Go Back   Dodge Talk Community Forum > Dodge Truck, SUV and Van Forums > Van and Cargo Truck Forums > B-Series Vans 1971 - 2003
Kerbchek
  1996 Dodge Ram Van Fuel Pump Problem - Posted: 06-02-2006, 11:43 PM
City: Des Moines
State: IA
Post #1
Hello, I'm new to this forum and have already learned a lot by reading thread after thread for the past hour...
I believe the fuel pump is going bad on my 96 Dodge Ram van.
When it gets to or below 1/4 tank of gas it starts to sputter, backfire some, and basically run rough. When I let it sit for a while and start it back up it runs fine. I'm thinking when the fuel pump gets hot since there's not enough gas in the tank to keep it cooled??
When the tank is full it runs fine. I need to use my van so if I fill it up and run it, will it be ok until I can get a new fuel pump - and just fill it up when it gets to a 1/2 tank or so, or should I just stop running it altogehter?
Thanks!
Registered users do not see this ad or IntelliTXT ads. Please Register today! Its quick, easy and free!
DANVAN
 Posted: 06-03-2006, 09:58 AM
DANVAN's Avatar
vanner
City: Merrimack NH, formally LI
State: NH
Post #2
Sure sounds like the fuel pump, mine did the same thing a while ago, I would get the fuel as low as possible and drop the tank and replace the pump, its not hard to do. There is a special deep socket needed to remove the fuel tank straps, other then that its a simple job.
DAN
93 B250 VAN. Navy Blue Metalic 5.2 MAGNUM 3.92Gears, MSD Blaster coil, MSD 8.5mm wires, FLOWMASTER, K&N. FASTMAN 50mm TBody
Fully custom home built interior, no conversion van.
2001 GRAND CARAVAN SPORT-wifes.
318 Enthusiast member #80
http://www.showtrux.com/showvans/bluestraveler/index.htm
Click HERE to view the complete signature...
Dodgevanman
 Posted: 06-03-2006, 05:01 PM
Dodgevanman's Avatar
Do It In A Van
City: Baltimore Hon!
State: MD
Post #3
I concur Doctor. Fuel pump is agoin' bad.
Nate the skate
5.2L Magnum
1972 B200 Royal Sportsman Maxiwagon
318/2bbl.
1985 B150
318/2bbl.
Kerbchek
  A little trickier than I thought... - Posted: 06-03-2006, 09:11 PM
City: Des Moines
State: IA
Post #4
I was told by several people that it was fairly easy to change the fuel pump. I bought the expensive one from the dealer and had no problems whatsoever until I tried to pull the wiring off. I didn't get it at first. I sought professional help on this issue and was told the little orange clip needed to come off first and then it should pop off pretty regularly. I was confused because there was a gray clip on the end of the wiring mechanism that I thought was the part that was supposed to come off. Of course I'm working underneath the van on jack stands with about 8 inches of head clearance between the top of the tank and the bottom of the van. Once I got that off things moved along easily.
I ran out of daylight hours so the new one is in, and the tank is partway back on. I'll finish tightening the bolts in the morning and see how it runs... wish me luck!!
Thank you for your assistance. This forum is great!!
stev
 Posted: 06-03-2006, 11:43 PM
stev's Avatar
Seating for 12
City: Near Niagara Falls
State: NY
Post #5
Kerbchek,
I know what you mean about the sun going down while getting the last bolt in place. It seems all to often this occures with me too.
Stev
2000 Dodge-Ram-B1500 V6 3.9L, 3.55:1, RoadMaster MKII-XF -SOLD-
2001 Dodge-Ram-B2500 V8 5.2L, 3.92:1, RoadMaster MKII-XXF
1982 Coachmen Cadet 19-1/2 3000# Towable Camper
*DodgeTalk.com 318 Enthusiast Member #(50)*
*DodgeTalk.com Ram Van/Wagon Member #(1)*
2006 Ram QC Revealed mrb83sxt02 3G RAM - General Talk 54 06-23-2005 04:49 PM
Legendary Dodge Ram Power Wagon Returns RAM MAN Chrysler LLC Press Releases 4 10-02-2004 06:44 PM
2004˝ Ram Diesel - 325hp / 600ft-lb dodge_em Diesel Tech 45 07-13-2004 10:39 PM
2004 Dodge Truck Highlights RAM MAN Chrysler LLC Press Releases 0 09-03-2003 05:27 PM
2004 Dodge Car Highlights RAM MAN Chrysler LLC Press Releases 0 08-01-2003 03:38 PM
