99 Durango SLT no speedo, abs & brake light on, shift prob. - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 11 Old 10-23-2006, 09:29 PM Thread Starter
gzetski
Ok, I did some leg work on here before posting, but i'm not clear on a few things... first off, the problem:
1999 Durango SLT 5.2 4X4 - no speedo below 30 mph, ABS light on, Brake light on, and will not shift from 1st to 2nd until about the speed at which the speedo comes on (@ 30 mph). Also, downshifts from 3rd straight to first when going below 50 mph.
The previous owner told me he replaced the speed sensor at the trans. no luck. From reading the forums, I can see this is somewhat common on these. Here is what i'm wondering:
1. how many speed sensors are there? just the output shaft sensor on the trans and the one on the rear diff or are there more? I was given 3 different part numbers for the same truck at the parts store, so are there 2 or 3?
2. Which controls what? speedo + ABS, or speedo + TCM, or ABS + TCM???
does anyone know which does what?
I did just buy this truck thinking i will have to replace the trans... but all the gears seem to be there and this seems to be a trans control issue. I have seen the tps mentioned on here numerous times too, but i do not see how this would affect the speedo, and the shifting problem and the speedo seem related to me. Thanks for any input.
gzetski is offline
post #2 of 11 Old 10-24-2006, 09:07 AM
y2kd
You need to replace the ABS/Speed sensor on top of the differential. 10 min job and $35.00 part.
y2kd is offline
post #3 of 11 Old 10-24-2006, 10:27 AM
Neil F.
Neil F.'s Avatar
The are two for the speedometer and one or three for the ABS depending if you have the std two wheel or optional four wheel ABS. The differential is used for the speedo and ABS. According to an individual on the durangoclub forum, the rear sensor supplies the input to the speedo below 20 mph. The transmission output sensor picks up after that. If you have all three symptions, ABS/Brake lights and speedo not working, it's the rear sensor. The rear can go out and the speedo may still work. Mine did. The rear senso does not have anything to do with shifting. The transmission output sensor will affect shifting and will throw a P0720 code. The rear sensor is a dealer only part. The output speed sensor is available at parts stores.
99 Durango 5.9, FT 4x4, IP stage III w/ K&N air hat, M1, MOPAR PCM, Fastman TB, 1.7 RR, JBA headers, Borla cat back, Martin Saine valve body, Hotchkis swaybars, Blistein shocks, lowered 2" Black Rhino Kenya wheels, 246. 7 RWHP, 319 TQ
Neil F. is offline
post #4 of 11 Old 10-24-2006, 06:53 PM Thread Starter
gzetski
Thanks for the input
Strange enough tho, as soon as the speedo comes online, it starts shifting normal. no DTC except pending cyl 2 misfire, nothing at all related to the speed sensor. will try the rear axle first and see what happens.
gzetski is offline
post #5 of 11 Old 10-25-2006, 01:24 PM
OldSchool
yep, when the sensor works, the trans has enough info to shift correctly, when the sensor doesn't work, the trans kinda goes "Huh?". Goes to first cause it thinks your stopped (0 speed)
OldSchool is offline
post #6 of 11 Old 10-30-2006, 05:54 PM Thread Starter
gzetski
Now what's going on?
Ok, so i replaced the ABS/Speed sensor in the diff, piece of cake, ABS and brake light went out and the speedo works. The trans seemed ok at first, but after about 20 miles, O/D OFF lights up, about a minute later TRANS TEMP lights up. The O/D does not respond to the button on the shift knob, and the whole thing feels like its starting from 2nd, then kicking down to 1st, then 2nd then 3rd and so on. WEIRD!
So, what's the verdict? Am I looking at a trans rebuild? Apparently, the people that had the truck before me had the trans rebuilt by Cottman **coughs...* and the warranty on that work ran out already. After the problems with the sensor started, they replaced the output speed sensor on the trans and then messed a whole lot with the TV cable. I got the TV cable to where it "feels good" but still it shifts erratically. The oil is clean, and doesn't smell burnt. GRRRRR.
gzetski is offline
post #7 of 11 Old 10-31-2006, 05:14 AM
Neil F.
Neil F.'s Avatar
OD gets locked out when the trans temp sensor gets triggered. It's to keep the engine and fan speed up to hopefully cool things off. If the trans is not really getting hot, I'd start with the temp sensor.
Neil F. is offline
post #8 of 11 Old 08-23-2007, 09:12 PM
jdrachar
just replaced my speed sensor on my 2000 durango 5.9L and the lights went off for a day but came back on the next. maybee more problems here than meets the eye. someone told me it could be a problem with the PCM (powertrain control module) but I dont know. any ideas?
jdrachar is offline
post #9 of 11 Old 08-23-2007, 11:05 PM
tosterho
Todd O
tosterho's Avatar
sounds like a pcm make sure you check your fuses too imo
tosterho is offline
post #10 of 11 Old 08-24-2007, 07:58 PM
tactransman
Transmission Man!
tactransman's Avatar
You have a fault code,scan it!
Terry aka tactransman
'99 Ram 1500 4X4 5.9 Automatic #110 in the White Truck Club
Aren't you tired of getting your parts for your Super Bee from a kid that thinks a Civic is a "hot rod"!
Mods:
MSD Blaster 3 Coil
Magna Flow Cat and "Y" pipe
46RE Built to the Hilt
Transgo TF OD JR Shift Kit (With Mods)
Billet Cover Converter
Upgraded to five direct clutch drum
Five Overdrive Brake Clutch pack
47RE STEEL front planetary
Sonnax Reverse servo parts
HD Kevlar Lined Rigid Int Band
Deep Pan w/cooling tubes
3.8 ratio Int lever
billet Int servo struts
tactransman is offline
post #11 of 11 Old 11-21-2007, 04:08 PM
kellybcmi
ABS and Brake Light
Well, I am trying to replace the module and am somewhat stuck. The base broke free but will only turn. I can't seem to get it to move vertically. The top came off and the magnet is out, but the base and insert is still there. I have tried channel locks and prying with a screwdriver, but no luck. Don't want to use too much pressure.
Any tips?
kellybcmi is offline
    Brake problem 77crewcab Dodge Caravan General Talk 5 03-25-2008 01:29 PM
    HELP !! Parking brake light and ABS light coming on Rebzilla32 3G Dodge RAM - General Talk 3 06-15-2006 10:03 PM
    (ABS) and BRAKE light turns on...... mrjivester 1G Dodge Durango - Drivetrain Talk 7 12-20-2005 04:59 AM
    ABS Error Light & Brake Error Light 78RamCharger01D 1G Dodge Durango General Talk 7 09-11-2005 02:54 PM
    ABS and Brake Light On rickdog67 1G Dodge Durango General Talk 13 05-28-2004 10:15 PM
