hemi block heater install - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 25 Old 01-10-2007, 08:36 AM Thread Starter
05hemiram
05hemiram's Avatar
Hi, has anyone out here installed a block heater in their hemi themselves? Is it hard to do? Thanks
Current Mopar- '05 1500 4x4 QC LB SLT HEMI 5SPD AUTO 3.92LSD REAR
Previous Mopars- '75 Charger, '76 Aspen, '75 Dart, '83 Power Ram, '89 Plymouth Reliant, '92 Dodge Spirit MOPAR OR NO CAR BABY!
*Longbed Truck Club Member #5*
*Light Almond Pearl Club Member #10*
Nathan
05hemiram is offline
post #2 of 25 Old 01-10-2007, 09:16 AM
waldershrek
waldershrek's Avatar
How cold does it get there in Montana?
01 Ram 2500 QC Cummins
Public Servants Club member #28
waldershrek is offline
post #3 of 25 Old 01-10-2007, 09:34 AM Thread Starter
05hemiram
05hemiram's Avatar
Can get -30 or colder depending on the winter.
Nathan
post #4 of 25 Old 01-10-2007, 11:33 AM
exdecuk
exdecuk's Avatar
Regardless on which engine you put it in all you are doing is knocking out a core plug (freeze plug) inserting the new one of the correct size ensuring the correct orientation of the heating element & tightening the centre fixing, routing the cable & thats it, finished.
Both of mine have them as standard (good old Canadian build) but I bought another for my other engine I am building. Its not just a matter of how cold it gets, even just down to freezing I put mine on. I get in first thing & I am blowing warm air moments after starting which is great for clearing the screen plus it wont do your battery any harm either.
Black Truck Club
Member #222
5.9 Gassers Club Member #4
To join the Official Dodgetalk Member Map, click
exdecuk is offline
post #5 of 25 Old 01-10-2007, 12:02 PM
mopar fan
mopar fan's Avatar
Isn't there one that splices into a heater hose?
Name's
AL
Proud Member of the Original WCPW Club
If you don't stand behind our troops, PLEASE feel free to stand in front of them.
Official Dodgetalk Facebook Page:
mopar fan is offline
post #6 of 25 Old 01-10-2007, 12:20 PM
exdecuk
exdecuk's Avatar
You can get them spliced into the heater hose, down the dip stick, attatched to the outside of the oil pan etc etc.
Black Truck Club
Member #222
exdecuk is offline
post #7 of 25 Old 01-10-2007, 05:09 PM
m37boblee
Armed QC
I just looked at mine ('05 hemi) and can't see any freeze plugs in the block! are they there, where?
Trucks & Guns Club Member #24
Military Trucks Club # 13
2005 Dodge Magnum R/T
m37boblee is offline
post #8 of 25 Old 01-10-2007, 05:17 PM
04Ram2500Hemi
Same Name, Different Game
04Ram2500Hemi's Avatar
Quoted: 29 Post(s)
I know this is a little off topic but welcome to the site. Where in Montana are you from?
Truxedo Deuce Bed Cover with Bed Lights, Black Line-X Rocker Panel, Custom Built Rock Rails Sprayed with Line-X, Front & Rear Bumper and Grill sprayed with Line-X, Husky Mud Flaps, Husky Floor Mats, Four VisionX Xmitter Low Pro Prime XP LED Light Bars Behind the Grill, LED Lights Mounted in the Rear Bumper, Heated Seats, Interior LED Lighting, NAV-TV, Camera Mounted in Front Grill, Custom Headache Rack, AEV Raised Air Intake, 285/75/17 Toyo A/T II Tires
Gone But Never Forgotten!
2004 Ram 2500 4X4 SLT Quad Cab Hemi Silver Metallic, Black Line-X Rocker Panel, Westin Nerf Bars Sprayed with Line-X, Bushwacker Extend A Fender Sprayed with Line-X, Rhino Lining in the Bed and Over the Rails, Truxedo Low Profile Tonneau Cover, Hell 500's Behind the Grill, Warn Front Receiver, KC Backup Lights, Custom Mounted Bumper Backup Lights, V-7 V Force Muffler, Auto Meter Transmission Temperature Gauge, SRT-10 Pillar Grab Handle, Kore Recon Suspension System, Kore Race Steering Damper, Kore Chase Control Arms, Kore Coil Spring Isolator, Kore End Links, 35x12.50 Mud Terrain SXT Tires, SRT-10 Hood, AEM Brute Force Intake, Wet Okole Seat Covers, Smoked Recon Cab Lights, Tuff Stuff 12,500 Pound Multi Point Winch
04Ram2500Hemi is offline
post #9 of 25 Old 01-10-2007, 05:25 PM Thread Starter
05hemiram
05hemiram's Avatar
I'm from billings, I spoke with the dealer today. I guess there is a port in the block by the starter to put a heater into. I guess you have to loosen the starter up and move it out of the way to put in the heater, it is not a wet port. Doesnt sound to hard, I'm gonna give it a shot tonight, will let you all know how it goes when done. By the way there are no freeze plugs in the hemi block.
Nathan
post #10 of 25 Old 01-10-2007, 08:02 PM
waldershrek
No freeze plugs eh? I would have never guessed. Good luck with the install and make sure you post some pics when you're done!
post #11 of 25 Old 01-10-2007, 08:32 PM
rickey p
let me go check my ,my was done from the factory,and ill get back
rickey p is offline
post #12 of 25 Old 01-10-2007, 10:42 PM
STL HEMI
I installed one in mine. The Insert hole is on the drivers side of the motor. Their is nothing to knock out. The kit comes with the wire and element. Easy install plus the directions It's down low close to the back side of the block.
STL HEMI is offline
post #13 of 25 Old 01-11-2007, 12:54 AM
rickey p
hey stl i saw it was on the drive side ,did you put it in the center or tore the rear of motor, i just cant see for where is was
rickey p is offline
post #14 of 25 Old 01-11-2007, 02:03 PM
STL HEMI
It's alittle hidden. I did this awhile ago. Let me crawle under the rig real fast.
STL HEMI is offline
post #15 of 25 Old 01-11-2007, 02:08 PM
STL HEMI
OK the hole is right above the starter. Look at the end of the manifold log and it right across from their. I did have to drop one bolt from the starter and rotate it to put the element in but one in the starter goes back in place. Whole job including beer time was 30 minutes.
STL doesn't get bad winters but with the rig outside and not in a polbarn when it dips into the teens or single digit's I don't wanna freeze my ass off wating for the truck to warm up as I role down the road. We don't let our vehical's warm up before we leave.
STL HEMI is offline
post #16 of 25 Old 01-11-2007, 02:41 PM
dale3fan3
How much do these run? Also can you post a picture of where its installed?
dale3fan3 is offline
post #17 of 25 Old 01-11-2007, 02:58 PM
Mad Hemi
Mad Hemi's Avatar
For '05s and up . . . http://www.autotrucktoys.com/ram/OEM...9696C3097.aspx
"From Knowledge springs Power, just as Weakness stems from Ignorance."
Hi! My name is Steve!
2004 QC Hemi Ram - 14.74 @ 91.71 / 9.477 @ 75.09 mph - SOLD!
2008 Hemi Charger - 13.86 @ 99.72
Mad Hemi is offline
post #18 of 25 Old 01-11-2007, 03:01 PM
dale3fan3
do they make one for a 04 hemi?
post #19 of 25 Old 01-11-2007, 03:24 PM
Yellow04Hemi
Yellow04Hemi's Avatar
STL HEMI's is an 04 so maybe he can chime in with where he got his. It does get cold in StL but luckily mine is garaged. Still takes a few minutes to get the heat rolling. I wonder how much power the block heater consumes per hour? Might be worth it to improve gas mileage in the mornings of really cold nights.
Yellow Truck Club - #1
2004 Solar Yellow Dodge Ram 1500 QC Hemi Sport
Yellow04Hemi is offline
post #20 of 25 Old 01-11-2007, 04:40 PM Thread Starter
05hemiram
05hemiram's Avatar
Allright got my block heater put in last night, sorry I'm not very high tech and don't have the ability to post pics, but like stl hemi says it is very easy to do. The port in the block is right above the starter. I actually removed th starter just for a little more clearance, the hardest part is routing the wire. I got my block heater kit from local dodge dealer parts department. $62.00
Nathan
    Use this heater hose for flush kit tee install location ? Thanks....David RamVanMan Dodge B-Series Vans 1971 - 2003 17 09-11-2006 12:03 PM
    Block Heater bbodyguy 2G Dodge Durango General Talk 6 02-28-2006 01:14 PM
    Nerf Bars And Block Heater For 05 Ram 2500 DAVE W 3G Dodge RAM - General Talk 0 09-01-2005 10:04 AM
