Go Back   Dodge Talk Community Forum > Dodge Truck, SUV and Van Forums > Van and Cargo Truck Forums > B-Series Vans 1971 - 2003
jbirdmotox
  Couple questions - 96 1 ton 15 passenger Van - Posted: 06-07-2006, 03:03 PM
Post #1
Hello, I just bought a 96 1 ton 15 passenger van. It does not have a "tow" package but I believe, from what I've seen, it has a transmission cooler mounted to the front of the radiator.
Could someone tell me if a cooler was standard of a van of this type?
Also, when driving over small sharp bumps or road imperfections I am hearing a thumping/rattle from the left front. I don't feel anything in the wheel just hear the noise. I assume it's a ball joint or bad shock or ???. Whats the best way to jack the beast up to check for this? From the frame? From the bottom of the front suspension?
Thanks, Jon
Registered users do not see this ad or IntelliTXT ads. Please Register today! Its quick, easy and free!
stev
 Posted: 06-07-2006, 10:23 PM
stev's Avatar
Seating for 12
City: Near Niagara Falls
State: NY
Post #2
Jon,
All of the 2nd Gen Dodge Ram Vans got the tranny cooler.
As for the bump in the night ... Oh, the thump/rattle from the left front, just crawl upder the van. No lifting is needed. These vans are already high off of the ground to take a quick peek. A nice large sheet of cardboard helps too.
My thumping/rattle was the heat shield that compliments the dog-house underneath. Check that first. It's a simple fix with thick wide washers. The aluminum nuts may look corroded, but they are not. The come off easy.
Other than that, some of the other people will chime in too.
I got the 12-passenger B2500. One less bench seat than yours.
Welcome to the forums, stick around, and visit often.
Stev
2000 Dodge-Ram-B1500 V6 3.9L, 3.55:1, RoadMaster MKII-XF -SOLD-
2001 Dodge-Ram-B2500 V8 5.2L, 3.92:1, RoadMaster MKII-XXF
1982 Coachmen Cadet 19-1/2 3000# Towable Camper
*DodgeTalk.com 318 Enthusiast Member #(50)*
*DodgeTalk.com Ram Van/Wagon Member #(1)*
gower3544
 Posted: 06-07-2006, 10:27 PM
gower3544's Avatar
I Love My Van!
State: OTHER
Post #3
Thanks, Jon
I am actually getting my van checked for this same exact problem on Thursday and whatever they tell me I will try to post it as soon as possible. They suspected maye it was a shock.
Dodgevanman
 Posted: 06-08-2006, 07:00 AM
Dodgevanman's Avatar
Do It In A Van
City: Baltimore Hon!
State: MD
Post #4
My '94 doesn't have an auxillary trans. cooler or the HD radiator.
What you have may have been standard on the one-ton 15-pass. maxi vans.
Have your ball joints checked...what happens is that the upper ball joints tend to be forgotten about when the chassis is lubed during an oil change.
Nate the skate
5.2L Magnum
1972 B200 Royal Sportsman Maxiwagon
318/2bbl.
1985 B150
318/2bbl.
Click HERE to view the complete signature...
jbirdmotox
 Posted: 06-08-2006, 08:23 AM
Post #5
Thanks for all the replys. I will be towing a camper with the van so I'm glad it already has a tranny cooler.
I will also check the on the heat shield. I hope it's that easy of a fix. I have crawled under there a couple times and even jacked up the front end by the bottom of the shock and felt or saw no obvious movement or worn parts. I just grabbed the front tire and tried to move things up and down/ side to side.
It almost sounds like at this point it could be broken shock....
Jon
gower3544
 Posted: 06-08-2006, 12:06 PM
gower3544's Avatar
I Love My Van!
State: OTHER
Post #6
Hey went to our Dodge dealer today to get trans fluid changed and get the moise in our left front checked. They diagnosed the problem as Rotor Worpage and they said they (i guess) would rotate the rotors or something like that. But of course always check and do trial & error to determine your problem as it could be totally different.
stev
 Posted: 06-08-2006, 12:08 PM
stev's Avatar
Seating for 12
State: NY
Post #7
jbirdmotox,
So you're a Ram Van towing a camper man! Same here. Check out www.RV.net/forums as well. I go by the same name there too. Acutally I go by the same name in every forum I belong to.
Stev
jbirdmotox
 Posted: 06-08-2006, 12:16 PM
Post #8
Yep, I will be towing a 1996 25' Sunline camper with a 2003 KX250 dirtbike in the back of the van. I just ran the wires and hooked up my Prodigy brake controller/7 pin harness last night.
I spend a bit of time on rv.net. It's a great site.
stev
 Posted: 06-08-2006, 02:18 PM
stev's Avatar
Seating for 12
State: NY
Post #9
jbirdmotox,
Do you have the 5.9L or 5.2L in that van?
Stev
jbirdmotox
 Posted: 06-08-2006, 02:26 PM
Post #10
5.9
kcollett
  96 - Posted: 06-08-2006, 04:15 PM
State: AZ
Post #11
I have a 96 3/4 ton van with the same noise. It was the brake calipar holder. It was broken. It took us nearly a year to find it and wasnt till the calipar fell off and locked up the wheel when we did. On inspection the other side was ed and needed to be replaced also.
Dodgevanman
 Posted: 06-09-2006, 07:29 AM
Do It In A Van
State: MD
Post #12
The caliper bracket was broken? Man that is pretty stout steel and surprised it broke. I wonder what caused it.
Nate the skate
5.2L Magnum
318/2bbl.
1985 B150
318/2bbl.
kcollett
 Posted: 06-12-2006, 12:51 AM
State: AZ
Post #13
I wonder if it had anything to do with the really rough road I live on . Dont you think this has however been the best vehicle I have ever owned. Love it so much i put a new complete power train to take it another 10 years.
jbirdmotox
 Posted: 06-12-2006, 08:44 AM
Post #14
Well, I figured out what the noise is. It's the caliper bracket/caliper. There is about 1/16 " play between the the caliper and the bracket. One or the other is worn. I looked at the bracket very closely and didn't see any cracks etc. It is made out of very thick steel to be sure. I made a temp. shim to take up the gap and the noise was gone.
What to do next I have no idea. With my luck I would buy a caliper and it would be the bracket. Although, I would think both part could be had for not too much cash???
Jon
"New" van... some questions myfreevan B-Series Vans 1971 - 2003 3 03-06-2005 11:07 AM
1974 Dodge B300 1 ton Van is stalling Vexxed Boy B-Series Vans 1971 - 2003 8 11-23-2004 11:55 AM
1997 Dodge 1/2 ton van problem dbach Other Dodge Vehicle Talk 0 02-11-2004 08:07 PM
Old Dodge Van Ambulance Questions john wells Other Dodge Vehicle Talk 0 09-02-2003 03:01 PM
1994 and a 1999 dodge van 1 ton rearend wally04345 Other Dodge Vehicle Talk 0 04-02-2003 07:06 PM
