Oxygen sensor Bank 2 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 11 Old 01-05-2007, 06:54 PM Thread Starter
bigswol2
Can anyone tell me which one this is. I have a 97 1500 4x4 with a 318. Is this the one before or after the cat.
Thanks in advance.
bigswol2 is offline
post #2 of 11 Old 01-05-2007, 07:15 PM
2k1DurangoR/T
Jason
2k1DurangoR/T's Avatar
Do you have 2 O2 sensors? Cause 97 is OBD-I with only one O2 sensor.
07 Charger R/T 5.7
01 Durango R/T 5.9 - Sold
98 Ram 1500 5.2 Auto CCSB 2wd - Sold
95 Ram 1500 5.2 Auto RCSB 4wd
President*
2k1DurangoR/T is offline
post #3 of 11 Old 01-05-2007, 10:28 PM
B-Rad!
I'm a little confused here, but are you saying that in 1997, they weren't the newer OBD-II? Cause I have read mine with an OBD-II checker several times. But I just might be confused as to what you meant by it.
B-Rad! is offline
post #4 of 11 Old 01-05-2007, 11:24 PM
2k1DurangoR/T
Jason
My Haynes manual says '94-'97 are OBD-I.
07 Charger R/T 5.7
President*
post #5 of 11 Old 01-05-2007, 11:42 PM
B-Rad!
Hmmm...well, maybe they changed it late in 97, cause mine is at the tail end of the 97 model year, about the last month or 2 of production. But it definitely has an OBD-II plug to check the engine light.
B-Rad! is offline
post #6 of 11 Old 01-06-2007, 12:11 AM
2k1DurangoR/T
Jason
Prolly so...
07 Charger R/T 5.7
President*
post #7 of 11 Old 01-06-2007, 09:14 AM
CaptainCummins
CaptainCummins's Avatar
I am unfamiliar with these engines, but a 96 and up is OBD-II. Bank 2 would be the O2 sesor in the right exhaust manifold. Bank 1 would be left exhaust manifold. If there is only 2 O2 Sensors, there is Only 1 bank. You should have at least 3 o2 sensors
2000 3500, ISB, NV4500, 4x4, Quad Cab, DRW, Silver, 8 psi low fuel pressure light, Pioneer Head Unit, Sylvania Silverstars, Carter 4601 and Vulcan Bigline Kit on the Workbench, will go on soon
CaptainCummins is offline
post #8 of 11 Old 01-06-2007, 12:57 PM
2k1DurangoR/T
Jason
Ok, the Haynes manual says that 94-97 is OBD-I, then in the next chapter it says 96 and later is OBD-II. How retarded! OBD-II . com says 96 and later and if you have the plug, it's OBD-II. So, what you need to do is look to see how many you have. Start at the manifolds and go down to the cat. My 95 only has one.
07 Charger R/T 5.7
President*
post #9 of 11 Old 01-06-2007, 01:42 PM
Dave3825
Dave3825's Avatar
There are OBDI and OBD-II Plugs
My scanner will scan OBDI and OBD-II...
Heres my scanner
2001 Dodge Ram 1500 5.9 8 ' bed
34000 Front u joint blows apart $20.00
38000 Lights blow out on radio Got Kenwood
39000 Tailgate cable snaps $8.00
40000 Ignition wire in column breaks $2.00
42000 Auto window rolldown stops working not fixed
51000 Power steering pump blows $35.00
52000 Multifunction switch blows $87.00
54000 Overdrive in tranny blows $1200.00
60000 Gas steady @ 3.13 a gallon
60106 Plenum repair
61380 Master cyclinder 140.00 (dealer)
61398 Gas down to 2.99
80000 steering box fails
100232 2nd trans dies
100102 ac clutch bearing failed
123256 Fuel pump fails
124562 2nd steering box failed
Dave3825 is offline
post #10 of 11 Old 01-06-2007, 03:40 PM
MAGICDSSMAN
Some of the 96's were obd1. All the 97's are obd2. My 97 was built in feb of 97 and it is obd2. You should only have 2 o2 sensors one before the cat and one after. THe only o2 codes you should get are bank1 sensor 1 and bank1 sensor 2. The 1st sensor is just that the one closest to the engine. This sensor monitors and changes the A/F ratio. The 2nd sensor does nothing more than watch to make sure your cat is functioning and does not do anything else.
MAGICDSSMAN is offline
post #11 of 11 Old 01-08-2007, 01:36 PM
Grantman31
Truck Sold :(
Grantman31's Avatar
My '96 is OBDII...2 sensors, 1 precat 1 postcat.
Current Vehicle:
Silver 2008 Nissan Altima 3.5 SE
Gone but not forgotten:
1996 Dodge Ram 1500 4x4
Sport SLT Laramie Club Cab
5.2L 318 V8
White w/Black trim
90k Miles
Nitto Terra Grappler AT LT265/75R16
Mods:
Flowmaster 40 Series Muffler - Dual Exhaust w/Chrome 4" tips.
Hughes Plenum Reinforcement Kit
Hypertech 180* Thermostat
K&N Drop in
*DodgeTalk.com 318 Enthusiast Member #(78)*
Originally Posted by BleedDodge
Why not just inject some fake oxygen into the pipes instead of getting fake sensors? Problem solved.
Grantman31 is offline
    Check engine light is on and D is missing bad StressboyD 1G Dodge Durango General Talk 11 06-22-2006 08:29 PM
    1998 Caravan wont stay running JMDTOYS Dodge Caravan General Talk 3 05-05-2006 11:57 AM
    Code P0203-HELP rudegirl 1G Dodge Durango General Talk 3 03-31-2005 01:07 PM
    00-02 Codes dvgRT Dodge Neon - General Talk 0 06-13-2004 02:25 PM
