318 won't start - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 18 Old 05-30-2003, 07:43 PM Thread Starter
vandle835
318 won't start
any ideas - if I use starter fluid or a little gas in the carb it will fire but stop immediatly. truck does have an ignition electrical problem, i start it under the hood, but this ould not seem to effect the start because it does turn over. could it be a fuel problem? what should i check first and how do i tellif thinks are bad?
vandle835 is offline
post #2 of 18 Old 05-30-2003, 07:48 PM
speeddragon190
check the fuel filter. if it's clogged bad enough, it could keep the fuel from flowing.
More projects than I know what to do with!
72 D100, Project R/T 100, aka "Timex", check it out at:
73 D100 Club Cab shortbed Adventurer, 360 2-bbl, 727 auto w/ bolt-on yoke
71 W100 big block 4x4 project
84 D50 Sport Ram, 2.6 turbo 5-spd swap in progress
87 Shelby GLHS, #392, 2.2 T2 Intercooled
89 Lebaron, swapping to supercharged 3.0 5-spd, aka "The Red Baron"
88 Conquest TSI, black on black leather, sunroof, 2.6 turbo 5-spd, 50k original miles
89 Conquest TSI, black on black cloth, rebuilt 2.6 turbo auto, 88k original miles
86 Turbo Z Daytona, 2.2 T1, 5-spd, red on black cloth, sunroof, rear louvers
84 Shelby Charger, parts car, 2.2 5-spd
85 Conquest TSI, parts car
speeddragon190 is offline
post #3 of 18 Old 05-31-2003, 12:19 AM
WARLOCK
WARLOCK's Avatar
Quoted: 8 Post(s)
I don't wanna be a smart***, but you got gas in the tank?
Pull the fuel line off of the carb, and 'bump' the motor over a couple times to see if your getting fuel that far. Just remember to wipe the fuel up before you actually fire the truck up,,, could be ugly other wise
Rusty
DodgeTalk.com
Member #(77)
DodgeTalkAholics #77
RIP
2005 Dodge Magnum R/T
Been Hammered and Diablo Predator.
Pedderized
KSport coil overs
R1 Concept drilled and slotted rotors
To join the Official Dodgetalk Member Map, click
WARLOCK is offline
post #4 of 18 Old 05-31-2003, 10:20 AM
speeddragon190
i don't want to be a smart-a**, but you got gas in the tank?
trust me, that's not be a smartass, i've asked that same question plenty of times, and occasionally been asked myself and that was the problem you wouldn't believe how many times.
post #5 of 18 Old 06-29-2003, 02:46 AM
Bullsnake69
I was having the same problem so thinking it was the fuel pump I replaced the fuel pump. Still no start. I replaced the fuel filter on the engine. Still no start. I went and disconnected the gas line about halfway between the tank and engine. No gas poured out. So now I have to take the sock filter out of my tank and see if that is the problem. To get to that part of the tank I have to take the bed off though.
Bullsnake69 is offline
post #6 of 18 Old 06-29-2003, 10:06 AM
WARLOCK
WARLOCK's Avatar
Quoted: 8 Post(s)
trust me, its easier to take the bed off then to drop the tank.
Rusty
DodgeTalk.com
Member #(77)
RIP
Pedderized
KSport coil overs
WARLOCK is offline
post #7 of 18 Old 07-02-2003, 01:46 PM
Bullsnake69
To be honest with ya, I see no way to drop the tank without taking the bed off. The nut is hidden in the frame rail and you cant get to it with anything
post #8 of 18 Old 07-07-2003, 12:52 PM
oldschoolmuscle
inside your mind with ls1
what year is your truck ? carb or fi
oldschoolmuscle is offline
post #9 of 18 Old 07-09-2003, 01:46 PM
mopar89ram
mopar89ram's Avatar
Quoted: 1 Post(s)
I am also in the process of removing the gas tank. I have a 89 ramd100. you can drop the tank without taking the bed off,but I wouldn't recoment it. If you need any help just ask. I had to replace the pump and the sending unit.
mopar89ram is offline
post #10 of 18 Old 07-11-2003, 02:20 PM
psycho_maniac
!!!Ram Power!!!
psycho_maniac's Avatar
hey now my truck wont start. but instead if i dump gas down the carb pump it and boooooom it fires and stays runnin. what is my problem. also one question do u get spark if u dont get gas? dont be mean.
psycho_maniac is offline
post #11 of 18 Old 07-13-2003, 12:49 PM
81 ram
i had the same problem with my truck all i did was siefin some gas outta the tank and replaced the fuel filter and it starts fine now
1981 dodge ram d150 custom (in the works)
slant six power baby - now swapped to a 318
past mopars:
1989 dodge caravan
1978 plymouth volare
81 ram is offline
post #12 of 18 Old 07-13-2003, 03:18 PM
pyssed
pyssed's Avatar
Yes, your plugs fire even without gas.
2001 quad cab sport 5.2l
supercharged
Just the facts
pyssed is offline
post #13 of 18 Old 07-13-2003, 07:32 PM
WARLOCK
WARLOCK's Avatar
Quoted: 8 Post(s)
might also be a bad float in the carb also
Rusty
DodgeTalk.com
Member #(77)
RIP
Pedderized
KSport coil overs
WARLOCK is offline
post #14 of 18 Old 07-15-2003, 07:28 PM
speeddragon190
psycho,
sounds like the accellerator pump in your carb is bad. either that or you have a fuel evaporation problem, or possibly a weak fuel pump.
post #15 of 18 Old 08-12-2003, 08:18 PM Thread Starter
vandle835
on my 77 all it took was a few well placed hammer taps on the carb to get it going again
thanks all of u for the help
Daily drivers
2000 chevy tahoe ls
1999 volvo V70
The Beast
1977 Dodge M880 or in non military a W-200. IT has 85 w250 Grill, Hood, front fenders,and ds door
post #16 of 18 Old 08-14-2003, 02:37 PM
speeddragon190
needle and seat must have been stck, or the float one.
post #17 of 18 Old 09-03-2004, 09:15 AM
james.speed
I Did All The Same Stuff You Did For My W-100 New Mech Fuel Pump New Fuel Filter Took Off Lines Between Tank And Fuel Pump No Gas In Line, Put Gas In Carb It Fire Up And Then Stop. The Problem For Me Getting Fired Up So The Pump Would Pump Faster And Draw The Fuel From Tank To The Carb. Starting Fuel Does'nt Work As Well As Gas In Carb, To Honest I Would Try Again Before You Take Your Shit Down To Parade Rest.
james.speed is offline
post #18 of 18 Old 09-06-2004, 10:38 PM
dodgensince74
Quoted: 11 Post(s)
i had about the same problem on my 86 once, i disconnected my fuel line as close to the carb as possible and used my air compressor to blow in to the line to see if i had a leak in it and did have one. When you disconnected your fuel line did you see if you were getting any pressure at the open end? I don't know if you have a mech. pump or electric but with either one you should feel some pressure on the open end. Good luck.
dodgensince74 is offline
