Whining Noise - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 13 Old 06-28-2006, 10:33 PM Thread Starter
DODGEIT
DODGEIT's Avatar
Quoted: 1 Post(s)
Whining Noise
I've noticed a whining type noise when driving. I don't notice it until I unload the driveline. As the vehicle slows down is when I hear it. I am unable to hear it with the a/c off and the windows down as the noise from the outside air rushing in drowns it out. However with the windows closed and the a/c on low fan the noise is there. It sounds like mid truck is where it maybe coming from. Any suggestions.
2012 Dodge Ram 1500 Big Horn QC 4x4
DODGEIT is offline
post #2 of 13 Old 06-28-2006, 10:49 PM
Fargo
Leaning Tower of Power
Fargo's Avatar
You may be suffering from the same problem we have...
http://www.dodgetalk.com/forums/showthread.php?t=109791
Fargo
*DodgeTalk.com 318 Enthusiast Member #(49)*
Fargo is offline
post #3 of 13 Old 06-28-2006, 10:53 PM
Fargo
Fargo's Avatar
If the noise is coming from the rear axle, remember that the huge driveshaft will resonate the sound up through the truck and make it hard to detect exactly where it originates...
Fargo is offline
post #4 of 13 Old 07-10-2006, 10:12 PM
James D. Reding
My truck is whining also, I had a shop look at it and it is comming from the rear diff. they said that once it starts making the noise there in nothing to stop it accept to replace the gears, and make sure that the backlash is set correctly.
1997 4x4 sport
extended cab
318
James D. Reding is offline
post #5 of 13 Old 07-11-2006, 03:03 PM
kennethpruett
It may not be gears, but the pinion bearings.
That is what failed in mine.
KP
kennethpruett is offline
post #6 of 13 Old 08-24-2006, 04:24 PM Thread Starter
DODGEIT
DODGEIT's Avatar
Quoted: 1 Post(s)
Well I finally sent my truck to be fixed. New pinion bearings,new carrier bearings, seals and labor came to $630.00. After all is said and done I still have a noise. It is somewhat different then before. I've had it back and forth several times since my first posting and while they have worked on it each time it was there they can't seem to find what is now causing the noise. Lash has been checked and rechecked. Tried several shims and the noise won't go away. Shop owner says ring and pinion have normal wear and don't need to be replaced. The noise is deeper in sound then before plus I can hear the ring gear making noise. I have a 1200 mile trip coming up in a few weeks. I am open to suggestions as to what it might be. Also axle bearings were in good shape.
DODGEIT is offline
post #7 of 13 Old 08-24-2006, 06:57 PM
kennethpruett
Mine still makes a noise that also is different in tone and seems to be affected more on heavy accel/decel.
Someone said I should have checked the backlash but my father and I didn't think about it until it was all back together.
I also used the same shim.
Not sure what to tell you.
I was worried about mine (and still feel uneasy about long term), but the sound has not gotten louder and sometimes I think it got a little quieter.
Maybe someone else will have some more info.
KP
Hope your trip goes well.
post #8 of 13 Old 08-24-2006, 08:37 PM Thread Starter
DODGEIT
DODGEIT's Avatar
Quoted: 1 Post(s)
Thanks Kenneth. Yes mine is affected by accel/decel. The noise also varies in loudness depending on speed. I can't hear it with the windows down and the a/c and radio off. But with windows up and a/c on low or even off I hear it significantly. Really sounds loud on smooth pavement. I may end up replacing the ring and pinion before it is said and done. I am going to get a second opionon from another shop. I went to the shop I had it repaired at on the recommendation of my normal mechanic who is down to just himself in his shop and didn't have time to get to it for several weeks. I will have him drive it also to see what he thinks.
DODGEIT is offline
post #9 of 13 Old 08-25-2006, 11:12 AM
kennethpruett
No problem.
Let us know what he says.
KP
post #10 of 13 Old 08-29-2006, 03:55 PM
Jeff_Taylor
I was getting this terrible whining sound in my truck. It only occured when my wife was in it!
Jeff
'10 Ram 1500 QC
TRX4, Hemi
Jeff_Taylor is offline
post #11 of 13 Old 08-29-2006, 04:29 PM
chizzle1
REDNECK SPACESTATION
chizzle1's Avatar
Quoted: 18 Post(s)
have you checked the u-joints?
DODGEIT: some noise is normal. When I had my Yukon 4.11s installed, I noticed a different noise than with the 3.55s.
After 1000 miles I took it back for the inspection (per recommendation of the mechanic that did the install).
He checked the lash, play, etc and all is well.
01 Ram 5.9 Sport QC 4x4 - 175k, current build project - SCT Stage1 custom tune via Hemifever, Harland Sharp 1.7:1 roller rockers, Modded Kegger, Edelbrock ProFlow,52mm TB,180* t-stat,e-fans, pacesetter long tube headers, true duals with spun cats, Jones full-boar mufflers, 34x11 Falken ATs on 3rd gen Dodge 20"s, 3"TC lift, rebuilt 46RE w/HD internals, PML Deep Pan,SunPro Tranny Temp gauge,Rebuilt 231D,TSC Diamond Box, Sony head unit
10 Dodge Challenger R/T in Brilliant black - 392 cam,AFR shaker, MyGig 730N w/ navi,dvd,HD,u-connect & rear cam, 6 spd, Track Pak, SRT8 shorties & mids, DS Predator, Jet 180*, BBK 85mm tb, SLP line locks, de-badged, resonators removed, DRL enabled, skip shift eliminator, mopar hood struts, functional hood vents, 392 chin spoiler
09 Suzuki 1255S Bandit Metallic Blue on black, 1255cc I-4, 6 spd, Yoshi can, Givi screen, K&N, Bags Connection tank bag, TPX fuzz buster, Techmount GPS holder, Suzuki center stand, World Performance Seat
2013 Dart Limited Pitch black, fully loaded, hers
SOLD 06 Hemi Durango 4x4 Limited in Atlantic Blue Pearl
SOLD 97 Ram 1500 SLT Laramie in DuPont Frost White Pearl
chizzle1 is offline
post #12 of 13 Old 09-02-2006, 11:25 AM
Loud_Dodge
Loud_Dodge's Avatar
Careful Guys! Mine was making a whining noise to and it ended up being the throwout bearing on my tranny. I have a 5-speed manual. It made the whining for a few months and then one day after slowing down from 65 or so to make a turn i pushed in the clutch and a horrible screeching noise started. I let the clutch out and it stopped. Pushed the clutch in again and it screeched. Then when I let it out it didnt matter, the screeching would not stop. So I just bought a clutchkit from autozone and replaced everything myself. After that, no whining at all. Dont know if that could be a problem with automatic tranny's, but just a headsup.
Benny
2010 Ram Hemi Sport
Loud_Dodge is offline
post #13 of 13 Old 09-12-2006, 10:13 PM Thread Starter
DODGEIT
DODGEIT's Avatar
Quoted: 1 Post(s)
Well after another trip to the repair shop the noise is finally gone. They pre- loaded the pinion bearing some more and that seemed to take care of it. Heading out tomorrow (9/13/06) on my trip. We will see how it goes.
DODGEIT is offline
    2005 stratus sedan 2.4v whining noise zinn21 2G Dodge Stratus - Performance Talk 0 04-04-2006 11:04 PM
    loud whining noise Ironram 2G Dodge Intrepid - Performance Talk 0 02-06-2006 10:14 PM
    93 Dodge Caravan Whining Noise w/rmps mt74_98 Dodge Caravan General Talk 2 01-16-2006 09:56 PM
    Whining Noise when accelerating at 50 MPH MICHAELGRANT 2G Dodge RAM - General Talk 6 04-05-2004 05:52 PM
    AC whining noise TXDSS 3G Dodge RAM - General Talk 1 05-16-2003 06:50 PM
