Haynes manual wrong for 1991
- Posted: 05-31-2006, 06:34 PM
Post #1
Hey all. I've been chasing electrical demons, in my '91 Ram Van, and my Haynes manual is showing me some incorrect info. Specifically, the wiring diagram, for the '88-'91 vans. Several fuses shown are incorrect, compared to my '91 owners manual. Problem I'm having is, previous mechanic replaced a fusible link, in the pink/black, with a 30amp. fuse. This fuse blows when the starter engages. Although, if you change fuse with engine running, it won't blow. I lose my p.windows and blower motor. Anybody have a ignition harness schematic, other then Haynes?? Or does anybody have any thoughts on this problem?? Brad
2000 Dodge Caravan 91,500kmm, 3.3V-6, Quad 1991 Dodge 150 Ram Van V8-318, 144,000miles, purchased may27/06 $980. cert. and e-tested, Bosch wires, MOPAR coil, Eagle Alloys with Cooper Cobra GT's, Power Accoustics DVD, CD Player 1989 Dodge 150 Ram Van, V-318, now a trailer. 1982 Dodge Ram Maxi 1 TON V-8 360, 3spd. Soon dually. 1986 Dodge 250 Ram Van 318 4spd. standard. 1991 PV 3.0l parts van now a trailer ![]() *DodgeTalk.com Ram Van/Wagon Member #(3)* *DodgeTalk.com 318 Enthusiast Member #(86)* |
| Sponsored Links |
Posted: 06-01-2006, 07:11 AM
Post #2
You should go on Ebay and get yourself a used factory service manual.
I'll try and scan some schematics for you tonight.
Nate the skate ![]() 1994 B250 Ram Van Conversion by Elk 5.2L Magnum 1972 B200 Royal Sportsman Maxiwagon 318/2bbl. 1985 B150 318/2bbl. Click HERE to view the complete signature... |
Posted: 06-01-2006, 03:39 PM
Post #3
Thanks Nate, I would greatly apprieciate that.
Posted: 06-02-2006, 06:54 AM
Post #4
My DSL was down last night...I'll scan tonight.
| Sponsored Links |
Posted: 06-02-2006, 07:28 PM
Post #5
Referring to post#1, the 30amp fuse is inline with the pink/black wire. Referring to the '92 wiring schematic (haynes), pink/black goes through a 50amp. maxi fuse. Might my problem be too low amperage fuse. I might try a thiker wire with a heavy duty fuse and holder, and see if this solves the problem. I'm just concerned about melting wires...Brad
Posted: 06-02-2006, 07:39 PM
Post #6
Here ya go...start with these.
http://i37.photobucket.com/albums/e8...ce/91wire1.jpg http://i37.photobucket.com/albums/e8...ce/91wire2.jpg http://i37.photobucket.com/albums/e8...ce/91wire3.jpg http://i37.photobucket.com/albums/e8...ce/91wire4.jpg http://i37.photobucket.com/albums/e8...ce/91wire5.jpg http://i37.photobucket.com/albums/e8...ce/91wire6.jpg
Posted: 06-02-2006, 07:42 PM
Post #7
I wouldn't do that. '92 is the first year for the Multi-Port fuel injected Magnum engines which required a totally different wiring harness that had different requirements.
Posted: 06-02-2006, 08:14 PM
Post #8
Thanks for the wiring diagrams. I'll have to thoroughly go over them, before I try anything drastic.....Brad
Posted: 06-03-2006, 08:47 PM
Post #9
After having gone over all wiring and diagrams, I believe all wiring under hood is correct. I removed the ignition switch, which I now believe is the problem. The 2 big contacts in the middle, shows signs of being burnt. These are the pink/black wire, and the black/red wire. The pink/black is the wire with the fuse under the hood, the back/red goes to the p.w.'s blower motor. I think the switch is crossed and throws a ground, when starter engaged, therefore, blowing fuse under hood.....
Posted: 06-04-2006, 10:46 AM
Post #10
I used an old test trick, for when I was installing remote starters, for a living. I basically hot-wired the van. Everything worked as it should, so I'm pretty sure it's the ignition switch. I'm going to replace it this week, so I can drive it...
Posted: 06-05-2006, 06:53 AM
Post #11
Badda boom badda bing!
Posted: 06-05-2006, 06:10 PM
Post #12
And yes I was 100% correct. I stopped at a local Dodge Dealer, today, and they actually had an ignition switch on hand. Put it in as soon as I got home. Everything works perfectly. Although, I haven't reinstalled the rear defroster switch yet, as it also shows signs of melting terminals. I might leave it out, as I don't plan on driving this in the winter...
| Thread Tools | |
| Don't believe everything in the owners manual | vinman | 3G Dakota General Talk | 5 | 05-13-2006 09:00 PM |
| Haynes To Release 3rd Gen Ram Manual In June | scapegoat047 | 3G RAM - General Talk | 20 | 03-30-2005 01:10 PM |
| WRONG Lift kit arrived | HOCummins | 2G RAM - 4X4 Talk | 3 | 05-17-2004 09:12 AM |
| Where To find Fault Codes?????????? | slayer | 3G RAM - General Talk | 15 | 12-27-2003 10:02 AM |
| SORRY - when I'm wrong - I SAY I'm wrong | RAM MAN | 3G RAM - General Talk | 3 | 09-13-2002 01:53 PM |
| Sponsored Links |
