What ya got under the hood?(318 or 360 cubic inches) - Page 7 - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
View Poll Results: What ya got?
318 516 38.48%
360 825 61.52%
Voters: 1341. You may not vote on this poll
post #121 of 566 Old 01-04-2007, 11:37 PM
B-Rad!
I have the 360 in my 1997. I can tell you it's stock performance is way way way more than enough for me considering my last car was a 1990 Toyota 4runner. I am pretty happy with my truck, and I wasn't going to consider one with the 5.2, even though they are legendary motors.
B-Rad! is offline
post #122 of 566 Old 01-05-2007, 12:07 PM
threetwos
AirFuelEddie
Thats ok B-rad the 360 is the same engine except for the bore size, stroke and diameter of the crank mains. The 360 is just as "bulletproof", only weak point is the timing chain,(stretches), and Ma MoPar has a 35.00 fix for it. Unlike gm,phord,toyota the MoPar small blocks never used cheap cast iron connecting rods with weird valve angles, tissue paper cylinder walls,(ford), and junk valvetrains,(gm). The MoPar smallblocks will easily go 200k if reg. maintenance is adhered to.
threetwos is offline
post #123 of 566 Old 01-05-2007, 11:37 PM
B-Rad!
Yeah, I know the 5.2 is basically a destroked version of the 5.9. I just wanted to have more HP starting out. I don't really see myself having money to spend towards performance, so the bigger one seemed more logical. I still would have taken a 5.2 if I had to though, since I had no room to complain going from a japanese made suv with 215K miles on the orignal motor and tranny, with stock power ratings at 150Hp and 180ft lbs, to an american made beast truck with a V8 and almost double what I had before. But anyways, I love dodge's, and I don't care what their problems are, they look the best, and have more power stock than the rest. And they sound better too.
B-Rad! is offline
post #124 of 566 Old 01-06-2007, 10:33 AM
bigschwerm
bigschwerm's Avatar
97 ext. cab 2wd 5.9
Update: 7/27/07 1/4 mile run 13.312 @ 102.67 60ft 1.96
New Pics Aug 8th 07:
BLACK 1997Ram Ext. Cab 1500 2wd S/B
Performance Mods: Good for 320ish hp to the wheels/awaiting dyno run
5.9L Short block Bored .30 (local shop)
Schmidt Motor Works Ram Air Setup 4" Tubing
53mm Custom Throttle body
Custom Flashed Computer (Tom Fox)
Hughes Stage 1 "KEG" with extra Machining/Plenum Kit
Hughes Heavy Duty Super Prepped 2.02/1.620 Heads W/HD Valve Springs *Shaved .025"
1.7 Harland sharp Rockers
Custom ground KRC 210x Cam
Ford Racing 24lb Blue Top Fuel Injectors Part# 0280150947 F1TE-D5A
Improved design AIRTEX Fuel Pump (O'reily auto parts)
Underdrive pulleys
Accel coil
MSD 6A Ignition Box
MSD 8mm wires Brass cap/Rotor
Autolite Platinum 3923's
Dual Flex-A-LITE Efan's
180* Thermostat
Roll Pan
Royal Purple Throughout Drivetrain
Pacesetter Headers/gutted Magnaflow Cat /Flowmaster 40 series front of pass. side tire dual 3" tips
3.92 Gear Swap with Spool
~DodgeTalk.com 360MAGNUM Enthusiast Member #40 ~
bigschwerm is offline
post #125 of 566 Old 01-06-2007, 06:46 PM
threetwos
AirFuelEddie
The 5.2 isnt a de-stroked 360 the mains are different as well as the bore size. The 360 is even better than the 340 for Heavy Duty use, the 340 is a high rpm screamer due to the unshrouded valves and good head flow. The best heads were on the 360 TBI"s though.I know what you meant though and yes the 318 is a great engine!
post #126 of 566 Old 01-08-2007, 10:18 AM
snookers54
snookers54's Avatar
Got's me a 318 in mine.....and I luv it
good wholesome snack food
13 inches of total lift
color="Blue">7" S/J coils - 4.5" superlift spring packs - 3" P/A body lift - P/A Gap Guards - Thueren Trac bar - Solidsteel steering brace - Dual steering stabilizers - Dual front shocks - Russell SS brake lines - Drilled + slotted rotors - Yukon 4:56 gearing front and back - Detriot Locker - DC long arms - 37" DC FCII tires - 15x10 DC aluminum wheels - Dual batteries - Blue Lightning 130 amp battery isolater - ARB air compresser - Mack Truck Air Horns - 4.5 cu.ft. air reservoir - Clear corners - Hughes Engines Plenum belly pan - SS Exhaust - Magnaflow high flo cat - Flowmaster 40 SIDO muffler - Dual exhaust tips - MSD6A Ignition - Custom CAI - B+M remote external transmission filter - External tranny cooler - Hypertech Power Programmer III - and more
snookers54 is offline
post #127 of 566 Old 01-09-2007, 07:48 PM
Paele
Paele's Avatar
strokin' a 318 in the islands....wonder what I could do to get a little more boost especially going up hill?
thought about an AirRaid CAI, and a Flowmaster 40...got any other suggestions?
Paele is offline
post #128 of 566 Old 01-10-2007, 10:06 PM
snookers54
snookers54's Avatar
HEADERS
post #129 of 566 Old 01-11-2007, 08:22 PM
pn2112
98 1500 Quad 4x4 S/B Sport 360
Anyone know where I can find headers at a good price?
pn2112 is offline
post #130 of 566 Old 01-11-2007, 10:39 PM
jtbigz_ga
Grabbin life by the horns
jtbigz_ga's Avatar
5.2 L 318
jtbigz_ga is offline
post #131 of 566 Old 01-16-2007, 04:38 PM
novaDAK
The 360 wouldn't be around if it wasn't for the 318!
And the 318 wouldn't be around if it wasn't for the 273 either. (NOT the new 287!!!)
novaDAK is offline
post #132 of 566 Old 01-16-2007, 11:46 PM
mac69
Got me a 5.9L 360
2001 Sport RC/SB
1500 4x4 Offroad edition
5.9l 360
Volant CAI
33x12.5 17's Mud Terrian
4.10's
2 12" rockford p2's
with 1000watt amp
just got 2 new infinity perfect 12.1 just waiting on install and gotta buy some new amps
mac69 is offline
post #133 of 566 Old 01-17-2007, 05:38 PM
TXRamBabe360
Gold Member
TXRamBabe360's Avatar
360 here
TXRamBabe360 is offline
post #134 of 566 Old 01-20-2007, 01:47 AM
RamIt97
RamIt97's Avatar
Quoted: 1 Post(s)
360 here!
There is no replacement for displacement. The 318 isn't a bad motor either but these trucks need torque to get them moving. They aren't light A bodies that's for sure!
1997 Dodge Ram Sport 4x4, 5.9L Engine
KRC 2.02 Street Ported R/T Heads, KRC 210x Cam, Comp Cams 1.7 Rockers, F&B 52mm Billet TB, M1 Intake, K&N FIPK II, Accel 21 lbs/hr Injectors, MP Headers with True Duals, MSD 6AL Ignition, MSD Blaster HVC Coil, Magnacor R-100 Wires, ASP Crank Pulley, APS 2800 Stall Converter, APS Valve Body, SCT X2 Hemifever Tuned PCM, 180° Thermostat
RamIt97 is offline
post #135 of 566 Old 01-22-2007, 12:35 AM
Pimpina5.9
Brian
Pimpina5.9's Avatar
360 here too! And I love it! Although my Guitarist has a stock 318 and his will keep up with mine all the way. But his is a reg cab, mines a club cab. Same year models.
2009 1500 4.7 Crew 2WD. Just stock. (Moms and Pops)
1998 1500 ext. cab 360 Auto 2WD.
GOD SQUAD GROUP: 1988 - ETERNITY.
Mod list:
Flowmaster 40 dumped exhaust.
High flow Cat.
Mopar Performance PCM.
K&N FIPK.
Relocated IAT.
Fiberglass Rollpan.
Hard Tonneau Cover.
Carriage works Billet grille inserts.
Summit shorties.
OEM 20's off an 03.
MSD Blaster 2 Coil.
Taylor 8.2mm Wires.
Home made throttle body mod.
Modded intake manifold.
180* t-stat.
Map sensor vacuum mod thing..
Largest Autozone aux trans cooler.
Transo shift kit.
CPS Mod.
24lb 6 Hole pattern Injectors off a 97 Trans AM.
I FEAR NO BEER!
Pimpina5.9 is offline
post #136 of 566 Old 01-22-2007, 11:21 AM
wadman1
wadman1's Avatar
97 2500 with the 360 in it
wadman1 is offline
post #137 of 566 Old 01-23-2007, 10:19 PM
BlackRam 2500
BlackRam 2500
BlackRam 2500's Avatar
360 here 98 2500 Quadcab long bed 4x4 I love the truck but wish I had the shortbed. It has 265 x 16`s BFG`s and I trying to decide on putting 33`s on with American Racing Hurricane wheels 16.5 x 9.75 maybe I`ll post this to see if any pic`s surface.
BlackRam 2500 is offline
post #138 of 566 Old 01-23-2007, 10:24 PM
TXRamBabe360
Gold Member
yeah...my stock 360 will put the hurt on a GT Mustang. Talk about your slutstang ego mutilator
I guess the only thing that would hurt them more than a stock full size pickup whoopin their ass would be if...a Geo whooped their ass. LOL, I'd pay to see that.
post #139 of 566 Old 01-23-2007, 11:17 PM
Pimpina5.9
Brian
Pimpina5.9's Avatar
Well I`ve never spanked any GT`s, but I`ve tamed a few rice burners.
Mod list:
High flow Cat.
K&N FIPK.
Relocated IAT.
Fiberglass Rollpan.
Hard Tonneau Cover.
Summit shorties.
OEM 20's off an 03.
MSD Blaster 2 Coil.
Taylor 8.2mm Wires.
180* t-stat.
Transo shift kit.
CPS Mod.
I FEAR NO BEER!
post #140 of 566 Old 01-25-2007, 12:50 AM
ram_style62571
ram_style62571's Avatar
2 x the 360's here
360 in my '84 3/4 ton 4x4 mud truck, and 360 in the '01 qc/sb 4x4 haulin the 84 to the mud drags. love em both, with the exception of a few tranny issues (some funky sensor 2 shops haven't figured out yet) with the 01, never had a problem with either!!! 2 'ol boys sittin around lookin at their fords and chevys said 'we need a truck with More Power, and bein from the south this was said with a drawl, and there was born the MOPAR
07 Ram 2500 QC brilliant black pearl 4x4 5.9 HO Cummins 6 speed manual -Lonestar Edition-
All factory....... for now, upgrades are inevitable
its began....
AEM Brute Force HD CAI
MBRP 4" turbo back exhaust
01 1500 4x4 qcsb black/silver (sold)
5.9L, 360cid
flo pro single in dual out muffler
custom duals at 45 deg angle with 3 1/2 inch tips
tinted back glass
factory brushed aluminum nerf bars
Chrome brush guard w/ headlight guards
40 watt strobes all 4 corners
kenwood cd head unit with
sirius sattelite radio <--- best investment so far!!
Firestone Ride-Rite airbag helper springs in rear
Yukon R&P plus Detroit TrueTrac in rear
ram_style62571 is offline
    Help. Known Cubic Inches under rear seat? 66glasshouse 3G Dodge RAM - Interior/Exterior Talk 12 10-10-2006 11:01 PM
    Engine choice? (318 vs 360 cid) rstl99 Dodge B-Series Vans 1971 - 2003 20 09-08-2006 12:56 PM
    bore stroke and cam lift of 318 magnum?? blaizinram 2G Dodge Ram Performance Talk 4 06-18-2006 12:52 AM
    88 360 To 90 318 Swap bpblaes Dodge Ram Truck 1st Gen (88 - 93) Forum 4 02-28-2006 07:57 AM
