How much horsepower does 318, 340 & 360 V8 have? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 12 Old 02-07-2007, 07:25 PM Thread Starter
Elajten
Dodge Power
Elajten's Avatar
Hi!
I want to know how much horsepower, and torque does the:
* 1988 318 TBI
* 1988 340 TBI
* 1988 360 TBI
....have?
Is this correct:
* 318 Carb = 130kw
* 318 TBI = 128kw
* 360 Carb = 137kw
* 360 TBI = 153kw
...all Dodge B250/350 Van engines?
Elajten is offline
post #2 of 12 Old 02-08-2007, 02:06 AM
Daytrepper
2.7 Trauma Surgeon
Daytrepper's Avatar
5.9L Injected = 190 HP
5.2L Carb = 140 HP
5.9L Carb = 170 HP
5.2L Injected = 180 HP
I couldnt find anything for a 1988 340 engine. Torque specs for 5.2 and 5.9 were between 270 and 325 ft lbs, depending on if they were carbureted or injected.
Pretty scary, my little 3.2L V6 in my Intrepid is 226 HP. Shows the improvements they have made in engine designs over the years.
Dan C.
1998 Dodge Intrepid
1999 Dodge Ram 3500 CTD
Daytrepper is offline
post #3 of 12 Old 02-08-2007, 06:29 AM Thread Starter
Elajten
Dodge Power
Elajten's Avatar
5.2L Carb = 140 HP
5.9L Carb = 170 HP
Thanks
Elajten is offline
post #4 of 12 Old 02-08-2007, 06:45 AM
Dodgevanman
Do It In A Van
Dodgevanman's Avatar
You won't find any info on a 1988 340 engine because the Chrysler stopped production of the 340 in 1972.
Nate Breece
5.2L Magnum
2008 Grand Caravan SXT
3.8L
Member of:
Dodgevanman is offline
post #5 of 12 Old 02-08-2007, 02:56 PM
B-300
4 Wheel Power Disc Brakes
I think the 340 was produced till 1974. In '72 the compression was cut to 8.5 to1 , the forged crank replaced with cast and the camshaft changed.
In general tems the 360 produces more torque at a lower rpm than the 318 due to a longer stroke. The 360 produces a little more horsepower than the 318 due to lagrer displacement.
--B-300--
B-300 is offline
post #6 of 12 Old 02-08-2007, 05:10 PM
Dodgevanman
Do It In A Van
Was it '74? I knew the compression went down on the 340 in '72 but I couldn't remember if it was the last year of production as well. Maybe it was the 360 that debuted in '72. I had that year stuck in my head.
Nate Breece
5.2L Magnum
3.8L
Member of:
post #7 of 12 Old 02-08-2007, 06:15 PM
B-300
I think '72 was the first year of the 360 and they had thick-wall blocks thru '74 so the same basic casting with different casting # could accomodate the larger 4.04" 340 bore.
The early 360's ('72-'74) are cold blooded and take longer to warm-up but can take the larger overbore.
--B-300--
B-300 is offline
post #8 of 12 Old 02-08-2007, 10:21 PM
gsmagnum
gsmagnum's Avatar
'73 was the last year for the 340.
The performance small block after that starting in '74 was the 360.
I almost bought a '73 340 Duster. A friend had a 340 Duster way back when too.
Grant
gsmagnum is offline
post #9 of 12 Old 02-08-2007, 10:27 PM
gsmagnum
gsmagnum's Avatar
SAE rating for the 340 in '72 and '73 was 240 HP. The '74 360's rating was 245 hp.
Grant
gsmagnum is offline
post #10 of 12 Old 02-09-2007, 01:53 PM
B-300
340 to 360 transition
It seems were all taking about the 340 now. My info was based on How to rebuild your small block dodge engine or something to that effect and seeing a #matching cuda for sale a few years ago that had 340. What I recall of the book also said '74 was a transition and it's when the High-Perf 360 debuted with 4-bbl, same cam as late 340 and shoot-peened crankshaft.
Also internally '72 was the begining of pressed piston pins and the end of full floating pins.
--B-300--
B-300 is offline
post #11 of 12 Old 02-09-2007, 11:14 PM
gower3544
I Love My Van!
gower3544's Avatar
So how much horsepower does my van have which is a 94 5.2L V8??
gower3544 is offline
post #12 of 12 Old 02-10-2007, 02:25 AM
Daytrepper
2.7 Trauma Surgeon
Daytrepper's Avatar
220HP, 300 Ft Lbs of Torque.
5.9L is 230 HP and 330 Ft Lbs.
Dan C.
1998 Dodge Intrepid
    Engine choice? (318 vs 360 cid) rstl99 Dodge B-Series Vans 1971 - 2003 20 09-08-2006 12:56 PM
    88 360 To 90 318 Swap bpblaes Dodge Ram Truck 1st Gen (88 - 93) Forum 4 02-28-2006 07:57 AM
    318 to 360 mar0051 2G Dodge RAM - General Talk 8 11-28-2005 11:08 AM
    Help! 318? 340? or 360? ghostrider Dodge Ram Truck 1st Gen (88 - 93) Forum 7 11-22-2004 04:11 PM
