Performance Intake manifold options for a 318? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 27 Old 07-05-2006, 05:02 AM Thread Starter
greg_glider
greg_glider's Avatar
Hello,
I did some searching around for performance intake manifold options for a 97 318 ram. The most popular manifold that I could find is a Mopar Performance M1 MPI intake Manifold. How much work is it to replace the stock manifold with a M1? also, are there any other aftermarket intake manifolds available?
thanks
Greg
greg_glider
*DodgeTalk.com 318 Enthusiast Member #(39)*
"Silver 97"
1997 Dodge Ram 1500
Reg cab, long box with topper
318/ 5.2L w/ 46RE auto transmission, RWD
only 118,000km on it total!
Misc Mods;
-Topper with a GMC LED brake light
-spray in bedliner
-Aftermarket paging car alarm w/ starter kill
-Dodge Ram 16x7" 3 spoke polished aluminum wheels
-2001 dodge ram overhead console w/ trip computer, painted black (still a work in progress!)
-2003 Dodge ram split 40/20/40 bucket seats, driver power!
Performance Mods;
-Fastman 52mm throttle body
-7.5mm mopar performance plug wires
-Custom cold air intake/ ram air intake
-K&N drop in air filter (backup)
-Exhaust in progress
-Efan in progress
-kegger intake in progress
greg_glider is offline
post #2 of 27 Old 07-05-2006, 09:44 AM
edglock21
The Green Machine
edglock21's Avatar
The swap isn't very hard - just remove the old kegger, swap over the components, and plop the M1 in there. There aren't any other performance intakes for the 318/360 beside the Mopar M1 - one question though:
How will you be using the truck?
Reason I ask is that there is another option to the M1, involving modifying the stock kegger manifold. The M1 is designed to work in a higher RPM range due to the short runners - great for racing, not the best for street driving or offroading. A modified kegger can give you power down in the lower RPMs, where the 318/360s like it. I can give you some more info on this mod, if you'd like.
ED
98 RAM 1500 SLT QuadCab 4x4 360/AT
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same, or one day we will spend our sunset years telling our children and our children's children what it was once like in the United States where men were free. - President Ronald Reagan
I'll rochambeau ya for it..." Eric Cartman
edglock21 is offline
post #3 of 27 Old 07-05-2006, 02:31 PM
Gamester
Power Adder
Gamester's Avatar
Yea, I like my MP1 intake; However you will notice that you lose some low end power, but you will also gain quite a bit of high range power in return
It’s great for higher speeds. I'm planning on getting some 4.56 gears next month in hopes of restoring some of my low end torque.
If you’re going with the MP1, this is about the cheapest place that I have found to buy it, don't forget your installation kit and gasket also...
http://chucker54.stores.yahoo.net/inman.html
O’ yea and you might want to get some new intake bolts too...
http://chucker54.stores.yahoo.net/mop19magv8.html
The intake comes with some very good and detailed instructions. If you are at all mechanic savvy, installation should be a breeze.
The guys at Mancini Racing are very helpful; I do business with them when ever I can. I got my heads and cam from them too.
Hope this helps,
Gamester
2016 Ram 4x4 5.7L Hemi
Procharger D-1SC Supercharger 7.5PSI
DynoMax Ultra-Flow Stainless Exhaust
470 RWHP @ 5000ft elevation
Gamester is offline
post #4 of 27 Old 07-05-2006, 02:42 PM
Silver_DodgeRam
Mmmmmmmmm, beer.
Silver_DodgeRam's Avatar
Quoted: 2 Post(s)
I have heard from a couple of very reliable sources that the low end loss experienced by most who do an M1 upgrade is because they do not flash their PCM to compensate for the M1. There is actually an "M1 Flash" you can get through the Fastman (it's a B&G flash), and it is supposed to make a huge difference. If/when my plenum goes, I fully plan to get an M1 with the appropriate PCM flash. Expect to pay about $400 for the flash though.
2009 Dodge Ram 1500 4x4, 5.7 Hemi, Crew - work in progress
2008 Chrysler Aspen 4x4, 5.7 Hemi, Loaded
Silver_DodgeRam is offline
post #5 of 27 Old 07-05-2006, 02:49 PM
Gamester
Power Adder
Gamester's Avatar
Sadly, I do not have that option
I have a 94' OBDI computer system instead of the OBDII
But don’t worry greg_glider, you do have the option of getting a B&G PCM flash
Gamester
Gamester is offline
post #6 of 27 Old 07-05-2006, 06:39 PM Thread Starter
greg_glider
Hello All,
thanks for the info, it all looks good.
edglock21, that info for modifying the stock kegger manifold would be great. I would like to improve both the low and high end power, but if I had a choice, I would rather improve the low end power and torque since I could use that for towing. Hughesengines.com does have a modified kegger manifold (called a stage 2 OEM), is this what you mean? Do you know how much of an improvement this modified kegger is to the original?
thanks, I think thats enough questions for now!
Greg
greg_glider
"Silver 97"
1997 Dodge Ram 1500
Misc Mods;
-spray in bedliner
Performance Mods;
-Efan in progress
post #7 of 27 Old 07-05-2006, 06:47 PM Thread Starter
greg_glider
forgot to ask: for this B&G flash, can I still use a programer with the flash, or do I have to use only one or the other?
thanks
Greg
greg_glider
"Silver 97"
1997 Dodge Ram 1500
Misc Mods;
-spray in bedliner
Performance Mods;
-Efan in progress
post #8 of 27 Old 07-05-2006, 08:06 PM
Road Dog
Derelict
I've seen pictures of Hughes modified kegger and I really don't understand how you "shorten" the intake runners. Just curious.
1998 Dodge RAM 1500 Quad Cab 4x4
Hughes Plenum Kit
Modified kegger with shortened runners
Superchips Microtuner
Road Dog is offline
post #9 of 27 Old 07-05-2006, 11:00 PM
Silver_DodgeRam
Mmmmmmmmm, beer.
Quoted: 2 Post(s)
thanks
Greg
It's not really one or the other because that makes it sound like they are equal. The flash is so much better then a hand held programmer. But yes, you would not want to use the programmer with the flash.
post #10 of 27 Old 07-25-2006, 09:33 PM
edglock21
The Green Machine
edglock21's Avatar
Greg
I'm sorry guys, I lost track of this thread
Here is some information on modifying the stock kegger manifold (this is all information that I gleaned from other sites, I've not yet done it myself - I just got a second manifold off of a 5.9 that I'll be using though.)
- Take a Sawzall and hack off the runners flush with the runners next to 'em (see blue line in first pic below)
- Clean up the ridges, and any metal shards, with a Dremel (sort of like porting, but not to the same degree)
- Get yourself a Hughesengines or APS Precision Plenum Gasket replacement kit and a Fastman Throttle Body, button everything back up - and you're all set
I'm sure it sounds easier than it actually is, but I'm gonna give it a shot on my newly acquired manifold. Anyone that doesn't feel comfortable doing it, go see a machine shop or call up Hughes and get their modified kegger.
The pictures are property of robert97dodge, from DTO, during his modification of his manifold (I don't claim them as my own and will remove them if requested - I'm gonna PM him over there with a link to this thread).
ED
post #11 of 27 Old 07-26-2006, 08:23 AM
DPR250R
It's also a good idea to clean up the injector bores.
1996 Ram 1500
5.2 - 4x4
215,000
DPR250R is offline
post #12 of 27 Old 07-27-2006, 10:03 PM
Anarchist
Anarchist's Avatar
hmm well looks like im going to cut up some scrap at the shop lol lots of 318/360s
I Would Eat Chevys All Day.... But They Taste Like Sh!t....
98 ram 5.2
headers
3inch lift
3inch body
full MSD
cut intake
and lots of other mods
just to damn lazy to type them all
36 tsl radial
4.56 gears
fast man TB
1.7 RR
the money pit never ends
*Green Truck Club Member #12*
Anarchist is offline
post #13 of 27 Old 07-29-2006, 12:33 PM
Road Dog
Derelict
Thanks. I just order the Hughes plenum kit so maybe I'll cut up my manifold while I'm in there.
Hughes Plenum Kit
Road Dog is offline
post #14 of 27 Old 07-29-2006, 01:51 PM Thread Starter
greg_glider
let me know how the Hughes Plenum kit works for you.
greg_glider
"Silver 97"
1997 Dodge Ram 1500
Misc Mods;
-spray in bedliner
Performance Mods;
-Efan in progress
post #15 of 27 Old 10-31-2006, 11:54 AM
JD770
anyone have a before/after dyno of the M1?
JD770 is offline
post #16 of 27 Old 10-31-2006, 11:57 AM
JD770
Gamester
Do you have engine pics?
JD770 is offline
post #17 of 27 Old 10-31-2006, 08:44 PM
ScojoDak
Dakota for life!
ScojoDak's Avatar
Fellaz, while the M1 will improve performance, in some states, like here in Cali, it'll flunk the visual when the smog nazis do their testing. With a modded kegger, Hughes or otherwise, they wont know it's modded just by looking. I'm going the modded kegger route. Just my $.02
If you don't live for something, you'll die for nothing!
ScojoDak is offline
post #18 of 27 Old 10-31-2006, 08:49 PM
Gamester
Power Adder
Gamester's Avatar
I don't have any pics of my engine right now. Are you just wanting to see what the M1 looks like on the 318? If so I can take some pics for you. Just let me know.
Later,
Gamester
Gamester is offline
post #19 of 27 Old 11-01-2006, 09:35 AM
JD770
Later,
Gamester
yes, and thanks
no hurry.
JD770 is offline
post #20 of 27 Old 11-01-2006, 03:18 PM
Gamester
Power Adder
Gamester's Avatar
Ok JD770,
I'll take some pics for you before I go to work. I'll post them here in a bit.
Later,
Gamester
Gamester is offline
    97 Ram Questions 63_c300_413 2G Dodge RAM - General Talk 5 04-27-2006 10:44 PM
    bad intake gasket tsb included T's99durango 1G Dodge Durango - Drivetrain Talk 6 09-16-2005 10:01 PM
    Intake Test, Phase One Complete magnuman Dodge Magnum - Performance Talk 6 07-30-2005 05:19 PM
    intake manifold leak? 360v8 andyc Dodge B-Series Vans 1971 - 2003 7 12-08-2004 09:51 AM
