how to keep rain out of exhaust stacks - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 15 Old 11-30-2006, 06:31 PM Thread Starter
adv85
adv85's Avatar
hi i was wondering if anybody has any suggestions on how to keep rain out of mitre cut (stacks with an angled cut top) exhaust stacks thanks
2001 Navy Blue Dodge 2500 Cummins Diesel 2X4 Quad Cab Laramie, w/o Silencer Ring, Edge EZ, BHAF and Aluminum Heat Shield, 4in TurboBack MBRP Exhaust into 5in Dual Mitre Cut Stacks, bought with 48k miles on it.
2005 Gold Dodge 3500 Cummins diesel 4X4 Quad Cab Laramie, Leveling Kit, 22in Chrome Rims, w/o Silencer Ring, BHAF with AFE Torque Tube, Banks High Ram Intake Manifold, Smarty Programmer, 4in TurboBack Grand Rock Exhaust into 5in Dual Aussie Stacks, bought with 40k miles on it, pics to come
adv85 is offline
post #2 of 15 Old 11-30-2006, 09:08 PM
Tires
A guy here in town puts rubber boots over his when he's parked. During the periods when the truck is turn on, i dont think you would have much of a problem since the stacks should be pushing air out.
Daily:
1997 Dodge Ram 1500, SLT Laramie.
33's
Fully Straight piped.
Cobra CB and dual 4ft whips.
Toy:
2001 Honda rancher 350.
4x4
2000lb warn.
Tires is offline
post #3 of 15 Old 11-30-2006, 09:09 PM
StarDriver
Rain caps or coffee cans.
1995 RAM 3500, 2WD, Banks Powerpak system, Southern Diesel Truck parts custom cut torque plate, ATS trans and Triple disc torque converter,Westen Grille guard, Putco Stainless Running boards, Leer custom topper, custom sound system, Whelen Strobe lights.
1993 Dodge Dakota,318, auto, custom paint, Flowmaster exhaust, former Mark III conversion, Pace Setter shorty headers, Airaid intake spacer, Mopar Performance PCM, Flowmaster exhaust.
StarDriver is offline
post #4 of 15 Old 11-30-2006, 09:49 PM
crazys182003
Quoted: 5 Post(s)
I've heard of people drilling a small hole at the bottom to drain out the water.
crazys182003 is offline
post #5 of 15 Old 12-01-2006, 11:00 PM Thread Starter
adv85
adv85's Avatar
thanks guys for the tips
adv85 is offline
post #6 of 15 Old 12-03-2006, 03:04 AM
codyboy
http://www.hankstruckpictures.com/pi...s/file0003.jpg
check that out. Try getting the little lid type things that are on the top of old semi stacks. Not the best pic but hopefully you get the idea
2010 Dodge Ram 1500 Sport 4x4 Hemi
codyboy is offline
post #7 of 15 Old 12-03-2006, 02:44 PM
Cummins4ever
Cummins4ever's Avatar
either rain caps or drill a small hole in the bottom of them
My trucks
2012 2500 6.7 Cummins Laramie Longhorn H&S tuned with 5" TBE
1997 2500 12v Cummins 5 speed, 0 Plate, Tuned AFC, Gauges, Bradford Built Flat Bed
Cummins4ever is offline
post #8 of 15 Old 12-03-2006, 06:39 PM
Dodge2500
DodgeRamOhio
Dodge2500's Avatar
their miter cut stacks not flat tops so the flappers wouldnt realy function right when the trucks running because they wouldnt open properly all though they would keep the rain out i dont think you would like the overall look after putting them on and i have rain flat tops and miters with the rain the water all comes out when you fire your truck up and i havent had in problems with rust or anything and my father in law ran miters on his kenworth for years with out covering them and he never had any problems hes now running 8 inch miters on his truck and i got his 5 inch miters for helping him.
DODGE MAKES IT CUMMINS SHAKES IT
1998 Dodge Ram 2500 4x4 with a 12 valve Cummins turbo diesel.
AFC housing, torque plate, and star wheel full forward.
BHAF installed.
KDP done.
5 spd trans.
4 inch turbo down pipe from Jardine. $ 75.00 on ebay
5 inch exhaust from the down pipe to the transfer box thats 6x6 steel to a pair of 5 inch stacks, turnouts,miter cuts,or flat tops with flappers just depends on which ones i want to run.
8 LED lights in lower air dam, LED lights in tool box 18 total in box. installed Cab lights with LEDs. nexlight LEd on pinch mold. LED light bar under tailgate.
custom sub boxes joined with an amprack and green neons two 12 inch audiobahn subs. 1000 watt lanzar vibe amp.
Gauges ISSPRO Pyrometer, Boost, fuel pressure.
wish list
cb in overhead console, bigger turbo, bigger injectors, new clutch, step bars, air horns, diamond plate bed cover, and more.....
Green Truck Club Member #8
Dodge2500 is offline
post #9 of 15 Old 12-04-2006, 02:43 PM Thread Starter
adv85
adv85's Avatar
thanks i was most worried about them rusten out but if all the water comes out when i start it then the heat of the exhaust should dry up all the moisture anyways makes sense. thanks guys. hopefully this tuesday my buddy will be able to help me install them. i will post pics once they are installed. thanks again
adv85 is offline
post #10 of 15 Old 12-04-2006, 03:33 PM
hotrod_06010
the only problem I have ever seen from not capping your pipes, is if your truck creates alot of black smoke. The soot coats the inside of the pipe, add a little water, and on start up you have soot all over the roof of your truck, had a pete do that all the time.
hotrod_06010 is offline
post #11 of 15 Old 12-04-2006, 06:07 PM
Dodge2500
DodgeRamOhio
Dodge2500's Avatar
thats what they make carwashes for and if your running miter cuts its not that bad and i wash my truck 2 to 3 times a week and with the curved tops they soot very little because theirs not that much water getting into the pipes.
BHAF installed.
KDP done.
5 spd trans.
wish list
post #12 of 15 Old 12-04-2006, 06:49 PM
Cummins4ever
when the trucks runnin its not a problem so put like a coffee can or a cup or sumthin over them
My trucks
post #13 of 15 Old 12-11-2006, 12:50 PM Thread Starter
adv85
adv85's Avatar
i have pics now of my exhaust stacks
adv85 is offline
post #14 of 15 Old 12-12-2006, 06:11 PM
Dodge2500
DodgeRamOhio
Dodge2500's Avatar
looks good adv85 i bet it sounds great to.
BHAF installed.
KDP done.
5 spd trans.
wish list
post #15 of 15 Old 12-14-2006, 05:29 PM Thread Starter
adv85
adv85's Avatar
thanks, its sounds great i haven't had the radio on since i have put them in, i love it
adv85 is offline
    Error code P 0308 Ironhorce 3G Dodge RAM - General Talk 15 11-22-2008 05:41 AM
    Michigan to try and BAN aftermarket Exhaust RAM MAN East North Central 12 04-19-2007 11:37 PM
    Anyone know where I can find out what this code means? Bagged02 3G Dodge RAM - Drivetrain Talk 12 07-19-2006 06:38 PM
    bore stroke and cam lift of 318 magnum?? blaizinram 2G Dodge Ram Performance Talk 4 06-18-2006 12:52 AM
    Full Exhaust fitment. Alterocks 2G Dodge Dakota Performance Talk 1 01-17-2006 07:15 PM
