FastMan 52MM TB
Hughes Modded Kegger
Hughes Super Prepped Heads
B&G Flash
Airbornejohn007 is offline
post #2 of 14 Old 05-10-2007, 10:33 AM
MeenGreen5.2
i'm blue :D
MeenGreen5.2's Avatar
Quoted: 1 Post(s)
if it was only 2 wheel abs, then it would be useless. abs is so your wheels wont lock up so you still have steering during harsh braking situations.
2010 dodge ram 5.7 sport
deep water blue pearl
BLUE
24"verde rims
stock
BLUE TRUCK CLUB MEMBER #249
Trucks and Guns member #164
MeenGreen5.2 is offline
post #3 of 14 Old 05-10-2007, 10:38 AM
dorelse
Just Rammin with my 98
dorelse's Avatar
Ahh, yes, but many many models of cars/trucks/minivans, etc had only rear wheel ABS.
It was very common in the 90's.
dorelse is offline
post #4 of 14 Old 05-10-2007, 10:44 AM
MeenGreen5.2
i'm blue :D
Quoted: 1 Post(s)
i didn't know that
BLUE
24"verde rims
stock
post #5 of 14 Old 05-10-2007, 12:18 PM
tactransman
Transmission Man!
tactransman's Avatar
My '99 is only rear wheel anti lock brakes.
Terry aka tactransman
'99 Ram 1500 4X4 5.9 Automatic #110 in the White Truck Club
Aren't you tired of getting your parts for your Super Bee from a kid that thinks a Civic is a "hot rod"!
Mods:
MSD Blaster 3 Coil
Magna Flow Cat and "Y" pipe
46RE Built to the Hilt
Transgo TF OD JR Shift Kit (With Mods)
Billet Cover Converter
Upgraded to five direct clutch drum
Five Overdrive Brake Clutch pack
47RE STEEL front planetary
Sonnax Reverse servo parts
HD Kevlar Lined Rigid Int Band
Deep Pan w/cooling tubes
3.8 ratio Int lever
billet Int servo struts
tactransman is offline
post #6 of 14 Old 05-10-2007, 12:45 PM
Aboynamedsue
well the RWAL (rear wheel antilock brakes) is what is used on most reaer wheel drive vehicles. on some 4 wheel drive vehicles they have 4 wheel. thats how you can drive it with the front only and the speedo still works. yours however is only rear wheel ABS.
1999 Dodge Ram Sport 1500
Lowered(3 inch coils 5 inch shackles & hangers), dual tube nitrogen shocks, Street Scene weld in roll pan,
Lund Bed Cover, billet grille and bumper inserts, Clear corner lenses.
Next on the List:
Window tint, Mirrors, shave antenna tailgate grille rain chanels, 1 piece rear window.
Aboynamedsue is offline
post #7 of 14 Old 05-10-2007, 04:57 PM
BigGreenV10
Big Green
BigGreenV10's Avatar
you could also go to http://.dodge.com/wccsapp/universal/D/index.jsp?...
then fill in the info and you will find out all about your truck from the builders you will need the vin
POWDER COAT CLUB MEMBER #1
DON'T TOUCH OUR TRUCK CLUB #2
GREEN TRUCK CLUB MEMBER #31
V10 RAM CLUB MEMBER # 35
MILITARY TRUCK CLUB #147
CRACKED DASH CLUB # 32
2000 2500 V10 4x4 Ext. cab 6" suspension 37 x 12.5 x 16.5 with 4.88 gears.
SCT tuner, Cold air and custom exhaust.
Tail lights, fuel filler door and tail gate handle shaved. Body color fiberglass bed cover and fender flares. Custom all steel 4" cowl hood, custom front bumper.
100% Xtreme Kreations Club President looking for members
BigGreenV10 is offline
post #8 of 14 Old 05-10-2007, 08:29 PM
Josh87
link does not work
2001 Dodge Ram 1500 Std. Cab
4x4
5.2L
Automatic
Josh87 is offline
post #9 of 14 Old 05-17-2007, 04:29 AM Thread Starter
Airbornejohn007
Alright, I don't want to sound ungreatfull or anything but I'm being told 2 different things...
Does anyone know for 100% sure? I'm about to drop 150 bucks on custom stainless brake lines and I dont want to be wrong, you know what I mean?
I tried e-mailing a couple dodge dealerships but have gotten no response from them.
Any help is appriciated, AirborneJohn
3" P/A Body Lift
P/A Gap Guards
Thuren Trac Bar
4.56:1 Yukon Gears
MSD 6AL
MSD Blaster 2
MSD 8.5MM Wires
soon...
FastMan 52MM TB
B&G Flash
post #10 of 14 Old 05-17-2007, 05:36 PM
BigGreenV10
Big Green
I dont know how to use the link but if you type that in your window it will take you to the dodge site and type in vehicle info (vin)and they will respond with all your build info at least that is where I got mine from they told me everything from the usefull to the who cared
post #11 of 14 Old 05-17-2007, 09:22 PM
B-300
4 Wheel Power Disc Brakes
2 wheel abs has a speed sensor on the differential housing. 4 wheel abs has a sensor at each brake, front and rear.
Locate the sensors and you can tell what you have.
--B-300--
B-300 is offline
post #12 of 14 Old 05-21-2007, 08:22 PM
QCRam
Try this link to request a build sheet linky
1999 1500 Quad cab, 5.2 4x4 Flame red/Driftwood 2" lift, 285/70/16 - sold
2007 Chevy HHR
2002 Navy Blue Metallic Camaro SS convertible
QCRam is offline
post #13 of 14 Old 05-22-2007, 07:43 PM
BigGreenV10
Big Green
thats what I was trying but me no computer literate
post #14 of 14 Old 05-23-2007, 02:45 PM Thread Starter
Airbornejohn007
Just got my printout... Said rear ABS. Didnt say anything at all about the front. Took that as rear ABS only and ordered my brakelines.
Thanks for the help, John
3" P/A Body Lift
P/A Gap Guards
Thuren Trac Bar
4.56:1 Yukon Gears
MSD 6AL
MSD Blaster 2
MSD 8.5MM Wires
soon...
FastMan 52MM TB
B&G Flash
    Conversion and RV Manufacturer info: RAM MAN Dodge B-Series Vans 1971 - 2003 11 11-17-2009 12:38 AM
    4 wheel or rear wheel abs? Deezel_Dusten 1G Dodge Durango - Tire/Wheel/Susp Talk 4 03-13-2005 07:15 PM
    4 wheel ABS udidwhat? 3G Dodge RAM - General Talk 3 11-15-2004 11:16 AM
    2005 Dodge Ram Power Wagon Specifications RAM MAN Rumor Mill & Gossip Talk 0 10-01-2004 06:12 PM
    05 Chrysler and Dodge Minivan Specifications RAM MAN Rumor Mill & Gossip Talk 0 12-12-2003 07:37 AM
