check egr light won't go out - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 07-18-2006, 09:10 AM Thread Starter
desertdirk
I have an 87 ram 50 and the "Check EGR" light cam on at 100,000 miles. How do I get it to go out? I have tried turning the ignition key on and off several times but that does not work.
Thanks
DD
desertdirk is offline
post #2 of 9 Old 07-18-2006, 08:09 PM
bherder
Mopar Madness - Get it...
bherder's Avatar
Take the bulb out of the dash...
But seriously,... Did it come on at exactly 100,000 miles?
May not be anything wrong at all. Some computers on rigs are 'pre-programmed' to turn a warning light on, even if there is nothing wrong...
("Check Engine" light)... (Get you into the dealer to 'fix' nothing wrong..)
Sometimes, disconnecting the positive cable from the battery for 10 minutes or so, will clear the 'warning' lights up, sometimes not. Sometimes you have to have a 'tech' at the dealer get rid of the light for you. Maybe you really DO need an EGR valve.
Then again, if I'd replaced everything a light on the dash told me to all the time, .... Heh heh heh, you know how that goes
Guages, I trust.... 'Lights'... Well.... Ehhhh......
One more note... I've got a Geo Metro with 190,000 miles on it. The 'check engine light' came on about.... Oh, 120,000 miles ago.... I'm still driving it and it still gets as good as mpg/power as it ever had....
Eh, for what it's worth
"There's been a DODGE in my garage since 1974"
bherder is offline
post #3 of 9 Old 07-18-2006, 09:22 PM Thread Starter
desertdirk
As a matter of fact I did remove the bulb, but it stayed lit!! Ha
No, I did disconnect the battery and it stays on. The manual says it comes on every 50,000 so maybe when I hit 150,000 it will go out again.
Now if I can just figure out the new carb problem . . .
DD
post #4 of 9 Old 07-18-2006, 09:23 PM
Speed Dragon
Aka Force Fed Mopar
Speed Dragon's Avatar
Stick a piece of tape over it Take it to Advance or AutoZone, usually they can clear codes for you. If they do and it comes back on, swap out the EGR and have them clear it again and see what happens.
If you still have a cat on it, it could be getting stopped up and throwing the light too.
Rob M.
'93 D150 RC SWB, 5.2 Magnum, NV4500 5-spd, 9.25" diff
'72 D100 RC LWB, PT project
Speed Dragon is offline
post #5 of 9 Old 07-19-2006, 11:44 PM
Chump
Chump's Avatar
Chump is offline
post #6 of 9 Old 07-20-2006, 01:21 AM
bherder
bherder's Avatar
Originally Posted by Chump
Heh heh heh.... And there ya go....
"Removing the bulb or disabling the system before the specified mileage is a violation of the Federal Automobile Emissions Act."
BE CAREFUL!! I'm sure the FBI has nothing else better to do than throw you in the slammer for 20 years for pulling a light bulb out of your dashboard...
But these days, one never knows...
bherder is offline
post #7 of 9 Old 07-20-2006, 09:44 AM Thread Starter
desertdirk
I am going to have to tell the guys at Autozone about their own website. This is a great resource and when I went in to Autozone to have them check this out, they didn't know about this. Thanks so much for the info.
DD
post #8 of 9 Old 07-20-2006, 04:29 PM Thread Starter
desertdirk
Well
I looked at the dash and found a small panel (actually thought it was a blank for some other option like a switch or light) when I popped it out, I found the rest switch behind it. Brilliant!
Thanks again
DD
post #9 of 9 Old 07-26-2006, 09:43 PM
richknapp
richknapp's Avatar
i have a 86 Power ram 50 and i had a little switch under the dash besal for the gadges. it was on the right side below the cluster just had to slide it to the opposide side. mine goes off every 50,000. sitting in the seat with the besel/gadge plastic seround off (4 screws, 2 up top, 1 hidden by cover plates one right side of dash plate the other is hidded behind the hazard switch insert), it should be right there staring you in the face on the lower right side
richknapp is offline
    2001 Dodge Dakota Engine Check Light Roushracingfan 2G Dodge Dakota General Talk 6 02-18-2006 09:58 AM
    Reset EGR light on dash catnip1970 Dodge Dakota 1st Gen (87 -96) Forum 7 02-09-2005 05:43 PM
    check engine light want come on and truck want start shorty69 2G Dodge RAM - General Talk 3 09-01-2004 05:53 AM
    check engine light... WumpscuT Dodge Magnum - General Talk 15 08-25-2004 06:35 PM
