Bad vibration while slowing down - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 5 Old 03-13-2007, 08:49 PM Thread Starter
buckgtr
Ok I need some help! I have a 05 2500 CTD has a six inch susp lift with 37 inch toyo's. I have not had a problem for 32000 miles until last night. I had just pulled off the highway and began to slow down when my truck began to shake and vibrate. It came on all of a sudden. It does it at lower speeds. Nothing seems to happen when excellerating just when slowing down. Doesn't matter if your in gear(6sp) or in neutral. I don't feel it in the steering wheel just the body. I thought it was in the front end but I took it to the place that put on the lift etc and they thought it was in the rear. After 4 hours they couldn't figure it out, checked all the specs and they were good. They suggested I should take it to the dealer. Which I did, I have an appt for thurs3/15. Anyone have any ideas what it would be? Any help would be greatly appreciated!
buckgtr is offline
post #2 of 5 Old 03-13-2007, 10:12 PM
paulgaard
I had the same problem, took it to a tire shop and they machined down the brake rotors for $70 and everything was fine
paulgaard is offline
post #3 of 5 Old 03-13-2007, 10:36 PM
bonzai
bonzai's Avatar
It does sound like bad rotors.
2003 DODGE RAM QC
bonzai is offline
post #4 of 5 Old 03-13-2007, 10:43 PM
john.colorado
Lifted HEMI 4x4
john.colorado's Avatar
sounds like warped rotors
lets see some pics of your lifted CTD man
john.colorado is offline
post #5 of 5 Old 03-13-2007, 10:45 PM
slammed1
slammed1's Avatar
do you have blocks in the rear for lift??
reason I ask is that 3" or larger blocks can contribute to axle wrap,which can happen slowing down,causing the leafs to start to wrap up.......causing a truck to vibrate.
just a thought
warped rear rotors can also be a culprit.........them not figuring it out is not a good sign.....for them anyway.
slammed1 is offline
    Intermittent HEAVY Vibration... very crazy! investor 3G Dodge RAM - Drivetrain Talk 2 08-21-2007 02:03 PM
    Bad Vibration 90Ramcharger 2G Dodge RAM - Drivetrain Talk 1 12-23-2006 12:03 PM
    No Help From Chrysler on Bad Paint Problem Disguntled 2G Dodge Dakota - Interior/Exterior 13 06-26-2005 04:30 PM
