Metal Chunks in Rear Differential - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 5 Old 01-28-2007, 11:36 AM Thread Starter
rome5982
rome5982's Avatar
Here is another thread about metal pieces found in our rear differentials. This has sometimes been referred to as the "c-clip" problem, however, I believe that my pieces were part of the clutch pack retainer. The picture shows what I found when I changed the rear differential fluid as part of regular preventive maintenance. I have a LSD and the milage is 70K. I took the truck to the dealer and they confirmed that the whole rear end had to be rebuilt/replaced (thank God I had the 7 year 100,000 mile powertrain warranty because he confirmed that the charge would have been over $2,000). This is what the invoice indicated:
Bearing-differential (1) 5072506AA
Bearing-drive pinion (1) 5017438AA
spacer-drive pinion bearing (1) 3507678
seal-drive pinion (1) 52070340AB
lubricant (2) 4874469
lubricant (1) 4318060AB
sealer (1) 82300234
bearing-drive pinion (1) 5072498AA
differential-differential (1) 5161549AA
Labor - bearings, differential side differential side-bearing-all axle replace (includes case and side gears if necessary)
2002 1500 Quad Cab 4x4
315x70x17 BFG's, Stock Suspension
Air Ram CAI
Flowmaster Delta Series Muffler
Westin Chrome Step Bar
Sony Head Unit
Infinity Kappa 10" Sub with Custom Fiberglass Enclosure Under Left Rear Seat
Rockford Fosgate 150W Amplifier
10" Myron & Davis DVD Screen
rome5982 is offline
post #2 of 5 Old 01-28-2007, 11:49 AM
helo-pilot
helo-pilot's Avatar
Quoted: 2 Post(s)
That's exactly why I changed to an Auburn!!
2004 1500 QC 5.7L
MODS:
268 Cam
SCT Programmer
4.56 Gears
LT Headers
Electric Fan
Caltrac's
And lots of other goodies
helo-pilot is offline
post #3 of 5 Old 01-28-2007, 11:53 AM
bucci
bucci's Avatar
Yep, that's the retaining clips that break and the big half circle piece is what creeps out and rubs the bearing cap. You probably have a big groove in the bearing cap too.
My whole axle assemble was replaced. The dealer didn't do any differential work. They just swapped out the old one with the new one. This way the gears are set up at the factory.
2015 Ram 1500 4x4 Laramie Crew 6' 4"
Brilliant Black Crystal Two Tone; Black Leather; Floor Console
5.7l HEMI; 3.21 LSD
Fold-a-Cover G4 Elite
bucci is offline
post #4 of 5 Old 01-28-2007, 04:09 PM
ce2flaco
sans sanity
ce2flaco's Avatar
It's always been a clutch pack retainer problem, there was never an issue with any "c" clips. Someone initialy mis-spoke and it took off. If you ever get a chance to actually look at the c clips in these rear ends it will be obvious they aren't breaking any time soon.
03 1500
SAS'd, linked, locked
ce2flaco is offline
post #5 of 5 Old 01-28-2007, 06:44 PM
sherdep
voo doo 1 I am buggin out
sherdep's Avatar
Welcome to Dodgetalk and
he is correct .... the "c" clips are what hold the axles in ..... Welcome to the notorious Broken Clip Club http://www.dodgetalk.com/forums/show...oken+clip+club
04 Dodge Ram 1500 4x4
6" Fabtech Lift
305/70/18 Dick Cepek FC-II Tires on DC-1 Rims
Fram Boost CAI
Hellwig Rear sway Bar
Train Horns with a Viar420C and a 5 Gallon Air Tank
Dynatech Long Tube Headers - Great fit but Dynatech's support is lacking
DynoMax Part # 19413 Single Cat Back Exhaust
If you need to contact me - please send me an email due to not being on here as much as I used to.
Some get it and some will never get it
sherdep is offline
    2007 Dodge Ram 1500 RAM MAN Rumor Mill & Gossip Talk 1 11-29-2007 09:54 AM
    04 Durrango just hAd rear end replaced EMF_VIRUS 2G Dodge Durango - Drivetrain Talk 5 03-14-2005 05:06 AM
    04 rear end replaced by dealer EMF_VIRUS 2G Dodge Durango General Talk 2 08-24-2004 07:52 PM
    Help... metal chunks in diff REALM 3G Dodge RAM - Drivetrain Talk 15 01-26-2004 11:56 PM
    2004 Dodge Truck Highlights RAM MAN Rumor Mill & Gossip Talk 0 09-03-2003 05:27 PM
