Spindle nut size ??? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 05-28-2006, 09:44 PM Thread Starter
msu_ram2500V10
Wendell Curry
i am tryin to replace my front rotors and can not find a right socket. i have tried a 1 11/16 and its a little to small. also does any body know how to break it free. damn is it tight lol. i have a 1 3/4 its a little sloppy.also does anyone know what the best spark plugs are for my truck.. if i have to pay a couple more dollars for better performance i will..... its a 1999 ram 2500 v10
msu_ram2500V10 is offline
post #2 of 7 Old 05-29-2006, 02:28 AM
Jmw132001
Jmw132001's Avatar
Quoted: 2 Post(s)
are you trying to take the big nut off just to take the rotors off? you do not have to take that big nut off just to get the rotors off. Good luck
Justin
Resigned July 19th 2011
COIN HOLDERS ASSOCIATION MEMBER # 88
Beta tester for online games.
1998 Dodge Ram 1500 qc sport 360 4x4
208,300 original miles (as of 9-25-10)
new transfer case, brakes, shocks, radiator, water pump(twice cause of faulty parts), front balls joints, trak bar, front u-joints, tires, heater core.
Jmw132001 is offline
post #3 of 7 Old 05-29-2006, 07:27 AM Thread Starter
msu_ram2500V10
Wendell Curry
theres a plate with the lugs on it in front of the rotor. the spindle nut holds it all on im guessin.
post #4 of 7 Old 05-29-2006, 10:59 AM
Jmw132001
Jmw132001's Avatar
Quoted: 2 Post(s)
i have never seen one like that. can you take a pic of it and put on here?
Justin
post #5 of 7 Old 06-02-2006, 08:17 AM
v10sport
Built Not Bought
v10sport's Avatar
The big nut size is 1 11/16ths. Maybe you bought a reject socket. Ive worked an many years Rams and all have had 1 11/16th socket. Is the socket a 6 point or 12 point?
JMW, he has to pull the nut off to pull the rotor. The 94 to 99 2500/3500 do not have slip on rotors like the 1500's do. The rotors bolts BEHIND the hub.
MSU Ram, you will have to pull the entire hub assembly off, knock out the studs, put the new rotor on and pull the studs back in. Good luck getting the hub off. They sieze to the knuckle because Dodge didnt use any anti sieze. Got to loosen up the 4 bolts behind the hub about an inch, put a socket and extension on and get a BFH and start hitting the socket. Rotote which bolt you hit. After an hour of hard beating with the hammer, the hub may start to move. Make sure to put antisieze on the knuckle/hub so it will come off easy the next time.
As for plugs for the V10, Ive had good luck with the bocsh platnums
2000 Dodge 2500 Quad Cab LB V10 with many many mods.
7500 pounds
1/8th 10.193
67MPH
1/4 16.024
84.01 MPH
05 610 CTD QC 4x4 Needs some mods
02 Jeep Grand Cherokee 4x4
v10sport is offline
post #6 of 7 Old 06-02-2006, 05:34 PM Thread Starter
msu_ram2500V10
Wendell Curry
thanx for every bodys help there off and new ones on. what a pain in the ass .. lol
post #7 of 7 Old 01-29-2007, 04:35 PM
james c hein jr
Socket Size
THE CORECT SOCKET SIZE IS 1 11/16 six point,but acording to dodge&tinken the bearing company the splines are to be dri to optain the proper torque, your best bet is to buy the dodge repair manual this can be purched at the dealer or calling the number in the back of your owners manual to do the job properly.
james c hein jr is offline
    Axle Nut size on 2500 dodge ram 4x4 MudViper 2G Dodge RAM - Drivetrain Talk 1 08-06-2005 12:12 PM
    anyone know nut size for grille? SlinkyOfRage 3G Dodge RAM - General Talk 11 07-28-2005 12:51 PM
    Axle Nut size on my 99 neon gbfan10 Dodge Neon - General Talk 3 07-07-2005 07:32 AM
    axle spindle nut ILLUMN8OR 2G Dodge RAM - 4X4 Talk 2 09-28-2004 12:01 PM
