2000 Grand Caravan - No brake lights - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 5 Old 02-08-2007, 06:16 PM Thread Starter
north country
Have a 2000 Grand Caravan Sport - brake lights do not come on. Where do you start checking? Is it the switch, a fuse, both bulbs at the same time?
north country is offline
post #2 of 5 Old 02-08-2007, 09:16 PM
acton mike
could be bulbs - substitute a good bulb if you have one or use a test light or multi-meter
If it is not the bulb, I would go right to the brake light switch and look for a dislodged or broken wire
acton mike is offline
post #3 of 5 Old 02-08-2007, 09:36 PM
kabhatti
If they're both not working, I would first check the fuse under the dash...
kabhatti is offline
post #4 of 5 Old 02-09-2007, 06:16 AM
donald7150
donald7150's Avatar
if the brake switch is out of alignment or dislodged the brake lights will stay on
most likely you have a blown fuse, if you tow a trailer with your minivan have the trailer lights checked for shorting, or check the trailer harness itself in the back of your van if so equipped
2005 Chrysler 300 (DD): 6000K 50W HIDs, Niteshades, LED Interior light Conversion...
'99 Caravan: Work van. 6000K HID headlights and fogs
'92 Chrysler Daytona IROC R/T (2.2L DOHC Turbo-III)
donald7150 is offline
post #5 of 5 Old 02-11-2007, 06:16 PM
Glenn_H
I just replaced the brake light switch on my 96, since I kept getting the "Service Engine Soon" light for a brake fault, intermittent operation. If you have the Haynes manual, the instructions are on page 9-20...the index does not mention this task. The switch is located on the brake pedal arm above the brake pedal pad. If you need to replace the switch, depress the brake pedal fully and turn the switch body approx 30-deg counter clockwise (to the left). It will pop right out of the switch mounting bracket. Carefully remove the connector by prying on alternate ends with a screwdriver. Be careful not to damage the connector. Look at the arm where the switch is mounted, make sure it is not bent (mine was). If bent, carefully straighten it out.
The new switch will have the plunger protrude much farther than the old one--that's a feature, not a bug. Do not try to push it in, the correct plunger length is done during the pedal adjustment. To install the new switch, plug in the connector and make sure it's fully seated. Press down on the brake pedal as far as it will go, insert the switch into the mounting bracket. A key tab and mating slot on the mounting bracket will align the switch. Turn the switch to the right (clockwise) about 30-deg to lock it in place. Release the brake pedal and carefully pull it back all the way...you'll hear a clickclickclick sound as the plunger ratchets into the correct length. Check to make sure the brake lights work.
The brake switch is part of the power train control system and feeds information into the PCM (Powertrain Control Module) to turn off cruise control, downshift, etc during braking.
Glenn_H is offline
    ABS and Brake Dash Lights tcjram99 2G Dodge RAM - General Talk 7 06-21-2006 10:09 PM
    those pointless 3rd brake lights miniracer 1G Dodge Durango General Talk 7 03-16-2006 01:55 PM
    Problem with Trailer Lights LaserAWD 2G Dodge Dakota General Talk 5 03-01-2006 08:59 PM
    Brake lights not working on 97 Intrepid scout_75 Dodge Intrepid 1st Gen (93 - 97) 3 01-22-2006 06:36 AM
    Brake lights on for no reason corky Dodge Caravan General Talk 3 12-13-2004 09:40 PM
