318 cam recommendations - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 08-28-2006, 09:36 AM Thread Starter
chizzle1
REDNECK SPACESTATION
chizzle1's Avatar
Quoted: 18 Post(s)
What cam is available for the 5.2 that will make more low rpm torque, and still use the stock PCM & torque converter?
I am looking for a low rpm, high torque (RV style) cam shaft.
Anybody running something like this?
thanks
01 Ram 5.9 Sport QC 4x4 - 175k, current build project - SCT Stage1 custom tune via Hemifever, Harland Sharp 1.7:1 roller rockers, Modded Kegger, Edelbrock ProFlow,52mm TB,180* t-stat,e-fans, pacesetter long tube headers, true duals with spun cats, Jones full-boar mufflers, 34x11 Falken ATs on 3rd gen Dodge 20"s, 3"TC lift, rebuilt 46RE w/HD internals, PML Deep Pan,SunPro Tranny Temp gauge,Rebuilt 231D,TSC Diamond Box, Sony head unit
10 Dodge Challenger R/T in Brilliant black - 392 cam,AFR shaker, MyGig 730N w/ navi,dvd,HD,u-connect & rear cam, 6 spd, Track Pak, SRT8 shorties & mids, DS Predator, Jet 180*, BBK 85mm tb, SLP line locks, de-badged, resonators removed, DRL enabled, skip shift eliminator, mopar hood struts, functional hood vents, 392 chin spoiler
09 Suzuki 1255S Bandit Metallic Blue on black, 1255cc I-4, 6 spd, Yoshi can, Givi screen, K&N, Bags Connection tank bag, TPX fuzz buster, Techmount GPS holder, Suzuki center stand, World Performance Seat
2013 Dart Limited Pitch black, fully loaded, hers
SOLD 06 Hemi Durango 4x4 Limited in Atlantic Blue Pearl
SOLD 97 Ram 1500 SLT Laramie in DuPont Frost White Pearl
chizzle1 is offline
post #2 of 9 Old 08-28-2006, 09:41 AM Thread Starter
chizzle1
chizzle1's Avatar
Quoted: 18 Post(s)
I talked to the people at comp cams, and they recommend a cam with a dur of 206 intake / 212 exhaust, with a lift of 480 intake & exhaust. Price is $325.
Power band is 800 - 5000 rpm.
stock stall speed converter and PCM can be used.
Does that sound like a decent price?
I have heard that Mopar make an R/T cam that can be had on ebay for fairly cheap (less than $200).
chizzle1 is offline
post #3 of 9 Old 08-28-2006, 12:55 PM
intosin
Quoted: 1 Post(s)
comp cams told me the same for my truck with a lift of 480 thats with no lifters and the smallest one they made for my application, at that time. And what they did't tell me the first time is, you'll need to change out your valve springs and they dont even offter them, you'll have to get them from someone else. if your just looking for more low end tq its probly not the cam you want. although it does sound like a good deal to me at the time. also they neglected to tell me that i may or maynot have to "burn" my pcm or buy a new one. i grew board of their misinformation from the different people i would talk to. mopar makes a nice one with not that big of a lift so you dont have to change out the springs ( but i did b/c of the mileage on the truck) and it comes with new lifters. the guys from mopar were super nice, however i didn't pay $200.oo for my cam. i did get it from Moparts connection and got a better price then summit. there's other good cams out there just make sure they are computer compatalbe. good luck
intosin is offline
post #4 of 9 Old 09-10-2006, 07:51 PM
Ram15
Comp cams hot line
You might call the the comp hot line. they have a computer program that will match a cam to your truck. I built an olds engine for a car and used the cam they recommended for more low end torque with stock converter and rockers and it runs damn good.
Ram15
Ram15 is offline
post #5 of 9 Old 09-11-2006, 09:21 AM Thread Starter
chizzle1
chizzle1's Avatar
Quoted: 18 Post(s)
I did, see post #2.
They told me that it would get me more low end, so I may give it a try.
I'm not too concerned with the spring situation as new springs will be installed when the heads are re-worked when it's rebuilt anyway.
It'll be a while before the cam is ordered, I may get in touch with Crane and a few others to see what they offer.
I researched the MOPAR R/T cam and it's a high rpm application, definitely not what I want.
thanks for the replies.
chizzle1 is offline
post #6 of 9 Old 09-13-2006, 09:39 AM
RAM MAN
Originating Member
RAM MAN's Avatar
talk to Scott Brown
PH: 517-381-8801
FX: 517-381-9337
Email: sbrown@racemufflers.com
Tell him David / RAM MAN told you to call
Scott is a very well know MOPAR cam specialist
Good luck on your project.
RAM MAN is offline
post #7 of 9 Old 09-13-2006, 09:57 AM Thread Starter
chizzle1
chizzle1's Avatar
Quoted: 18 Post(s)
thanks, he got me some good information.
Looks like a cam (312/218 .510) , MP springs, and new lifters will run about $600 with shipping...that bumps the overall price of the stroker rebuild to about $3200.
I hope the tranny holds up behind the 390.
chizzle1 is offline
post #8 of 9 Old 09-13-2006, 12:34 PM
RM Indy
Ram Racer
RM Indy's Avatar
Welcome to the world of strokers. That sounds like a better cam, anything under 500lift is a bit anemic IMHO.
Need to be realistic about your budget, I would expect it to go to 4200 or more Best to add what you need while its apart, not later after the motor is back in.
With new cam/lifters and springs you must have new retainers as well. Stock ones are too small for MP 600 lift springs. I would add pushrods also.
Few other things you should consider adding to your list
Roller rockers, water pump, high volume oil pump to keep her cool, 24lb injectors (stock inj will have you running very lean), 255lph intank fuel pump and a flash to control it should be also added.
11 Bighorn 4x4 5.7, K&N FIPK, BD GT+, Herculiner, Extang Encore, Bedrug
Toy...96 Ram Indy
408ci/8.5cr all forged/billet
Procharger D-1SC (polished) w/3core a/a intercooler
Tons of pics, timeslips, videos, installs, downloads & more check out
(ets in sig pic = mild 360 w/7psi @ approx 390-400rwhp)
RM Indy is offline
post #9 of 9 Old 09-14-2006, 08:49 AM Thread Starter
chizzle1
chizzle1's Avatar
Quoted: 18 Post(s)
here is a list of what I have to purchase so far:
$1600 for stroker kit includes:
Scat crankshaft and I beam Rods
Diamond Racing Forged Pistons & RINGS (multiple comp ratios, stock up to 10.5:1)
Clevitte - 77 rods and main
Melling High Volume Oil Pump $37.99
MP timing chain tensioner DCC=5007709 $38.99 Cheaper at the dealer.
Double roller timing chain set P5249267 $58.75
Intake plenum cover kit 7714 $80.50
MP Chrome molly retainers P4452032> $60?
MP Locks P4529218> $60?
Valves?
Cam (312/218 .510) , MP springs, and new lifters $600
Gasket set P4876249 112.50
Intake bolt set P4876772 $6.25
Machine work
Bore block typical cost $160
Hot tank and new cam bearing typical cost $70
Heads, 3-angle valve job $200
*Balancing $145-200 depending on who you call
depending on the cost of the valves and variances in shipping, $3200 isn't that far off.
chizzle1 is offline
    1979 318 timing chain red83150 1972-1987 Dodge Ram Trucks (D, W-series) 4 08-13-2006 09:55 PM
    bore stroke and cam lift of 318 magnum?? blaizinram 2G Dodge Ram Performance Talk 4 06-18-2006 12:52 AM
    5.2L Cam and other engine help MechE 2G Dodge Ram Performance Talk 29 04-25-2006 11:39 AM
    6.1L Cam advice BamaHemi 3G Dodge Ram Performance Talk 2 09-16-2005 11:53 PM
