2500 front shock install - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 03-17-2007, 07:38 PM Thread Starter
bytehoven
bytehoven's Avatar
Am I correct in assuming the 2500 front shocks are removed & installed by taking off the shock top "basket mount" which is bolted to the frame area with (3) bolts?
It looks like both the air filter box and battery box need to be removed. True?
Finally, the bottom bolt on the front shocks is also a little tricky to access. It looks like I need to use a box wrench on the back end nut, and an impact drive socket on the front end bolt head. True?
Can anyone recall the sizes of the front & rear nut/bolt sizes?
Thank goodness the rear shocks look a #2 level of effort compared to the #8.9 on the fronts. Looks like I only need to remove the spare to get to the drivers side shock top nut & bolt.
bytehoven is offline
post #2 of 6 Old 03-17-2007, 08:02 PM
strtlegal
strtlegal's Avatar
the front doesnt need the battery or the air box removed its cake to get to just use a long extension on the big top bolt and the small ones on the out side..sometimes people remove the fender liner which is still not neccessary but can help...the drivers die is alittle trick on the top but you can get it done
the bottom is a 13/16 or a 22mm they come factory with flag bolts ( just like it sounds nut with a lip on it so it doesnt rotate when losseing or tightening the bolt) so just impact the from the front and the bolts will come right out..just keep your wheels straight and on the ground and youll have plenty of clearance on the passenger side between the tierod and the center link
good luck..should take you about 20 minutes a side
CARLI 6" COILS/THUREN RADIUSARMS
CARLI LONG TRAVEL LEAF SPRINGS
KING 4 TUBE BYPASS 3.0'S
KMC Enduro Pro beadlocks
37" TOYO MT'S
Strapt Performance
strtlegal is offline
post #3 of 6 Old 03-17-2007, 11:03 PM
HemiBoatPuller
When I had my level kit installed... yes they did pull the airbox and battery. Not sure if it would be different on a 1500.
20 min per side....?? that does not leave much time for beer.
HemiBoatPuller is offline
post #4 of 6 Old 03-18-2007, 02:49 AM
strtlegal
strtlegal's Avatar
its different on a 1500..thats more like a strut
37" TOYO MT'S
Strapt Performance
post #5 of 6 Old 03-18-2007, 10:57 AM
Thor20003
Thor20003's Avatar
When I replaced mine on a 2500 I did have to remove the airbox, but not the battery.
Thor20003 is offline
post #6 of 6 Old 03-18-2007, 06:08 PM
strtlegal
strtlegal's Avatar
it might help to move the inlet hose on your turbo but airbox wasnt in the way
37" TOYO MT'S
Strapt Performance
    odering 4.56 gears soon? 2006 4x4 install is the front 8.0 or 8.25? titanconvert 3G Dodge Ram Performance Talk 1 07-06-2006 03:15 PM
    Front shock question ctfzr 3G Dodge RAM - 4X4 Talk 5 05-20-2006 06:16 PM
    How to Install Steering Stabilizer shock? clown_trigger 2G Dodge RAM - 4X4 Talk 17 04-19-2006 03:15 PM
    2" Lift on 2500 2wd on front only... yellow2000c5 3G Dodge RAM - Sport Truck Talk 9 08-22-2004 03:51 PM
    Shock information from HankL RAM MAN 2G Dodge RAM - General Talk 2 02-28-2003 11:56 AM
