How hard is it to change U-Joints - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 05-02-2007, 01:55 PM Thread Starter
chefred112
Valdez Racing Team
chefred112's Avatar
Quoted: 58 Post(s)
hey All... can anyone tell me how hard is it to change out my U-joints? or do i need to take them in (with driveline) and have them pressed out/In...
thanks,
Fred
05 Ram 1500 QC 5.7 (stroked 6.4 as of 7/14)
Inertia Motorsports Stroker Assy/Custom Tuned
best 1/4 (5.7 nitrous): 12.10 @ 113
best 1/4 (5.7 na): 12.96 @ 104 (cold day)
best 1/4 (6.4 na): 12.54 @ 107 (hot day)
over 300k miles on block
chefred112 is offline
post #2 of 9 Old 05-02-2007, 07:07 PM
DannyMK2
DannyMK2's Avatar
Quoted: 12 Post(s)
they are not that hard to do. of course it helps if you have a lift readily availible to get the driveshaft out. changing the u-joint itself is easy.
2012 Express QC 4x4
2004.5 QC DRW 3500 Cummins 4x4
1998.5 QC DRW 3500 Cummins 4x4 - SOLD
2002 Ram 1500 QCSB 4.7L 4x4 - SOLD
Dodgetalk.com 287 Enthusiast Member #108
DannyMK2 is offline
post #3 of 9 Old 05-02-2007, 07:20 PM Thread Starter
chefred112
Valdez Racing Team
chefred112's Avatar
Quoted: 58 Post(s)
...takin out the shaft is the easy part...but how hard is it to remove the u-joints?...aren't they pressed in?
post #4 of 9 Old 05-02-2007, 09:21 PM
sawcut64
Inertia ROCKS!!!!
sawcut64's Avatar
Quoted: 1 Post(s)
Well the old style u-joints had c-clips that you had to remove and then use a socket and a vise. I even seen some guys use a hammer instead of a vise but I wouldn't recommend it.
2005 RC SB 2WD Hemi Ram
NA Stockblock Setup-7.79 1/8 NA, Best 60ft 1.68
NA Stroker Setup-?
Inertia 400 CI Stroker-Inertia Custom Cam-170 Degree T-stat-6.1 Exhaust Springs/6.1 Pushrods-Caltracs-Superchips Performance tune-Ebay Knock Off CAI-Edge 2800 Billet Converter-IAT Mod-True 3" Dual Exhaust Dumped-McGaughy Rear Flip-Motive 4.56 Gears, Factory LSD-Pacesetter Long Tube Headers-Stock Front Coils Trimmed 2" Drop-Street Scene Roll Pan
sawcut64 is offline
post #5 of 9 Old 05-03-2007, 11:13 AM Thread Starter
chefred112
Valdez Racing Team
chefred112's Avatar
Quoted: 58 Post(s)
...one of the guys told me to take it in to get it pressed out...but the more I look at it it appears that i could prolly use a C-clamp or a vise (with a socket to fit the hole) to do it...
post #6 of 9 Old 05-03-2007, 11:24 AM
dizzyD
Registered MOPAR User
dizzyD's Avatar
Quoted: 24 Post(s)
Do the new rams have the bolted in or clipped in u-joint cups? I haven't looked at those yet.
2012 Challenger SXT+ 220ci 5 speed, blackberry pearl, FM xxMM, diablo in-tune I1000, Carbon fiber pedal covers, 11% tint
1999 Durango SLT+ leather, 360ci 4x4, hughes plenum rebuild, superchips 3865, tow pkg, 3.55 LSD, rear tail light guard, K&N CAI, FM 50MM TB, crystal clear headlights, Torsion/shackle lift, Rancho RSX's, Pacesetter headers, dual trans & oil temp a-pillar pod, chrome deep trans pan, drilled & slotted rotors, 10 disc cd changer.
2004 Ram 1500 SLT 2WD QC LB 345ci, FM 84MM TB, slotted brake rotors, step bar, diamond plate pedals, locking gas door, tow package w/ 3.55 lsd, Hellwig LP-15, shell and carpet kit, 18% door window tint, Magnaflow 12641, Slammed1's 3" spindle lift and 2.5 coil spacer, rear lift shackles, Airraid MIT, superchips 3815, 6K front winch & custom Winch Plate, Autometer phantom trans gauge mounted in Mopar SRT A-Pillar single pod, lumber/roof rack, Rancho 9000X shocks, ATS fender flairs, 1" BL, gap guards, black grille, silver painted bezel
2005 Dodge Magnum RT- Midnight Blue -Vroom Lakewood front strut bar, K&N Filter
Gone but not forgotten 93 factory freak CC dakota lifted 4x4 318
dizzyD is offline
post #7 of 9 Old 05-03-2007, 04:55 PM
Jimmy TJ
You are correct, I haven't done them on my truck but I've changed the U-Joints on my Jeep several times using a big 'ol C-clamp.
2003 Dodge Ram 1500 4x4 Quad-Cab
HEMI 5.7L V8
Traded in for a 2007 Jeep Patriot
Jimmy TJ is offline
post #8 of 9 Old 05-03-2007, 09:47 PM
DannyMK2
DannyMK2's Avatar
Quoted: 12 Post(s)
hammer worked fine for me..never thought to use a c-clamp, but its a good idea.
2012 Express QC 4x4
DannyMK2 is offline
post #9 of 9 Old 05-04-2007, 06:26 PM Thread Starter
chefred112
Valdez Racing Team
chefred112's Avatar
Quoted: 58 Post(s)
..well, did them yesterday.. I DID have to get them pressed out...they wer in ther like a mutha... able to use a vise to get them in tho...
    Sit-Com Oil Change. Enjoy! christophercale 3G Dodge RAM - General Talk 22 12-31-2005 08:04 PM
    Will not change from 1st to second gear under hard acceleration seankm 3G Dodge RAM - 4X4 Talk 3 05-06-2005 07:42 PM
    how hard is it to change power lock motor? glordel 1G Dodge Durango General Talk 11 12-02-2004 02:02 PM
