Very Low Heat Output - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 8 Old 01-18-2007, 07:05 PM Thread Starter
99BLUEDURANGO
My 99 Durango sucks for heat right now. Not sure why. Before I did the intake, water pump, thermostat, it worked excellent. At low speed, it is pretty warm, and med speed. But at med-hi to high, it puts out very little heat. Pretty much luke warm. Not sure why it would do this, since it wasn't that way before the intake gasket/water pump change. It comes up to temp fairly fast, and never gets hot. I did change the thermostat when I did the intake. Twice. I hope it's not the heater core... but I have a feeling it is. I used a NAPA new water pump. That couldn't be preventing it from heating correctly? Could it?
99BLUEDURANGO is offline
post #2 of 8 Old 01-18-2007, 08:45 PM
low pressure
low pressure's Avatar
i had the same problem befoe but didnt bother me til i started going to the mountains again for snowboarding. what i figured was my thermostat, i replaced my stock with a 160* i replaced that with the 190* and i get heat now. good luck
1999 5.9 Magnum
3" body lift
T/S lift
33x12.5x15 BFG's KO
Borla cat back
Autolite 3923
Surco roof rack (home made brackets)
8" Kicker sub w/ MTX amp hooked up to factory head unit
viper fan w/ hayden 3652 controller (less than $200 upgrade)
low pressure is offline
post #3 of 8 Old 01-19-2007, 09:15 AM
RayJay
Ray
RayJay's Avatar
When I flushed my cooling system I also had very little heat. The heater core was partially plugged and the flush kit wasn't getting in there to do its job. Finally used a water hose directly in the heater hose in both directions to get the heater core flushed out. It took about 10 minutes to get the heater core to flush out and flow free.
05 Ram SLT Quad Cab 1500 4x4 5.7 Hemi
Flame Red - de-badged, K&N drop-in
Lund soft tonneau
Sony MEX-1GP GigaPanel stereo
99 Durango SLT 4x4 5.9
Bright Platinum Metallic, K&N drop-in
Hughes plenum plate
RayJay is offline
post #4 of 8 Old 01-19-2007, 09:55 AM
AP
USAF MOPAR MILITARY BRAT
AP's Avatar
Just did mine 3 weeks ago! All same problems you described. Have your heater core checked and possibly flushed. I had mine high pressured flushed and a bunch of white gunk crap came out. It works like a charm now. Also, If you want more heat by yourself. Make sure the center console heat controls are off....if you don't have any back seat passengers.
My first new vehicle: 2003 Dodge Dakota Stampede 4X2 short bed
Graphite Metallic Clear Coat
4.7L. Magnum V8
5-45RFE auto, 3:92 gears anti-slip diff.
Mods: K&N filter, and MBRP performance exhaust,
stainless steel " Cuda Style " dual cat-back with roll
pan with exhaust openings, Jason bed cover, and alot of exterior acessories!NEW JUST ADDED AN AWSOME SHAKER HOOD!!
My second vehicle : 1998 Dodge Durango SLT Plus 4X4
Deep Amethyst Pearl Coat
5.2 L. Magnum SMPI V8
4 speed auto
Mods: none so far.
Previously owned cars:
1) 65 Dodge Polara 4 door 383 ( my first car )
2) 72 Plymouth Golden Duster 318
3) 73 Plymouth Cuda 360 ( my summer toy
4) 75 Plymouth Sport Fury 318
5) 88 Dodge Ram LE 150 318 FI
6) 92 Plymouth Sundance 4 cyl.
AP is offline
post #5 of 8 Old 01-19-2007, 10:38 AM
Volphin
Volphin's Avatar
Lack of coolant
Sounds like an air bubble to me. You have enough coolant? Heater core would be cold all the time if plugged. Burp that puppy. 5.9 and 5.2s are bad for it.
ASE Certified Master Tech, MoTech Class of '85
2001 D+ Platinum
5.9L, 4x4, 46RE, 9.25 Axle w/3:55, Speed Prop Tow Pkg, Kleen Wheels, IP Stage II, 52mm FMTB, PPH Headers with Jet Hot Sterling, Mopar M1, 1.7RRs and Magnum VCs, Smith Bros. Hardened Pushrods, B&G M1 Flash, Go Rhino! Sumatra 3000 Brush Guards, PIAA 580s, Optima Red Top, Mag-Hytec Diff Cover, Mag-Hytec Trans Pan. I'll bore you .060 over if you stroke my crank.
Volphin is offline
post #6 of 8 Old 01-19-2007, 04:51 PM
DurangoDan5.9
DurangoDan5.9
DurangoDan5.9's Avatar
also by using a lower temp. thermostat you will not get as hot of air, because the coolant is cooler now.
2000 Dodge Durango
5.9l (360 ci), 4X4, With 3.92's
T/S lift, W/Belltech 6400 Shackles
Pro Comp Add-A-Leaf
Rancho RSX17000
33x10.50R15 BFG M/T's
Relocated IAT sensor to stock air box
K&N Drop in filter
Flowmaster Super 40
Magnaflow Hi-Flow Catalytic Converter
Synthetic front to back
Polk Audio db650 (all 4)
Pioneer Deh-P7500mp
Next on the list
Cold air intake
Off road lights
DurangoDan5.9 is offline
post #7 of 8 Old 01-19-2007, 09:33 PM
!05RAM05!
Previously Micash21
!05RAM05!'s Avatar
put the original temp thermostat back in.
New: 2005 Dodge Ram 1500 QCSB 4x4 Hemi Laramie Bright Silver
Flowmaster SI/DO 40 Series. Superchips 3865 - 91 Tune, 2/4 drop, More to come............
::GONE BUT NOT FORGOTTEN::2005 Dodge Ram 1500 QCSB 4x4 Hemi Sport Black
5.5" Rough Country Lift, Dick Cepek DC2 20x9, 325/60R20 Nitto Terra Grappler's, Superchips 3865 - 91 Tune, Extang Tonneau Cover, K&N Cold Air Intake, Bosch Platinum 4 plugs, Magnaflow Y-Pipe, SI/DO Flowmaster Original 40 Series, Synthetic Everything, 7000K Headlights, Foglights and Hellas..
1998 Dodge Durango SLT 4x4 Black
Hypertech 87 Tune, K&N Cold Air Intake, Bosch Platinum 4 plugs, Bosch 8.5mm Wires. Ported Throttle Body, SI/DO Flowmaster Original 40 Series Muffler, Headman Headers, 3" PA BL, 2" T/S Lift, 33x12.50R15 Firestone Destination M/T's, 15x8 Eagle Alloy Wheels.
BTC Member 211 - Steel Reserve
!05RAM05! is offline
post #8 of 8 Old 01-19-2007, 10:02 PM
Volphin
Volphin's Avatar
Nope.
The stat is not the problem. Stock is 195. 15 degrees won't make or break the system. My 180 will run you out of the cab it gets so hot. Thats because the stat helps regulate temerature but the setting is when the stat opens, not what the operating temps of the engine will be.
2001 D+ Platinum
Volphin is offline
    Check engine light is on and D is missing bad StressboyD 1G Dodge Durango General Talk 11 06-22-2006 07:29 PM
    HELP!!! Code P0132 SHADOW QUAD CAB 2G Dodge Dakota General Talk 4 04-30-2005 09:00 PM
    Autolite 3923 Plugs BigJohn82 1G Dodge Durango Performance Talk 13 08-20-2004 09:20 AM
    Spark Plug Time!! Need Help!! LurcH 1G Dodge Durango Performance Talk 15 08-15-2003 08:02 AM
