Dually Dana 80 into SRW 2500 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 4 Old 01-11-2007, 09:57 AM Thread Starter
kas83
I've been looking into regearing my truck to 4.10s, and came across a screaming deal. I wanted to do a set of 4.10s and limited slip, and got quotes of about $700 for parts and labor. While talking with a buddy, he brought up the fact that his dad has an 02 Ram 3500 that was wrecked, and he's parting it out. It's a Dana 80, 4.10 with Trac Lock, and has roughly 120k miles. This is one heavy duty rear end let me tell you, and I know I don't need that much strength. After some quick negotiating, price would be $650. Obviously this would require some grunt work on my part. But for the money, do you think it's worth it? I will not buy the axle to resell it, only to install, so if it turns out to be a no go for my truck, they will keep it, that's just the way I am. Thanks in advance.
97 Ram 2500 CTD Ext Cab LB, 4x4, 5 speed, 3.55s
#100 plate, ISSPRO pyrometer/50 psi boost gauge, AFE Stage 2 Pro Dry, Valair Con OFE, DDP 2's, 15* timing, HTT Manifold, B-1 turbo
95 Ram 2500 CTD Ext Cab LB, 4x4, Auto, 3.55's
#6 plate, DDP 1's, BHAF
kas83 is offline
post #2 of 4 Old 01-13-2007, 06:57 PM
99sliverram
99sliverram's Avatar
Well it sounds like a great price for a dana 80 rear. But the things needed to swap it into a 1/2 ton might add up quick though. Things like the switch to eight lug wheels and new tires on the rear from your 5 lug wheels. The spring pads on the dana 80 being for 2 inch wide springs will be a problem to match up with the 1 1/2 wide springs on the 1/2 trucks. Then there is the brakes as far as what would be need to hook up the lines,cables,etc. You might also need at least a new u joint to match up the existing driveshaft to the new dana 80 pinion. You should also rebuild the trac lock in the dana 80 while you have it out and easy to get at the clutches since they wear out rather quickly and with a lot of miles. And last but not least you will still need to get the front dana 44 swaped to 4:10's so you can still use your 4 wheel drive. I'm sure I have missed a few things still needed to do this swap but it at least gives you a small idea? You might consider looking for a front dana 60 from 3/4 ton 4x4 and switch both at the same time and change the wheels also to 8 lug all around.
Formerly 2000redram
FORMER Member #93 of "The Red Truck Club"
I no longer have the truck. Time for new name
1999 Dodge Ram 1500 SLT 4x4 quad cab Driftwood/(sliver) metallic, leather int Member #180 Sliver truck club
3:92 gears
3" lift
285/75/16 all terrains
Randy Ellis light bar with 4 KC daylighters
94 -96 NEW in box Mopar Ram electronic ignition switch for sale $20 shipped to the lower 48.
Future mods
Exhaust
315/75/16 tires
Trucks and guns member #47
69 Charger R/T "General Lee replica"
440 .030 over
ported heads
10 to 1 comp
flowmaster exh
727 torqueflite w/ 2500 stall
4:10 geared Dana 60 with detroit locker
Not track tested yet. "weekend driver"
99sliverram is offline
post #3 of 4 Old 01-14-2007, 08:28 AM Thread Starter
kas83
UMM, my truck is a 2500, 3/4 ton pickup with eight lugs. I know the Dana 80 came in trucks equipped with CTD's and V10's with the 5 speed, but that's the SRW version. I'm wondering how it would be bolting up the DRW version, if those frames were thinner, spring pad width, and how far the single tires would stick out.
And I have the front Dana 60 out of an 01 with 4.10's.
kas83 is offline
post #4 of 4 Old 01-15-2007, 08:52 PM
99sliverram
Disregard didn't see your sig! Thanks for the by the way!
Formerly 2000redram
3:92 gears
3" lift
Future mods
Exhaust
315/75/16 tires
440 .030 over
ported heads
10 to 1 comp
flowmaster exh
    Can a 06 2500 be transformed into a dually? kmu 3G Dodge RAM Diesel Talk 9 08-16-2006 05:59 AM
    Converting Dually to SRW? mocho 2G Dodge RAM - General Talk 12 06-25-2006 09:58 PM
    All-New 2006 Dodge Ram Mega Cab Dually FreeLantz Rumor Mill & Gossip Talk 18 01-31-2006 10:59 PM
    2500 dually conversion? kstompaint 3G Dodge RAM - 4X4 Talk 6 10-30-2005 10:50 AM
    2001 2500 4x4 dana 60 locking 17pointer 2G Dodge RAM - Drivetrain Talk 1 06-17-2005 09:24 AM
