location of camshaft position sensor - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 18 Old 09-01-2006, 06:39 PM Thread Starter
alabamajoe
I have A 2003 dodge ram.
I went to auto zone and they pulled up the code for the bad sensor
The truck will start and run, But if you trun it off , It will take about 1 to 2 hrs to start again.
I need to know the location of this sensor.
Thanks
ALABAMAJOE
alabamajoe is offline
post #2 of 18 Old 09-01-2006, 07:10 PM
440challenger
Go to this web side www.hemitruckclub.com and down load the 2003 manual.
440challenger is offline
post #3 of 18 Old 09-02-2006, 09:47 AM
uk94ram
Hemi'd in the UK!
uk94ram's Avatar
Downloading the manual is best as detailed above. Location of the Camshaft Position Sensor also depends what engine you have in your truck. If you still need help what motor do you have?
2004 Ram 1500 4x4 QCLB Hemi Laramie
More "smiles per gallon" than "miles per gallon"
Our current gas prices*;
US$ 6.29 per US gallon
US$ 7.56 per UK gallon
* For those of you that are interested calculation based upon current UK gas price of 87.9 pence per litre and a conversion rate of US$1.89 to GBP£1.00 along with the fact that our gallons are bigger than yours!! If this doesn't interest you please eradicate it from your mind
uk94ram is offline
post #4 of 18 Old 09-03-2006, 07:54 AM Thread Starter
alabamajoe
not a HEMI 4.7L gas 2 wheel
I got a 4.7L gas 2 wheel
the manual shows a hemi.
post #5 of 18 Old 09-03-2006, 08:42 AM
slammed1
slammed1's Avatar
right below the front right side valve cover on the side of the head.
slammed1 is offline
post #6 of 18 Old 09-03-2006, 08:50 AM Thread Starter
alabamajoe
Is it the one that is just above the oil filter
post #7 of 18 Old 09-03-2006, 08:58 AM
slammed1
slammed1's Avatar
to the side of it
slammed1 is offline
post #8 of 18 Old 09-03-2006, 08:58 AM Thread Starter
alabamajoe
thanks
post #9 of 18 Old 09-03-2006, 11:25 AM
dodge3471
Dodge Fanatic!
No, the oil filter is on the left side (drivers side.) The cam position sensor is under the right side (passenger side) cylinder head pointing straight down, just as slammed1 posted.
dodge3471 is offline
post #10 of 18 Old 09-03-2006, 12:17 PM Thread Starter
alabamajoe
Thanks I have found it and replaced it and took it on test drive.
Glade to report it is ran out fine.
Thanks to ALL that help me.
post #11 of 18 Old 09-03-2006, 12:49 PM
mheideman
Whiskey Bent & Hell Bound
mheideman's Avatar
Thanks to that help me.
What was wrong with it? Did you do a cam swap?
2009 Ram 1500 SLT Crew Cab Big Horn Edition
5.7L Hemi
mheideman is offline
post #12 of 18 Old 09-03-2006, 06:37 PM Thread Starter
alabamajoe
The Prob. I had was:
No I did not do any thing to the truck, It just started this the other day.
1 - I could start only if the engine was cold
2 - If it was hot I had 1 to 2 hrs before I could start it again
3 - If I steeped on the gas It would cut out. ( spit and sputter )
I found the Prob. by turning the key switch on and of 3 time and read the code ( P0344 ) CAMSHAFT POSITION SENSOR.
Thank to all the Info I found on this site
post #13 of 18 Old 09-03-2006, 07:21 PM
slammed1
slammed1's Avatar
When I read the reply I ASSUMED he meant "oil filler" so I was hoping we were on the same page.
Glad you got the problem fixed,lets hope it was the right diagnosis.
slammed1 is offline
post #14 of 18 Old 12-06-2006, 12:33 PM
bc56845
I've got a buddy with a 4.7 truck who needs a cam sensor, is the sensor hard to get to? About how long did it take you?
bc56845 is offline
post #15 of 18 Old 12-06-2006, 05:11 PM Thread Starter
alabamajoe
Cam shaft sensor
Got My sensor at AutoZone foe about 20 bucks
Installed in less then 5 min
Sensor Location:
If you are looking at the front of the motor:
Look to your left under the motor all the way under.
I got to my with out Jacking the truck up.
got on my back and looked up and their it was.
I belive it was a 1/2" wranch.
Easy to install.
If you need help I will be here
post #16 of 18 Old 12-07-2006, 06:10 AM
bc56845
Alright, thanks
bc56845 is offline
post #17 of 18 Old 12-07-2006, 07:31 AM
bc56845
I'm assuming the code will eventually clear itself?, Or is there a way to clear a code on these trucks without using a scan tool?
bc56845 is offline
post #18 of 18 Old 12-07-2006, 09:04 AM Thread Starter
alabamajoe
It cleared up by its self after 15 miles or so
    2 Misfires in 1.5 years jenstrom Dodge Caravan General Talk 8 06-18-2008 01:35 AM
    Anyone know where I can find out what this code means? Bagged02 3G Dodge RAM - Drivetrain Talk 12 07-19-2006 05:38 PM
    Check Engine code 2002 3.3 engine login Dodge Caravan General Talk 5 04-19-2006 10:49 AM
    HELP!!! Code P0132 SHADOW QUAD CAB 2G Dodge Dakota General Talk 4 04-30-2005 09:00 PM
