Dipstick tube to transmission seal - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 01-12-2007, 03:16 PM Thread Starter
B-300
4 Wheel Power Disc Brakes
How did the factory seal the dipstick tube to the transmission without an O-ring. I am installing a transmission that I rebuilt and installed a Superior shift correction kit . The dipstick tube is rounded over at the end and doesn't have the spot for an O-ring.
It's a '90 B-250 with an A-500 (42rh). It appears that it was siliconed in before. This seems incorrect. Does anyone know if this is the way the factory did it... It seems cheesy to me.
--B-300--
B-300 is offline
post #2 of 9 Old 01-12-2007, 09:21 PM
van-nut
'98 B2500 Ram Cargo Van
van-nut's Avatar
Quoted: 9 Post(s)
No way would the factory use silicone. I fixed a leak at that point on my '98 w/46RE and there was a rubber seal there, but it wasn't just a simple 'o'-ring, it was a purpose made part. Why they didn't just use an 'o'-ring I don't know, but this "seal" pressed into the trans housing and the tube pressed into it. I don't remember needing any special tools to install it. The tube on mine had one ridge or bump on it about an inch up from the end. Not sure if yours is similar or not, but give your dealer a call and I'm sure he can tell you what is suppost to be there.
Pete
Experience is something you don't get until just after you need it - Steven Wright
van-nut is offline
post #3 of 9 Old 01-13-2007, 05:21 PM Thread Starter
B-300
Pete,
Thanks for the info. The rebuild kit came with a seal similar to what you described. I will try that tomorrow whe I finish the installation.
--B-300--
B-300 is offline
post #4 of 9 Old 01-13-2007, 09:22 PM
Chump
Chump's Avatar
FYI-my factory parts books show the O-ring in 1990 and not until 1996 did the seal part# change. Let us know how you make out.
Chump is offline
post #5 of 9 Old 01-15-2007, 05:10 PM Thread Starter
B-300
Chump,
You want to know "how I made out".
Well it turns out the dipstick tube was broken off. It's thin on the late vans, I guess to save weight and material.
I found one at a pick-n-pull off a 904 series tranny that has the correct mount strap. (727has a different length strap)
Transmission works excellent with a shift kit.
A note for those with leaks in this area, the tube is thin and may start leaking if it cracks at the O-ring groove.
--B-300--
B-300 is offline
post #6 of 9 Old 01-16-2007, 10:46 AM
Dodgevanman
Do It In A Van
Dodgevanman's Avatar
I was gonna say, all the Mopar tranny dipsticks that I've dealt with had the dimple for an o-ring.
Glad you found it was broke...was it a pain to get the busted piece out?
Nate Breece
5.2L Magnum
2008 Grand Caravan SXT
3.8L
Member of:
Dodgevanman is offline
post #7 of 9 Old 01-16-2007, 12:19 PM Thread Starter
B-300
There was no busted piece in the old case that had cracked due to lack of engine transmission braces...It had been silconed in. This is what thru a curve ball into the equation.
--B-300--
B-300 is offline
post #8 of 9 Old 01-19-2007, 04:54 AM
Chump
Chump's Avatar
Thx...I was curious because I know the o-ring has been around for a thousand years!
Chump is offline
post #9 of 9 Old 01-19-2007, 01:03 PM Thread Starter
B-300
Yep I was looking for an O-ring on the old tube which had broken off at the spot the ring should have been in, hence there was no other piece of the tube. This is the tube, without it's end had been silconed in. It has been replaced, using an O-ring.
If Ihad looked at my Transtar book in the parts listing I would of found the same thing about O-ring vs funny looking seal.
Enough of this already?
--B-300--
B-300 is offline
    Pinion seal....maybe TREP R/T 3G Dodge RAM - Drivetrain Talk 2 08-08-2006 05:43 AM
    Rear Main Seal Dman98 1G Dodge Durango General Talk 2 08-07-2006 05:49 PM
    Dana 60 front end......outter SEAL help 99RAMMAGK 2G Dodge RAM - Drivetrain Talk 3 11-07-2005 11:14 AM
    Hemi intake! Tube & filter or just tube? Ram4Pick 3G Dodge Ram Performance Talk 6 03-17-2004 06:27 PM
