Thread Tools |
Post #1
Hey 2nd Gen guys:
I was wondering how many here have had that annoying steering wheel / column 'clunk / rattle' develop in their trucks. My '97 Ram 4x Cummins developed it and it was totally annoying - I replaced most all the front end components and it still had the steering column clunk. I know the guys over at the Turbodiesel site have agonized over this, and suspect that the same trouble prone column is in most 2nd gen Ram Trucks - regardless of engine configuaration. Anyhow, I just developed a fix with a machined Nylon / Delrin bushing and would be happy to share how I did it here, or offer them, once we develop it a bit further. It totally transformed how my Ram steers - which surprised me. I was just trying to get rid of the 'clunk' - little did I know just how much the lower column bushing failure was allowing WAY excessive play, which made the steering vague & imprecise. Now, the truck steers with rack & pinion precision - Amazing ! When you consider this can be done at a fraction of the cost of a new column from Dodge $ 700 ea, for the same (defective) design, it only makes sense. Anyhow, I can post pics & procedure (still doing research, don't know what cost will be - pretty cheap), but it would help to get some feedback first, so to the original question: I was wondering how many here have had that annoying steering wheel / column 'clunk / rattle' develop in their trucks ? If so, please give: year, engine, trans, miles and any thing else you think relevant.... Thanks guys ...I'll post more once you give some feedback......take care David B. Ram Van (& truck) Man ![]()
1996 Ram Van B-2500 Conversion Van - 318, Electric Engine Cooling Fan - "The Family Bus" 1997 3500 Cummins Ram Truck - 19.5 wheels, pacbrake, Gearvendors OD - "Pocket Peterbuilt" Tyranny Rising ? The answer to 1984.....is 1776 ! "Evil is powerless, if the good are unafraid." Ronald Reagan "You never have to give up an ounce of Liberty to obtain security." Ron Paul ![]() "Stand fast, therefore, in the Liberty wherewith Christ has made us free, and be not entangled again in the yoke of bondage..." - Galatians 5:1 |
| Sponsored Links | |
Advertisement |
Posted: 06-04-2006, 03:09 PM
Post #2
intermidiate steering shaft
Details.....
- Posted: 06-04-2006, 03:31 PM
Post #3
In my case, I replaced my worn out OEM shaft with a Borgeson. Steering was tighter, but the 'clunk' grew worse......the steering column lower end bushing is tensioned by a spring that fits over the Primary steering shaft / column section - (the one that protrudes through the firewall). If you reach in and twist this 'tension spring' it can sometimes make the 'clunking' go away for a while - this is a good test to see if this is the source of the noise. Here's a some pics (manual trans Ram), showing how it looks stock (with spring) and after bushing installation:
Posted: 06-04-2006, 03:39 PM
Post #4
It is worth a shot, I am sick of the clunk. 01 Ram 1500 Off Road, 5.9,Auto Tranny, 81k miles...
2001 Ram 1500 Off Road VT GO HOKIES VT |
Posted: 06-04-2006, 07:17 PM
Post #5
I've gotta 98 Ram 4x4 360/Auto with 159,000 miles
ED 98 RAM 1500 SLT QuadCab 4x4 360/AT 86 Shelby GLHS ** How to: Changing Ball Joints on 2nd Gen Ram Quote:
Post #6
BTW, Ed love that quote by Reagan in your sig. about Freedom - so true !! David B.
Posted: 06-04-2006, 07:58 PM
Post #7
Ive got it to. Not real bad yet, but its there.
98 Reg Cab Short Box 1500 5.9 4x4 Performance: Custom 4 inch air intake, Custom Magnaflow Exhaust. No Cat. 265/70/17 Toyo Open Country AT's 4.11's with Auburn in the rear. Rhino Lined Rockers and bumpers |
Posted: 06-04-2006, 08:58 PM
Post #8
I don't have a "clunk" or "rattle" but I do have a pronounced "dead spot" if you will, when the steering wheel is rotated about 1/4 turn in either direction. It's most noticable to the right.... same thing, similar, or waaaay off?
2001 Dodge Ram 1500 4x4 Off Road, 109,000 miles, 5.9L, auto, 37" tires.
2001 Ram 1500 4x4 ENGINE / DRIVETRAIN MODS: 5.9L V8 | Pure Evil" Transmission by Dr. Evil Performance Transmissions | Hughes Engine Plenum Gasket reinforcement kit | Air Hog Drop in filter | No Muffler | 180° Thermostat | Dana 60 front, 5.38's | GM 14 bolt rear, disk brakes, 5.38's, Detroit Locker | Dakota Digital SGI-5 converter box SUSPENSION MODS: 13" of total lift | Thuren Trac Bar | Rough Country 5" X-Series Lift Kit (removed)| 3" Top Gun Customz coil spring spacer | 3" Body Lift | Rough Country Hydro 8000 shocks | 41x14.50R17 Super Swamper Radial IROK | 17X9 Moto's |Top Gun Customz Dual Shock kit | 7" SkyJacker coils | Custom (very) long arms | Shackle flip + factory block in the rear OTHER GOODIES / MODS: Optima Red Top | Pioneer 6x9's and 5 1/4's | HD Radio / CD player| "C5 Corvette" style seats | 4 point harness system | 136 Amp Alternator | Thuren Cross Over Steering Conversion | Rock Lights |
Posted: 06-04-2006, 09:19 PM
Post #9
I have a clunk. It seems like it goes away every other week that I drive.
102K
Main vehicle: 1986 Chevy Cavalier 1998 Ram Quad Cab 2500 Short Bed V10 4x4 C.A.I. Headers. SCT Tuner 3" SRB Lift Fast Man TB GM Push Rods 2" Leveling Kit 1.7 Roller Rockers Exhaust: No cats, Flowmaster 50 33" Cooper Discoverer STT Studded tires 35" Micky Thompson Baja Claws Best Runs (with trans issues) 60': 2.27 1/8th: 10.23 @ 68.56 MPH 1/4: 15.93 @ 85.7 MPH 0-60: 7.9sec V10 Ram Club #1 |
Posted: 06-04-2006, 10:40 PM
Post #10
Hey Off road, don't know if it could be the 'lower column bushing' issue that's causing your 'dead spot'. You might try checking out the end of your column as it comes through the firewall - grab the spring part and try to move it back & forth hard. If you feel any significant play - that might be it.
To the Quad Cab in Wa: do the same thing, wait til it starts clunking, then pull over, twist the spring and see if it doesn't go away for a while, also feel for play as above. wish you well, David B.
Posted: 06-04-2006, 10:50 PM
Post #11
Had it since the first couple of months! Had shaft replaced 3 times by Dodge but no
good still! As far ar the play in the steering, try changing your pitman arm, made a world of difference in mine, and not that much money!
Ret.ArmySF Lead, Follow, or get the Hell Out of the Way! 1998 Dodge Ram SLT 1500 5.2L/Debadged COIN HOLDERS ASSOCIATION MEMBER #69 S.N.A.T.C.H. Spec. Ops. 2nd Lt! Exterior: Blue Xenon Head and Fog Lights - Stainless Steel Toolbox - Mopar Molded Mud Flaps - Red Painted Brake Calipers - Tailgate Handle Lock - Alteza Tail Lights - Rear Spoiler - Aluminum Gas Door - Aluminum 3rd Brake Light Cover Interior: White Face Guages - Hard Wired Radar Detector - Pioneer Head Unit - Front 6x9 4 Ways Rear 6.5 4 Ways - Bazooka Tube Sub Woofer - Center Console Coin Holder Performance: TPS Modification - ACcel 8.8mm 300+ Plug Wires - NAPA Brass Contact Distributor Cap and Rotar - K&N cold air intake- Magnaflow High Flow CAT - Magnaflow Stainless Steel Muffler - Traction Bars Planned Additions: Cam -1.6 Roller Rockers- Fastman Throttle Body 52mm - 410 gears and Posi Water marks Powered by "PictureShark" http://www.picture-shark.com/ |
Posted: 06-04-2006, 10:54 PM
Post #12
another one
96 ram 5.2l ext cab 2wd 94k
Corey, 22yo bodybuilder 1996 Dodge Ram Extended Cab traded in for a 2006 Mazda3 S ![]() Brother, 19yo 2001 Dodge ram Reg cab full bed. Flowmaster muffler gutted cat Dad- 70 challenger, undergoing a 496ci replacement |
Posted: 06-05-2006, 06:28 AM
Post #13
I love that quote too - had to add it to the sig ![]()
Post #14
For sure, don't overlook a loose track bar as a potential source of noise. Mine was rebuilt with lukes' link 2 years ago, and very solid - I'd recommend that route as it's way stout and very reasonable cost $ 70 ea I think & lasts forever.
I'm not a real big fan of Borgeson. I took mine off - actually it prevented me from 'reinstalling' it after the said 'lower column bushing repair' completed. When new, the Borgeson had a very stiff 'slider' joint, and it only got worse with time (this undoubtedly contributed to the clunking, if it's joint refused to slide as Dodge intended). Anyhow, I tried to pull it up from the collapsed position - impossible, on or off the truck. Thank God I had been at Mopar parts the day before - checked out the OEM shaft - they beefed it up from my original one - and it slided very smoothly, so I bought it 'just in case'. Yes, it's got about 2 degrees of slop in it, but with the added precision of the bushing upgrade, it's more accurate than before by far.... I'm not trying to talk bad about Borgeson, could be I got a bad one, but as I read thousands of posts searching down the source of the column clunk, I noted many guys put on a Borgeson, and their clunking problem got worse not better. Does that make sense ? If you must have a Borgeson, I can probably let mine go cheaply, but it will need some work - don't know if it can be disassembled - has to be a way - to clean out any dirt & crud, relubed & needs a new rubber boot. With that done, the sliding joint will not bind as bad, surely. Thanks for the feedback - I'm looking into making more of the bushings by next week...... Take Care, David B. ![]()
Posted: 06-05-2006, 02:50 PM
Post #15
yea i have that rattling sound also how do i get rid of it?
01 regular cab long bed: altezza black euro taillights roll pan w/lic box billet chrome fuel door clear corner signal lights w/white bulb calvu sideview mirrors alpine amp alpine deck two 12" kickers tinted windows k&n intake k&n decal |
Fix has been found & pictured, if this is your problem...ideas for you
- Posted: 06-05-2006, 03:54 PM
Post #16
I explained how I fixed the "lower steering column bushing" in the first post or two I made. It wasn't hard if you have a lathe to machine the bushing from Nylon or Delrin round stock- I'll tell ya how if anyone wants to make their own. I plan to make more and then offer them at a minimal cost - we're still working to see if this 'bushing upgrade' can be done 'on truck' ie, w/o pulling the column, like I did - could cut repair time by 2/3 rds. Check out the pics and compare to your truck - the columns are pretty much the same from truck to truck - with the auto trans trucks having some linkage & brackets that cover the lower column end where the bad bushing sits -under that tension spring which covers the column just above where it joins the 'intermediate shaft' - my pics show it pretty clearly, but are from my '97 manual trans. If you check with Mopar parts, they only sell the entire column for $ 700 - so you're forced to buy the whole thing, and they still have the same bad design - a weak lower plastic bushing that develops play and then clunks you crazy ! It's worth mentioning to make sure the clunking is not from front end componenents - 4x4 trucks having a variety of things that might be your problem like: worn tracking bar, control arm bushings, worn steering box, bad sway bar links, worn intermediate steering shaft etc. In my case, I had fixed every single one of those things and yet the clunk only got worse !! I read thousands of posts here & on the TDR site and only 1 guy ever figured out EXACTLY what was causing it - he did a 'home brew' fix - and I'm in his debt. All I've done is refine his fix - planning how to make more of them, with better material (Delrin should outperform Nylon...) and see exactly what repair method can be developed - we still need to see how hard this is to attempt an 'on the truck' R & R & on an automatic truck, too. It shouldn't be expensive, maybe $ 30 for the kit with step by step instructions for a foolproof fix. Or just follow these principles and make it yourself - that's what these forums are so good for, eh ? Also, note how it doesn't just take care of the clunk sound, but tightens the steering more than any other mod I'd made so far - and I have them all. The truck now steers with the precision of rack & pinion - which I never thought possible. Hope that fills in the blanks - I appreciate hearing your responses. It seems like the 4x4 Diesels have the problem worse - probably due to the fact they are more front end heavy and get used to tow bigger loads - but since they are 95 % the same truck even if a gasser, this weakness is in all the Ram trucks, I think mainly in the 2nd gens. (Haven't checked yet to see if the 1st gen guys have it, I suspect so... ? ) Take Care, David B. "Ram Van & Truck Man" ![]()
Posted: 06-05-2006, 05:21 PM
Post #17
i got it too.
93000 miles
Lean on the gas and off the clutch! 2001 Dodge Ram QC 5.9L 4x4 |
Posted: 06-05-2006, 07:36 PM
Post #18
I got it too. 2001 ram 1500 off road package automatic 5.2. If you get these things up for sale, I will take one.
![]() Appearance: JTS VENOM Hood (1 of 5 w/o vents) SRT Front Bumper Roll Pan 6K HID Heads and Fogs Black Rims Black Headlights with Eyelids Black LED Tails Black Grill Black Door Handles Black Side Steps 20% Tint Performance: Sidewinder Cam Hemifever Tuned SCT Stacked with SC Trans Control 6.1 Springs and 6.1 Pushrods Pacesetter LT’s Circle D Torque Converter Sonnax Line Pressure Booster Magnaflow HiFlow Cats Pacesetter Y-Pipe Fastman Ported TB Aeroforce Interceptor & Wideband Kit Airaid Intake DMH Electric Cutout E-Fan Thundervolt 8.2's Hellwig Rear Sway Bar 2" Drop 1 Ton Trans Cooler Drilled & Slotted Rotors Magnaflow 12588 180 Stat Flowtech Powerwire Extras:MOPAR Remote Start SRT A Pillar Hella 500's |
Posted: 06-05-2006, 10:36 PM
Post #19
yeah ill take one also
Posted: 06-05-2006, 10:45 PM
Post #20
I'll take one too.
| Thread Tools | |
| Dodge Reveals New 2006 Ram 1500 | FreeLantz | Rumor Mill & Gossip Talk | 60 | 06-08-2006 08:58 PM |
| 2006 Dodge Ram 1500 Information | RAJ | 3G Dodge RAM - General Talk | 20 | 06-18-2005 12:18 AM |
| Legendary Dodge Ram Power Wagon Returns | RAM MAN | Rumor Mill & Gossip Talk | 4 | 10-02-2004 05:44 PM |
| 2004½ Ram Diesel - 325hp / 600ft-lb | dodge_em | Diesel Tech | 45 | 07-13-2004 09:39 PM |
| 1999 Durango 48k - Should I buy??? | jasonl57 | 1G Dodge Durango General Talk | 6 | 02-27-2004 07:48 PM |
Privacy Statement | |
