Need trans/tps help got a po123 code. - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Ram Truck 2nd Gen (94 – 01) Forums > 2G Dodge RAM - Drivetrain Talk
99sliverram
  Need trans/tps help got a po123 code. - Posted: 02-04-2007, 10:28 PM
99sliverram's Avatar
City: Chandler Arizona
Post #1
Ok, I'll start from the beginning and make it short along the way. Back around christmas my truck started jerking on cruise running between 65-75 mph. It only had this problem on cruise and never bothered me any other time. The truck ran fine shifting wise. At the time a few people on here suggested that the tps might be the problem. Well fast forward to a week ago my truck started having problems shifting from 2nd to 3rd gear, to the point it would only upshift if you did it manually. Otherwise it shifted smoothly in the other gears just like it has since the day I bought it. I checked the tps voltage and got readings of .60 to over 1.00 volt. Several members on here to me that meant that the tps was shot. Well I bought a new tps on thursday and put it on and it made a little difference to the truck. It now will shift from 2nd to 3rd on it's own but now it won't shift out of first unless you take your foot from the gas pedal and it sugres a lot in 1st gear at low speed (5-25 mph). I had done a search and found that the tps may need reset with a "drb tool"? I had also read that the tps might need to have the voltage set. So I now to tonight I went and checked the voltage and it was reading .73 which I understand is the right number for it to be at?? Well in the process of checking the voltage the orange wire running to the tps connector broke in two. I fixed the wire and started the truck and I got a check engine light. I borrowed a scan tool and got a
"PO123 generic tps/pedal psition sensor a control high output"
message. There was no book to explain more on this code.
My questions are:
1) does this mean that the voltage now needs to be set now that the wiring is is intact?
2) that the new sensor is bad?
3) or do I just need to reset the codes and try it again?
Any help would be greatly appreciated. But I would however like to hear from those of you that have had this code or the similar problem first or if there are any mechanics reading this.
The truck still runs the same after the wiring was fixed and it still has all four forward gears and reverse.
Formerly 2000redram
FORMER Member #93 of "The Red Truck Club"
I no longer have the truck. Time for new name
1999 Dodge Ram 1500 SLT 4x4 quad cab Driftwood/(sliver) metallic, leather int Member #180 Sliver truck club
3:92 gears
3" lift
285/75/16 all terrains
Randy Ellis light bar with 4 KC daylighters
94 -96 NEW in box Mopar Ram electronic ignition switch for sale $20 shipped to the lower 48.
Future mods
Exhaust
315/75/16 tires
Trucks and guns member #47
69 Charger R/T "General Lee replica"
440 .030 over
ported heads
10 to 1 comp
flowmaster exh
727 torqueflite w/ 2500 stall
4:10 geared Dana 60 with detroit locker
Not track tested yet. "weekend driver"
kennethpruett
 Posted: 02-07-2007, 01:47 PM
State: GA
Post #2
I think your error is P0123 and not PO123 (zero and not letter O).
You might find more information here:
http://www.obd-codes.com/trouble_cod...high-input.php
Not sure about reseting TPS. Anybody?
Did you get the same readings after fixing it?
KP
4x4_guy
 Posted: 02-08-2007, 07:39 PM
City: Fayetteville, Arkansas
State: AR
Post #3
you dont have to reset the tps at all...just hook it up to a drb and make sure the tps volts are within specs
-Jesse-
1996 Dodge Ram 2500 12valve cummins diesel
~Jesse~
kennethpruett
 Posted: 02-08-2007, 09:23 PM
State: GA
Post #4
-Jesse-
Someone else said they did have to have it done.
This one is still up in the air until someone can definitely confirm about reseting.
KP
99sliverram
 Posted: 02-09-2007, 07:39 PM
Post #5
I have seen this "drb tool" post before. Where do I get one and how much are they?
Formerly 2000redram
3:92 gears
3" lift
Future mods
Exhaust
315/75/16 tires
440 .030 over
ported heads
10 to 1 comp
flowmaster exh
tactransman
 Posted: 02-10-2007, 06:23 AM
tactransman's Avatar
Transmission Man!
City: Gerald, Mo.
Post #6
DRB is the scan tool for a Dealer. About $9000
Terry aka tactransman
'99 Ram 1500 4X4 5.9 Automatic #110 in the White Truck Club
Aren't you tired of getting your parts for your Super Bee from a kid that thinks a Civic is a "hot rod"!
Mods:
MSD Blaster 3 Coil
Magna Flow Cat and "Y" pipe
46RE Built to the Hilt
Transgo TF OD JR Shift Kit (With Mods)
Billet Cover Converter
Upgraded to five direct clutch drum
Five Overdrive Brake Clutch pack
47RE STEEL front planetary
Sonnax Reverse servo parts
HD Kevlar Lined Rigid Int Band
Deep Pan w/cooling tubes
3.8 ratio Int lever
billet Int servo struts
99sliverram
 Posted: 02-10-2007, 08:42 PM
Post #7
LMAO!!!! OK I think I'll pass on that one. It would cheaper to just throw a match in the gas tank and turn it in on my insurance and start over with a different truck! LOL
Formerly 2000redram
3:92 gears
3" lift
Future mods
Exhaust
315/75/16 tires
440 .030 over
ported heads
10 to 1 comp
flowmaster exh
99sliverram
 Posted: 02-19-2007, 09:21 PM
Post #8
Well I took the truck to a trans shop today and was told second gear is gone. I was quoted several price ranges from $1800 to $2500 for a rebuild and labor to remove and install.
Formerly 2000redram
3:92 gears
3" lift
Future mods
Exhaust
315/75/16 tires
440 .030 over
ported heads
10 to 1 comp
flowmaster exh
tactransman
 Posted: 02-19-2007, 09:39 PM
Transmission Man!
City: Gerald, Mo.
Post #9
$2500 is a little high for your truck unless that is with an extended warranty.
Mods:
MSD Blaster 3 Coil
3.8 ratio Int lever
99sliverram
 Posted: 02-20-2007, 09:16 PM
Post #10
2 year / 24,000 miles warranty. The thing that is stumping me is that if the truck has lost 2nd gear what gear (other than 2nd) would be causing the truck to run around 3000 rpm at 30 mph? It seems to low an rpm for 1st for sure and to high for 3rd gear?
Formerly 2000redram
3:92 gears
3" lift
Future mods
Exhaust
315/75/16 tires
440 .030 over
ported heads
10 to 1 comp
flowmaster exh
Trouble codes for neons 95-99 dodgeneonACR98 Dodge Neon - General Talk 87 02-25-2008 12:15 PM
98 Caravan 3.3L "Haunted" - Electrical problems daberguson Dodge Caravan/Grand Caravan Talk 11 12-22-2007 02:48 AM
Trouble Codes for 96-97 Caravans Jmw132001 Dodge Caravan/Grand Caravan Talk 0 05-18-2006 09:54 PM
How to decode the VIN flattop 3G Dodge RAM Diesel Talk 9 03-23-2005 09:25 PM
