Block drain plugs for coolant? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 10 Old 04-05-2007, 03:43 AM Thread Starter
MonsterStyleCom
MonsterStyleCom's Avatar
Anyone have pics of where I'd puke around on removing my engine block drain plugs for my coolant? I need to drain my radiator/engine of coolant to remove my water pump, correct? If so, I need to find the plugs. I been using alldatadiy.com and looked under my truck - I cannot find it/them :-(
MonsterStyleCom is offline
post #2 of 10 Old 04-05-2007, 06:33 AM
low pressure
low pressure's Avatar
when i did mine i only took off the drain plug on the radiator. its at the bottom of the radiator driver side.
1999 5.9 Magnum
3" body lift
T/S lift
33x12.5x15 BFG's KO
Borla cat back
Autolite 3923
Surco roof rack (home made brackets)
8" Kicker sub w/ MTX amp hooked up to factory head unit
viper fan w/ hayden 3652 controller (less than $200 upgrade)
low pressure is offline
post #3 of 10 Old 04-05-2007, 01:59 PM
mpm32
There on both sides of the lower block, not real good directions I know. If you do find them, good luck gettting them out. They most likely be stuck real well. And there's not much room to get enough leverage to break them free.
You can use the drain plug on the radiator or pull off the bottom hose.
99 Durango SLT
It has 4-wheels and a third row seat.
5.2 liter
105,000 miles oh wait, I drove to work a lot since then - 120,040- 1,000 miles on new engine, 126,000 miles on the rest of the truck.
Mods - New nerf bars to replace the rotted out running boards. Factory brushguard, used to be the same color as the truck, I took it off and painted it black.
Hughes plenum pan. Done!
mpm32 is offline
post #4 of 10 Old 04-05-2007, 02:27 PM Thread Starter
MonsterStyleCom
So if I change out my water pump just drain the radiator? I should be fine? Will do! Thanks guys.
post #5 of 10 Old 04-05-2007, 02:49 PM
Big D 318
Big D 318
Big D 318's Avatar
Don't pull the drain plugs yet!
Are you sure that you need to pull the drain plugs just to replace your water pump? Dude, I think you can just pull off the lower radiator hose and let the fluid drain into a pan - a large pan. Then you can start tearing things down to get to the water pump.
My water pump bearings went out last November and I had to replace the pump. A bit of a pain, but I didn't have to pull the drain plugs from the engine block to do it.
Big D 318 is offline
post #6 of 10 Old 04-05-2007, 03:52 PM Thread Starter
MonsterStyleCom
Ahh that's what alldatadiy.com suggested... I'll just try it your guys way and see how we work out!
post #7 of 10 Old 04-06-2007, 04:47 AM
firestingwisher
firestingwisher's Avatar
According to Alldatapro.com, there are actually block drain plugs,it looks like a hex headed bolt, I, imo, believe most of you are referring to the freeze plugs. Which I was thinking of to begin with. According to Alldatapro.com, (to the best of my interpretations) the block drain plug is located on the driver side of the engine, straight below the spark plug for cylinder 3. The freeze plug, seems to be located straight below cylinder number 1, and also another one, between 3 and 5. Maybe this helps, maybe you've already done it. Anyway, hope it was of interest.
White 2000 SLT 5.2L 318 Almost completely stock
Removed roof racks
Pioneer Single Disc Cd-player
Emergency lighting
30x9.50's
4 12" Infinity Subs
sealed enclosure
6.5" infinity component speakers and tweeters
Exterior mods
-Two "fog/driving" lights added to rear for night backing
-In Channel Autoshade Vent visors
-Tint front windows with 5%
-180 Deg t-stat
*DodgeTalk.com
#(81)*
Planned alterations:
-Apline head unit
-altzella black euro rears
-One piece chrome headlight/corner marker
-Cat-back, Borla
-K&N Cold Air Intake
-2" front drop, 4" rear drop
-LSD
-fastman TB
-Upgrade fuel pump/regulator
-Elec Fan/get rid of Clutch fan
-Highflow Water pump
-Optima deep cycle gell cell battery
-Upgrade from Factory Speakers and add Tweeters
-DVD/Video monitors
-Playstation
-200(or highest I can get) amp alternator
Can't think of anything else right now
firestingwisher is offline
post #8 of 10 Old 04-06-2007, 08:44 AM
mpm32
Nope, I was talking about the block drain plugs. There's one on each side. Very hard to break loose because of the location and access to the location. At least I had a hard time doing it.
99 Durango SLT
5.2 liter
mpm32 is offline
post #9 of 10 Old 04-06-2007, 06:46 PM
firestingwisher
[QUOTE=mpm32]Nope, I was talking about the block drain plugs. QUOTE]
I knew that you weren't talking about the freeze plugs, but it sounded like some of the other people were. I was thinking freeze plugs, untill I looked into it a little deeper. Get everything done alright?
Removed roof racks
Emergency lighting
30x9.50's
4 12" Infinity Subs
sealed enclosure
Exterior mods
-180 Deg t-stat
*DodgeTalk.com
#(81)*
-Apline head unit
-Cat-back, Borla
-LSD
-fastman TB
-DVD/Video monitors
-Playstation
post #10 of 10 Old 04-07-2007, 12:04 AM Thread Starter
MonsterStyleCom
I haven't started any of the processes to fix the water pump. I have all the gaskets, parts, etc... Just not in a rush to fix it. It's a little intimidating ya know?
I'll crack the b!tch open tomorrow and get it done! Muahhahaha!
    Denso "iridium Power" Plugs...4.7l AIR_RAM 3G Dodge Ram Performance Talk 33 02-13-2006 11:14 PM
    Getrag 238 6-speed - Drain and fill plugs? rbrown6061 3G Dodge RAM - Drivetrain Talk 2 01-15-2006 01:34 AM
    Tune up questions CBP ENGINEER 2G Dodge RAM - General Talk 6 12-06-2005 07:17 PM
    Spark Plug Time!! Need Help!! LurcH 1G Dodge Durango Performance Talk 15 08-15-2003 09:02 AM
