1991 b250 steering - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 10 Old 12-31-2006, 09:03 PM Thread Starter
wally527
91 b250
wally527's Avatar
1991 b250 steering
i know ur gonna say check the coupling but it seems fine is the steering box adjustable
1991 b250 omnicraft conversion
needs paint been set up awhile
1999 mustang gt 35th anni. edition
01 gt motor
wally527 is offline
post #2 of 10 Old 01-01-2007, 03:25 PM
Dodgevanman
Do It In A Van
Dodgevanman's Avatar
Yes the box is adjustable. Make sure everything on the front end is up to par first. The coupler may seem to be fine, but the slightest bit of play will show up in the wheel.
Nate Breece
5.2L Magnum
2008 Grand Caravan SXT
3.8L
Member of:
Dodgevanman is offline
post #3 of 10 Old 01-08-2007, 01:11 PM Thread Starter
wally527
91 b250
wally527's Avatar
well another weekend lost to working on van but its better i think vacuume problems solved running smoother but the new pcv valve rattles a bit too much as far as steering box i looked but did not touch it appers that the backlash needs adjustment when the wheel is turned till it just starts catching i can see input shaft raise up about a 32nd if u know when i could get a print whith some specs i would really be grateful
i v read some of ur [post sounds like u know what going on
thanks for ur input
wally
01 gt motor
wally527 is offline
post #4 of 10 Old 01-09-2007, 05:59 AM
Dodgevanman
Do It In A Van
Hmmmmmm. The steering box itself could be the problem. I'll see if I can find any specs. for you.
Nate Breece
5.2L Magnum
3.8L
Member of:
post #5 of 10 Old 01-09-2007, 09:39 PM
B-300
4 Wheel Power Disc Brakes
The input shaft should move up and down slighty as described. It operates the "spool valve" inside the steering box, which channels fluid to the left or right side boost depending on the direction the wheel is turned.
If a recall correctly the adjustment procedure is: Loosen locknut a turn or two, start engine and tighten adjuster to take-up slack when (wheels straight ahead) turning the input shaft at the coupler, then tighten the adjuster 2 more turns and tighten the lock-nut.
If it's still sloppy the internals of the box are worn.
--B-300--
B-300 is offline
post #6 of 10 Old 01-12-2007, 09:41 PM Thread Starter
wally527
91 b250
wally527's Avatar
no luck on steer box specs well now that im unemployed for amwhile steer box is coming off after this weather this weekend is heck on a windy day
wish me luck im gonna do the coupling just because and dealer said $14 and recomendations for shocks or just stock ?
got to help
01 gt motor
wally527 is offline
post #7 of 10 Old 01-13-2007, 11:14 PM
Chump
Chump's Avatar
If you pull the box you might as well do the input shaft seal and the pitman arm shaft seal.
Chump is offline
post #8 of 10 Old 01-14-2007, 01:08 AM
B-300
OK, I guess i was wrong on the preload. I must have been thinking about transmission band adjustment. I believe Chump is correct so follow his post.
--B-300--
B-300 is offline
post #9 of 10 Old 01-14-2007, 01:14 AM
Chump
Chump's Avatar
--B-300--
B-300..I was a bit surprised to see this adj sequence pop up but from what I see the vans used a Chrysler box from 88-92 instead of a Saginaw box?
Chump is offline
post #10 of 10 Old 01-14-2007, 05:48 AM Thread Starter
wally527
91 b250
wally527's Avatar
Thumbs up
hey guys i really appreciate the help
oh yea seals are a given alone with a set of shocks and redo steering coupler
it was alittle windy here the other day alittle squirlley
where do u guys find this info i looked for days online
thanks again got a mission now
01 gt motor
wally527 is offline
    steering coupler B250 Van jcole Dodge B-Series Vans 1971 - 2003 32 06-02-2007 04:00 AM
    dodge van b250 5.2L 318 1991 jhon58 Dodge B-Series Vans 1971 - 2003 0 09-22-2006 01:11 PM
    Steering shaft question on 2500 CTD??? tomcat#1 3G Dodge RAM Diesel Talk 0 08-18-2006 10:22 PM
    Steering Stabilizer JordanKeck 1G Dodge Durango - Tire/Wheel/Susp Talk 7 07-19-2006 07:27 AM
    94 B250 Steering Coupler Mike Hayes Dodge B-Series Vans 1971 - 2003 2 08-03-2005 12:08 PM
