Posted: 09-03-2007, 03:05 PM
Post #161
OK, got my kit installed yesterday afternoon. Did it on the truck and it went slow because I've never dealt with steering before and I was working off a faxed set of instructions instead of nice color printouts. However, if I had to do another installation today I could probably do it in 30 minutes, depending on how fast the spring came off.
Anyways, bottom line is the kit completely fixed the snap crackle and pop in my steering. Good as new. I recommend this fix to anyone who's steering isn't quiet and smooth. An outstanding $60 investment.
1998 Ram 1500 ClubCab ShortBox 4x4 360 Auto, 67K Miles, 3.90 gears, LSD, Intense Blue, Remote Starter, Pioneer stereo, 180° Thermostat, APS Precision Billet Plenum Pan (w/ Swain Tech Thermal Barrier Coating), DynoMax 3" Cat-Back, Edelbrock Performer IAS Shocks, Michelin LTX A/T Tires, Powerslot Rotors, Hawk Performance pads, Skylite Spoiler Sunroof, Rhino-Liner bedliner, Hellwig Rear Load Pro Helper Springs, Hellwig Sport Tech Rear Anti-Sway Bar, Mopar Step Tubes, RamVanMan's Steering Fix... |
| Sponsored Links | |
Advertisement |
Posted: 09-03-2007, 03:24 PM
Post #162
I'd like to have one but seems as if no one can get in touch with him.
Jesus, family, me. Psalm 121 Red Pill Mille Clip ATGATT Swag #1 - '02 Durango 4.7 4X4 89k Swag #2 - '01 Aprilia RST 1000 Futura Swag #3 - '06 GSX-R 1000 Streetfighter What do you add to powdered water? |
Posted: 09-03-2007, 04:01 PM
Post #163
Try this e-mail address: dbazley@rocksolidramtrucksteering.com
Posted: 09-05-2007, 10:29 PM
Post #164
Glad to hear you got it installed AOK - even if the faxed instructions weren't quite the same, you did great. It's not hard, really.
It just feels weird because you can't see the defective part - it's hidden up inside the lower end of the column outer shell - until you cut that retainer, pull of the spring, then pull the worn parts out, then it all makes sense. The stock part that gets worn and allows noise to occur is a cheap looking bearing that sits in a metal or plastic cup (Dodge used both types here & there). This bearing is so chinzy you wouldn't expect it to work on your daughters roller skate, let alone to steer our trucks. Anyhow, throw that stuff away and put in our retrofit unit and you're good to go. BTW, I'm answering all emails usually the same day, sometimes in an hour or two. I'll also attempt to stay abreast of comments here on the forum boards, of course ! I appreciate your patience - we're but a humble enterprise - but we aim to please you by shipping the kits out that you decide you need. Mecgmecg, appreciate your report on how the job went. Happy Steering. David B. www.RockSolidRamTruckSteering.com
1996 Ram Van B-2500 Conversion Van - 318, Electric Engine Cooling Fan - "The Family Bus" 1997 3500 Cummins Ram Truck - 19.5 wheels, pacbrake, Gearvendors OD - "Pocket Peterbuilt" Tyranny Rising ? The answer to 1984.....is 1776 ! "Evil is powerless, if the good are unafraid." Ronald Reagan "You never have to give up an ounce of Liberty to obtain security." Ron Paul ![]() "Stand fast, therefore, in the Liberty wherewith Christ has made us free, and be not entangled again in the yoke of bondage..." - Galatians 5:1 |
Posted: 09-06-2007, 09:48 AM
Post #165
Ok, I just ordered mine.
Posted: 09-06-2007, 10:31 PM
Post #166
Awesome fix, I have no clunk but I can feel some slight play in the last few days.
83K miles
"The search for truth is more precious than its possession." - Albert Einstein |
Posted: 09-13-2007, 09:16 PM
Post #167
Got mine in today and after looking over the instructions, looks quite simple.
I'll jump on this right after I get back from Auburn on Saturday.
Posted: 09-14-2007, 03:46 PM
Post #168
Alright Fox Fader...glad to hear that you got your part, we all look forward to seeing and hearing how things went when you do the install.
Posted: 09-19-2007, 05:50 PM
Post #169
Got it done yesterday, quite simple to do. Feels better, no more clunk. Steering a little tight though.
Posted: 09-20-2007, 10:58 AM
Post #170
I greased up the inside of my bushing from the kit with wax that you lube a bike chain with. Worked great and the steering didn't feel tight at all. Might be a good addition to the instructions.
Posted: 09-20-2007, 11:51 AM
Post #171
I was just about to grab my chain lube when I though I better follow the directions, but I was wrong. I used grease, but it apparently is not good enough. I emailed for some help cause I believe the bushing will get destroyed upon removal. I don't wanna dis on his merchandise, but the longer it takes to get help well.......
Posted: 09-20-2007, 11:58 AM
Post #172
I've read that other guys in this thread had the same problem as you. But, it seems that simply driving for a while will get the bushing to loosen up it's grip on the shaft and the steering effort returns to normal.
Posted: 09-20-2007, 03:16 PM
Post #173
Well I sure hope it does.
Posted: 09-20-2007, 03:46 PM
Post #174
What was the stuff that you used on yours? I am waiting for mine to show up and I would rather have to go purchase some of that than have real stiff steering for a few weeks. Blake.
*DodgeTalk.com 318 Enthusiast Member #(15)* 1998 QC Ram 1500 5.2l - Flame Red/Driftwood Red Truck Club Member #13 We use 43 muscles to frown, 17 to smile, and 2 to pull a trigger. I'm lazy and I'm tired of smiling. |
Posted: 09-20-2007, 04:28 PM
Post #175
You can go to walmart and get motorcycle chain lube, a white water-proof spray.
And I would spray the whole shaft and the inside of the bushing well.
Posted: 09-20-2007, 04:49 PM
Post #176
Cool, thanks.
Posted: 09-26-2007, 07:16 AM
Post #177
06 Ram 1500 Quad Cab Black Big Horn Edition 5.7l Hemi 4x4 with factory 20"s Leveled 5100 Bilstien Leveling Shocks
Posted: 09-26-2007, 09:02 AM
Post #178
It takes a lot less time to do it on the truck. It's cramped quarters in there because of the brake booster, but it can be done.
Posted: 09-26-2007, 11:40 AM
Post #179
That is what I was hoping. I really don't want to take the dash apart since that always starts another round of squeaks that you have to find.
Posted: 09-27-2007, 04:47 PM
Post #180
Did mine column in.
Good news, it has loosened quite a bit. Bad news, now that it's loose it seems to be doing the clunk again, but only a fraction of they way it was before... or is it my imagination?
| Thread Tools | |
| Dodge Reveals New 2006 Ram 1500 | FreeLantz | Rumor Mill & Gossip Talk | 60 | 06-08-2006 08:58 PM |
| 2006 Dodge Ram 1500 Information | RAJ | 3G Dodge RAM - General Talk | 20 | 06-18-2005 12:18 AM |
| Legendary Dodge Ram Power Wagon Returns | RAM MAN | Rumor Mill & Gossip Talk | 4 | 10-02-2004 05:44 PM |
| 2004½ Ram Diesel - 325hp / 600ft-lb | dodge_em | Diesel Tech | 45 | 07-13-2004 09:39 PM |
| 1999 Durango 48k - Should I buy??? | jasonl57 | 1G Dodge Durango General Talk | 6 | 02-27-2004 07:48 PM |
Privacy Statement | |
