Heater blows cold and warm air? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 8 Old 10-25-2006, 11:25 PM Thread Starter
MadMattress
MadMattress's Avatar
Tired of talking to the service guys at the dealership, figured I would ask for help here. 03 Ram 1500 4.7L, The heater stopped working, 2 weeks later it started overheating. Took the water pump off and noticed the front cover/timing cover had corrosion and a hole in it. Replaced the cover with what dodge told me was an updated cover/water pump/thermostat assembly. Didn't do anything, had to replace the radiator. It seems to be running normal, but still cant figure out the heater problem. On the passenger side it blows warm air and on the driver side it blows cold air. I don't get it, and either does my roommate which is a mechanic. He's tried various things and still can't figure it out. Anyone have this problem or know what i can do to fix it? If this thread is in the wrong place, sorry.
One more thing, why the hell would Dodge put a plastic impeller in their water pumps???? Then update their timing cover and still use a stupid plastic impeller? Thanks to anyone that can shed some light on how to fix my Dodge!
MadMattress is offline
post #2 of 8 Old 11-16-2006, 12:38 AM
jonny5
ditto
I am having the same heater problem - anybody???????
jonny5 is offline
post #3 of 8 Old 11-16-2006, 12:43 AM
AIR_RAM
AIR_RAM's Avatar
Quoted: 14 Post(s)
Sounds like the coolent level is LOW... ??... Perhaps there is air in the system...when the coolent passes through the heatercore you get HEAT... when air passes through you get cold air...??
SPEED SAFE, AIR RAM
4.7L PERFORMANCE ENTHUSIAST - DODGE RAM's, DAKOTA's, DURANGO's & JEEP's.
AIR_RAM is offline
post #4 of 8 Old 11-16-2006, 01:40 AM
Xjman1
Second that, sounds like air in the system or a partially plugged heater core. By the way, I am in Oxnard, hello neighbor
Xjman1 is offline
post #5 of 8 Old 09-12-2007, 01:07 PM
darrenb
Easy Rider
darrenb's Avatar
Heater Blowing Warm and Cool Air
I have the same problem with my 2003 Dodge Ram 4.7L truck. The passenger side is blowing warm air and the drivers side cool air.
Same this happened to me last winter. Local Dodge dealer changed the heater core and the blender door. I had the extended warranty but still had to pay $130 for the heater core and $100 deduction. I was pissed about the heater core because they don't normally go... Complained to the owner and received a free oil change...
I have to bring it in next Tuesday and will let you know the verdict.
One more time and I officially own a lemon...
darrenb is offline
post #6 of 8 Old 09-12-2007, 01:08 PM
NUTTSQUAD03
NUTTSQUAD03's Avatar
CHeck the coolant level, I had that problem on my '03 4.7 and my coolant was low. Added coolant and that fixed it.
Back in the truck again!
2013 White Ram Express Crew Cab.
Ready to play!
NUTTSQUAD03 is offline
post #7 of 8 Old 09-12-2007, 01:41 PM
siiturbo
I had to replace my heater core as smoke was pouring out my vents. Ripping out the dash wasn't too bad just time consuming.
Dodge Ram 1500 QC 4.7L SWB AT
20x10" MB Gunner 5 wheels
305/55-R20 (33.21") Nitto Terra Grappler AT tires
Focal Component Speakers (Front)
Infinity Kappa (Rear)
Rockford Fosgate HX2 10" Sub (FOX Box)
Boss GT1500D Amp
Side-Steps (need modified)
OEM Fog lights
NGK 6987 Sparkplugs
Performance Accessories 3" Body Lift
Flowmaster 50 Series Exhaust 3"in, Dual 2.25"out
20% Tint so you can't see up in my window lol
Motive 4.56gears
Auburn LSD
Superchips
Future aspirations:
Rebuild motor nice and beefy
Add Supercharger or Turbo
siiturbo is offline
post #8 of 8 Old 09-25-2007, 01:16 PM
darrenb
Easy Rider
darrenb's Avatar
Heater problem
Update: Chrysler changed the second heater core within a year in my truck and flushed the coolant. Everything seem ok now....
darrenb is offline
    2 Misfires in 1.5 years jenstrom Dodge Caravan General Talk 8 06-18-2008 02:35 AM
    03 ram engine light ?? leodogg24 3G Dodge RAM - General Talk 13 04-17-2008 04:21 PM
    2003 Service Manual DoD_Firefighter 3G Dodge RAM - General Talk 24 12-06-2007 03:36 PM
    Check Engine code 2002 3.3 engine login Dodge Caravan General Talk 5 04-19-2006 11:49 AM
    Intake Air Temp Study Exposes Spirit Problem CBP ENGINEER Vintage Dodge Car Forum 6 02-24-2006 07:55 AM
