Have you done: "Transmission throttle pressure adjustment" procedure ?
- Posted: 06-05-2006, 02:02 AM
Post #1
Hi all,
I was just informed by Dan Arcand, 'TheFastman', that my transmissions persistent tendancy to hunt in 3rd gear might be due to it needing a 'Transmission Throttle Pressure Adjustment'. Has any one done this ? I'd not really heard it recommended yet -- It appears to be adjusting a cable at the throttle body that sends a signal to your trans telling it to do several key things, like proper: Line pressure, shift timing and kickdown point. Attached is the pdf document on how to do this - it covers a 1999 Ram Truck with 5.9 but it must cover our vans too - engines and trans are identical. Curious to hear if you alread knew about performing this procedure Take Care, David B - Ram Van Man ![]()
1996 Ram Van B-2500 Conversion Van - 318, Timbren Susp, Dual Electric Engine Cooling Fans - "Family Bus" 1997 3500 Cummins Ram Truck - 19.5 wheels, jake brake, 2 spd rear, 380 hp / 800 ft lbs - "Pocket Peterbuilt" Favorite Quotes To Ponder: Samuel Adams, on signing the Declaration of Independance: "We have this day restored the Sovereign to Whom alone all men ought to be obedient. He reigns in heaven above, and from the rising to the setting sun, may His Kingdom come." William Penn: "Men who will not be governed by God, are destined to be ruled by tyrants." Click HERE to view the complete signature... |
| Sponsored Links |
Posted: 06-05-2006, 06:49 AM
Post #2
My '94's cable set-up is just a bit different, but the adjustments are the same. I may try that trick. I hate the early and mushy shifts that my transmission has (A518/46RH).
Nate the skate ![]() 1994 B250 Ram Van Conversion by Elk 5.2L Magnum 1972 B200 Royal Sportsman Maxiwagon 318/2bbl. 1985 B150 318/2bbl. Click HERE to view the complete signature... |
Posted: 06-06-2006, 10:46 PM
Post #3
Dave,
I recently had to adjust the cable from the TB to the tranny on a Honda Civic with 153k miles for a co-worker. The car had a very bad shudder/vibration when the idle dropped below 1k-rpm. We adjusted the cable and added four thick washers. Now the car idles smoothly just a hair over 1k. My co-worker had the car into three other Honda dealerships and couldn't get it fixed. Honda mentioned that they could not reprogram the electronics for a higher idle. It would then be out of spec and not pass some legal electronic controls. So, I searched the internet and found a Popular Mechanics article that walked us through the repair just for the Honda Civic dealing with the cables. Grant it, it was for a model year three years back for his model, but it still solved the problem. ![]()
2000 Dodge-Ram-B1500 V6 3.9L, 3.55:1, RoadMaster MKII-XF -SOLD- 2001 Dodge-Ram-B2500 V8 5.2L, 3.92:1, RoadMaster MKII-XXF 1982 Coachmen Cadet 19-1/2 3000# Towable Camper *DodgeTalk.com 318 Enthusiast Member #(50)* *DodgeTalk.com Ram Van/Wagon Member #(1)* |
Posted: 06-06-2006, 11:01 PM
Post #4
Great post David - I read about this before and seen some blurry pics, but that PDF is clear and concise
Thanks man ![]()
__________________ ED 98 RAM 1500 SLT QuadCab 4x4 360/AT 86 Shelby GLHS ** How to: Changing Ball Joints on 2nd Gen Ram ** How to: Use DT's search feature ** How to: Posting Pics on DT |
| Sponsored Links |
Post #5
Thanks for the feedback you guys ! Sounds like we may be 'barking up the right tree' !
Yeah, Ed isn't that a nice pdf Doc that Dan Arcand 'the fastman' sent me ? I'm getting to be fan of his already - I laid out my trans malfunctions to him, telling him I'd be willing to buy any thing from a TC solenoid to a reworked valve body to a whole built trans, and he replies that it's probably just a simple adjustment - while sending concise instructions. Sounds like a guy who's got the opposite ethics of say, many a transmission shop ! Honest and fair ! Very refreshing ! Stev, good to hear your experience of the same type of adjustment on the Honda - wasn't too hard, eh ? But the dealerships have become mainly 'parts changers' (sad to say), so look what you did, that they couldn't ! Bet your buddy was thrilled at the job - Bravo ! (Stev, I got your email and enjoyed it very much -did ya get mine, too ?) I'm going to wait until my 'Fastman TB' arrives until I do the TV cable adjustment, because they're right there together - best done at the same time. I dropped by Harbor Freight today and got an inch-pound torque wrench to do the trans band adjustment - Dan said it was maybe both - TV cable and/or Trans band adjustment, so I'll do 'em both. When done, I'll give a report right here.....stay tuned. David B. ![]()
Posted: 06-07-2006, 07:48 AM
Post #6
Dave,
Got your e-mail. It was very refreshing indeed. Stev
| Thread Tools | |
| 2 Misfires in 1.5 years | jenstrom | Caravan Talk | 8 | 06-18-2008 02:35 AM |
| Anyone know where I can find out what this code means? | Bagged02 | 3G RAM - Drivetrain Talk | 12 | 07-19-2006 06:38 PM |
| Check Engine code 2002 3.3 engine | login | Caravan Talk | 5 | 04-19-2006 11:49 AM |
| Engine Codes P0336, P1693 ?? | kg1216 | Diesel Tech | 12 | 04-21-2005 10:24 AM |
| Sponsored Links |
