no overdrive ? 1990 ram 350 van - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
Go Back   DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums > Dodge Truck, SUV and Van Forums > Dodge Van and Cargo Truck Forums > Dodge B-Series Vans 1971 - 2003
edward.p.harris
  no overdrive ? 1990 ram 350 van - Posted: 06-20-2006, 06:06 PM
Post #1
3000 rpm @ 60 mph, overdrive light switches on and of but no shift, my low idle also seems higher, the van wants to strain while sitting at lights, and i lost my cruise control. I'm getting error message 37 - shift indicator light failure or part throttle lock/unlock solenoid driver circuit or solenoid coil circuit, and 41 - alternator field control circuit open or shorted. could any of these problems be connected? Could the shifting problem be with the lockup torque converter? I recently had an alarm w/remote start installed, took it back and they dont think it's related to what they did, ( they were pretty thorough but mostly look for wires that may have come loose. this is a 1990 Ram van 350 that had been converted into an ambulance, but i dont think that effects these problems, the 2 systems seem to be well isolated. Thanks to any and all replies.
Dodgevanman
 Posted: 06-21-2006, 06:05 AM
Dodgevanman's Avatar
Do It In A Van
City: Baltimore Hon!
State: MD
Post #2
Even with the OD switch off, you should have lockup in after it goes into 3rd gear. See if it does.
There is an overdrive solenoid inside the transmission that kicks the OD in an out with the switch. You could have a bad wire somewhere or solenoid is bad. Not sure of the test for this right off the top of my head.
Nate the skate
5.2L Magnum
1972 B200 Royal Sportsman Maxiwagon
318/2bbl.
1985 B150
318/2bbl.
Member of:
Old Line Vanners
Interstellar Space Truckers
SouthEast Van Council
A-100 Van Association
Honorary Canadian as bestowed upon me by Van Clan plus One
mgrenia
 Posted: 08-15-2006, 09:19 PM
City: Dunsford, Ontario
Post #3
With that 41 code check the voltage with a DVM at the battery with the engine running. You're probably going to find that your voltage is too low (probably right at 12 to 12.5 volts). A healthy charging system should be around 14 volts at the battery with the engine running.
If this is indeed the case, get your wallet ready, you'll be replacing the ECU as that is where the voltage regulator is located and it's not replaceable.
I have had the same (and more) problems. The fine people who use this forum have told me that proper voltage is critical. Without it the ECU may be picking up codes that are false because of bad voltage.
Good luck and let me know what happens.
RamVanMan
  Thumbs up Back to you Edward.... - Posted: 08-18-2006, 11:21 PM
RamVanMan
City: Nacogdoches, TX
Post #4
A few random thoughts on your troubles that might help:
As regards what the fellow just said re the new ECU, also consider that just a weak / 'beginning to short out' battery might be the culprit.
I just had a low voltage problem - where I thought the alternator was faulty, turned out it was a battery less than a year old. This van has tons of built ins - its a conversion van - and only one battery - the starting battery -so it gets tons of use & abuse.
Made it fail in 10 months - Wal Mart gave me a new one for $ 0.
So, check that battery, if faulty it could mimic a bad regulator / ECU - PCM.
BTW, disconeecting your battery negative for a minute should reset your trouble codes, so at least you can see if that changes things, even if only temporarily.
Let us know how you fare,
David B.
RamVanMan
PS: when my '96 B-2500 runs hot (I think this is what causes it...), my OD won't kick in even if I press the dash switch, it still glows. If I stop and turn off the engine and disconnect my negative cable momentarily, it functions normally again. I have a 'quick disconnect' battery negative, so it's easy to do.
1996 Ram Van B-2500 Conversion Van - 318, Electric Engine Cooling Fan - "The Family Bus"
1997 3500 Cummins Ram Truck - 19.5 wheels, pacbrake, Gearvendors OD - "Pocket Peterbuilt"
Tyranny Rising ? The answer to 1984.....is 1776 !
"Evil is powerless, if the good are unafraid."
Ronald Reagan
"You never have to give up an ounce of Liberty to obtain security."
Ron Paul
"Stand fast, therefore, in the Liberty wherewith Christ has made us free, and be not entangled again in the yoke of bondage..." - Galatians 5:1
2006 Ram 1500 Info FreeLantz 3G Dodge RAM - General Talk 120 02-20-2006 12:09 AM
Swapping 318 with EFI into a 1990 Ram Van dani9678 Dodge Ram Truck 1st Gen (88 - 93) Forum 2 04-25-2004 11:42 PM
Chrysler Group Announces 2003 Model Year Pricing RAM MAN Mopar Vehicle Talk 0 10-08-2002 06:37 AM
Overview - 2003 Dodge Ram Heavy Duty RAM MAN 3G Dodge RAM - General Talk 4 09-29-2002 12:09 AM
new Ram packages RAM MAN 3G Dodge RAM - General Talk 7 09-02-2002 02:31 AM
