Go Back   Dodge Talk Community Forum > Dodge Truck, SUV and Van Forums > Van and Cargo Truck Forums > B-Series Vans 1971 - 2003
dodges 3
  Electrical Problems Maybe - Posted: 05-28-2006, 09:19 PM
dodges 3's Avatar
City: Kitchener Ontario, Canada
State: ON
Post #1
Hi all vanners, again. I have an electrical problem, maybe, I might have figured it out. Anyways, the previous owner told me his mechanic installed a fuse in place of a fusible link, because P.W.'s kept quitting. Well, it seems as though this mechanic replaced 2 fusible links with a fuse, not sure why both, but when ever I start the van the fuse blows. Having pulled all the wires out from behind brake booster, I think, and stripping all the tape off I can now trace harness based on Haynes manual. As per haynes, the rear window defroster wires, run on same circuit. I then pulled the switch for defroster, and saw a melted terminal. I am going to try 2 30amp fused lines to join the 2 fusible links, and with switch out, see if I can stop blowing fuses. If this doesn't work, would it be alright to run new power supply to the fuse block for the P.W.'s???
2000 Dodge Caravan 91,500kmm, 3.3V-6, Quad
1991 Dodge 150 Ram Van V8-318, 144,000miles, purchased may27/06 $980. cert. and e-tested, Bosch wires, MOPAR coil, Eagle Alloys with Cooper Cobra GT's, Power Accoustics DVD, CD Player
1989 Dodge 150 Ram Van, V-318, now a trailer.
1982 Dodge Ram Maxi 1 TON V-8 360, 3spd. Soon dually.
1986 Dodge 250 Ram Van 318 4spd. standard.
1991 PV 3.0l parts van now a trailer
*DodgeTalk.com Ram Van/Wagon Member #(3)*
*DodgeTalk.com 318 Enthusiast Member #(86)*
Rear hatch electrical problems arnieb Caravan Talk 3 01-17-2005 09:41 AM
Problems with AC and Lights Dodge99 Caravan Talk 2 01-10-2005 05:55 PM
IF having problems wiht the 4.7 please read ponchin 3G RAM - General Talk 8 01-09-2004 09:04 PM
Help Please. Electrical Problems. VaRam 2G RAM - General Talk 6 02-26-2003 08:18 AM
