Another code ... P1494, RATS !
- Posted: 06-04-2006, 12:04 AM
Post #1
OK, got another code. This time it's the P1494. The P0455 is gone and I didn't find any leaks via a visual inspection nor the service garage with the smoke tester.
So, P1494 is now the game to play on today. Ever since this code came, the cold engine idle tends to rev up and down continually. It can drive a person ... This is the best info I can find at this time to get things corrected. P1494 is a Leak Detection Pump Switch or Mechanical Fault. --- clip in --- TSB-18-01-00 SUBJECT: Misdiagnosed Leak Detection Pump Systems With DTC P1494, P0442, P0455, OR P0456. MODELS: 1997 - 2000 (AB) Ram Van 1997 - 2000 (AN) Dakota 1997 - 2000 (BR/BE) Ram truck 1998 - 2000 (DN) Durango 1997 - 2000 (FJ) Avenger/Sebring/Talon 1997 - 2000 (JA) Cirrus/Stratus/Breeze 1997 - 2000 (JX) Sebring Convertible 1997 - 2000 (LH) Concorde/Intrepid/LHS/300M/Vision 1997 - 2000 (NS) Town & Country/Caravan/Voyager 1997 - 2000 (PL) Neon 1997 - 2000 (PR) Prowler 1997 - 2000 (SR) Viper/Viper GTS 1997 - 2000 (TJ) Wrangler 1999 - 2000 (WJ) Grand Cherokee 1997 - 2000 (XJ) Cherokee 1997 - 1998 (ZJ) Grand Cherokee DISCUSSION: During evaporative system diagnosis, Leak Detection Pumps have mistakenly been replaced. A thorough inspection for pinched, kinked, or disconnected supply vacuum lines (as currently listed in the Powertrain Diagnostic Procedures) is a critical step in diagnosing DTC P1494 (LDP SW OR MECHANICAL FAULT). Additionally, the other evaporative leak faults (DTC P0442 - SMALL LEAK, P0455 - LARGE LEAK, and P0456 - VERY SMALL LEAK) should have the supply vacuum lines examined for pinches or kinks prior to any LDP component replacement. The supply vacuum lines should be checked from the engine compartment all the way to the fuel tank, including the LDP and purge system. NOTE: VERIFY ALL RELATED SUPPLY VACUUM LINE ROUTINGS FOR PINCHES, KINKS, OR DISCONNECTION'S BEFORE REPLACING LDP SYSTEM COMPONENTS. POLICY: Information Only --- clip out ---
2000 Dodge-Ram-B1500 V6 3.9L, 3.55:1, RoadMaster MKII-XF -SOLD- 2001 Dodge-Ram-B2500 V8 5.2L, 3.92:1, RoadMaster MKII-XXF 1982 Coachmen Cadet 19-1/2 3000# Towable Camper *DodgeTalk.com 318 Enthusiast Member #(50)* *DodgeTalk.com Ram Van/Wagon Member #(1)* |
| Sponsored Links |
| Thread Tools | |
| Trouble codes for neons 95-99 | dodgeneonACR98 | Neon - General Talk | 87 | 02-25-2008 01:15 PM |
| 98 Caravan 3.3L "Haunted" - Electrical problems | daberguson | Caravan Talk | 11 | 12-22-2007 03:48 AM |
| Trouble Codes for 96-97 Caravans | Jmw132001 | Caravan Talk | 0 | 05-18-2006 10:54 PM |
| P0455 code ... RATS! | stev | B-Series Vans 1971 - 2003 | 3 | 04-29-2006 10:11 AM |
| How to decode the VIN | flattop | 3G RAM Diesel Talk | 9 | 03-23-2005 10:25 PM |
| Sponsored Links |
