1998 Neon Interference Engine? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 11-29-2006, 06:18 PM Thread Starter
Rick99
I'm looking a potential good deal on a 98 with a broken timing belt. Does anyone know if this has an interference engine? (obviously that makes a big difference as to whether its a good deal or not).
If there is more than one engine for that year, please let me know. I'm not sure what this has.
2003 Durango SLT
AWD, 4.7l
Mods: Remote Start
Just got a new set of BFG All-Terrains
Planning retrofit to 4WABS
1999 Durango SLT+
4x4, 5.2l
Mods: B&M Supercooler, Ford OEM Remote Start/Keyless Entry/Alarm, Heated Seats
01 T&C Limited 3.8l
Rick99 is offline
post #2 of 6 Old 11-29-2006, 10:20 PM
HoodooGuru
HoodooGuru
Yep sure is.
Probably some bent valves in that puppy.
2001 Chrysler Neon SE.
Performance Mods:
Pedders Sports Ryder Lowered springs, CSA "Velocity" 15 inch alloy wheels & Toyo T1R-D low profile tyres, 2.5 inch cat back Lukey Turboflow exhaust, Highflow cat, Comp 200 Grind Camshaft, Race Spec P & P Cylinder Head with 3 Angle Valve Job & Decked 20 thou, Universal Polished Chrome Oil Catch Can connected to pcv valve, MPX 60mm polished aluminium throttlebody, Cold air intake, Cquence Motorsport Cross Drilled / Slotted Front Brake Rotors, Racing pod air filter, Quick / short shifter, Custom mid / long tube headers, Megan Racing underdrive pulley, Top Gun 8.0 high temp spark plug cables, NGK spark plugs, SPW Billet aluminium front strut brace, over bored 40 thou with 10:5.1 high comp pistons, lightened machined crankshaft, new conrods, ACL race spec bearing / rings kit, Fuelstar Fuel Catalyst, Nolathane front control arm bushes, Gripforce Sach Stage.1 racing clutch, Sparco fuel pressure gauge under the hood, Bendix "Ultimate" brake pads, dyno tuned with a Unichip piggyback ecu.
Future Mods:
Custom Box Style Intake Manifold & a Crane 14 camshaft / magnum valve springs.
External / Internal Mods:
Full viper body kit (As sold in Australia), Chrome mesh intake grille inserts, Sirius Plus 2000 55 watt driving lights, SCA Shift 55 watt spot lights, Boschmann 550 watt 6x9s, Roar RX-8 250 watt sub / amp cannon, Crack Hi / Low RCA Converter, Full tint, Autotechnica "Monza" leather gear shift, Isotta Taladega Race / Sports seats, 2x SRT4 turbo gauge pods with Splitfire oil pressure & air / fuel gauges, Splitfire volts & oil temp gauges mounted under the radio, Gold painted calipers, And a mighty MOPAR sticker!!
HoodooGuru is offline
post #3 of 6 Old 11-30-2006, 12:45 PM
rice_eater
All 2.0L engines were interference engines (i.e. all neon engines). If the timing belt goes, so do the valves... If you're lucky the valves wont damage the head or the pistons too much.
'97 Neon DOHC MTX - Sold
'98 Neon DOHC MTX Turbo - Sold
'99 Neon DOHC MTX - The project begins...
rice_eater is offline
post #4 of 6 Old 03-06-2007, 07:50 PM
redman27331
i had the same thing happin to me (95 sohv 2.0) and luckly nothing hit. but it is a pain to get to the belt. have fun
redman27331 is offline
post #5 of 6 Old 03-08-2007, 07:06 AM
dodgeneonACR98
So whats UR excuse?
You can bet something is messed up in teh motor Valves,pistons ect. The only way to tell is to take it apart and have a look see. Good Luck
Squad member #53 [/url]
04 Neon SRT-4
98 Neon ACR-2.4 swaped with goodies
dodgeneonACR98 is offline
post #6 of 6 Old 03-09-2007, 02:04 PM
redman27331
that was the first thing i did. in my mind i tought it hit but when i took the head of not a mark anywhere to be found
    New look for 07 Durango RAM MAN Rumor Mill & Gossip Talk 4 03-19-2007 04:11 PM
    New 6.7-liter Cummins Info Released Today! FreeLantz 3G Dodge Ram Diesel Talk - 6.7L 50 12-02-2006 08:12 PM
    Damn it! Speed Dragon 1972-1987 Dodge Ram Trucks (D, W-series) 23 09-07-2006 10:23 PM
