Thread Tools |
Have these torsion bars being cranked?
- Posted: 06-10-2006, 01:41 AM
Post #1
Hey, what is the stock torsion setting, I guess, how do I know how much these have being cranked from stock (aprox). Measurement from wheel centre to top of fender of a stock would work for me. Thnaaks
Great site, good info, good guys! LOVE anything motorized!!! 6 motorbikes (4dirt, 2street) 2004mxz Renagade 800 (big sled head) Hot rod/musle car intrests 2000 concorde LXI (wifes ride) Past rides: 96 Dodge ram15004x4 95trans-am 5.7/6spd 91 Celica turbo/allwheel |
| Sponsored Links | |
Advertisement |
Posted: 06-10-2006, 07:13 AM
Post #2
37 3/8 from ground to fender
2005 1500 4x4 quad cab- 20's Hemi oem 4"oval nerf bars sirius radio power,heated tow mirrors led's in cubby and int lights access lorado tonneau viper 1 mile starter 12 v outlet in bed 3 turns on t.b. silverstars power wire hellas in the grill Ride rite air bags 275-65-20 ATS wranglers bilsteins magnaflo ---------------------------------------------------- WHITE TRUCK CLUB MEMBER #43 |
Posted: 06-10-2006, 09:19 AM
Post #3
to my understanding, there is no firm stock torsion setting.. it all depends on how they were set at the factory.. just measure the rear from the ground (or center of the rim) to the feneder cut out and do the same for the front....
2004 DODGE RAM Q/C HEMI CNG/GASOLINE |
Posted: 06-10-2006, 04:26 PM
Post #4
Should be close to 2 inches difference from front to rear.
Posted: 06-10-2006, 09:52 PM
Post #5
Ride height for Ram 1500 4x4: To be performed with vehicle supporting it's own weight & taken on both sides.
1. Measure height from ground line at the centerline of the rear lower control arm bolt front tip. 2. Measure the height from the ground line at the front spindle centerline (Static load radius). 3. Subtract the first measurement from the second measurement. The difference between the two measurements should be 58 mm (2.3 inches) +/-3mm (.12 inches). 4. If value is greater than max. (61 mm), tighten torsion bar. 5. If value is less than min. (55mm), loosen torsion bar. 6. Repeat previous steps until ride height is within specs. Procedure is also listed in the service manual, Wheel Alignment 2-3.
2003 Ram 1500 4x4 RCLB 5.7l HEMI Patriot Blue Pearl Coat Laramie Package |
| Thread Tools | |
| 315's with Cranked Torsion Bars | enash | 3G Dodge RAM - General Talk | 2 | 03-03-2006 05:47 AM |
| Has anyone cranked up their torsion bars... | lsigrandson | Dodge Dakota 1st Gen (87 -96) Forum | 10 | 12-03-2005 12:52 AM |
| Cranked up the torsion bars, check it out! | acjrocks | 3G Dodge RAM - 4X4 Talk | 69 | 08-04-2005 02:48 PM |
| Got my torsion bars cranked | Byron | 3G Dodge RAM - 4X4 Talk | 3 | 05-18-2005 08:07 AM |
| Torsion bars cranked NEW rack & ball joints | mb190e | 3G Dodge RAM - General Talk | 1 | 11-18-2004 11:47 AM |
Privacy Statement | |
