Error Code P1195 - mass air flow sensor? - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 6 Old 05-22-2006, 11:46 AM Thread Starter
chrisk
My check engine light recently came on and was giving the error code P1195, which I believe to be a problem with the mass air flow sensor. I've heard stories of these going bad on other cars and people fixing it themselves. This, and seeing pictures of the actual part lead me to believe it isn't that hard to replace. Has anyone ever replaced one and can provide any tips?
chrisk is offline
post #2 of 6 Old 05-22-2006, 02:10 PM
edglock21
The Green Machine
edglock21's Avatar
Our trucks don't use Mass Air - they're Speed-Density. I'll see if I can find some more info on that code for you
ED
98 RAM 1500 SLT QuadCab 4x4 360/AT
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same, or one day we will spend our sunset years telling our children and our children's children what it was once like in the United States where men were free. - President Ronald Reagan
I'll rochambeau ya for it..." Eric Cartman
edglock21 is offline
post #3 of 6 Old 05-22-2006, 02:37 PM
Silver_DodgeRam
Mmmmmmmmm, beer.
Silver_DodgeRam's Avatar
Quoted: 2 Post(s)
That code is an o2 sensor code:
P1195 - 1/1 O2S Slow During Catalyst Monitor
2009 Dodge Ram 1500 4x4, 5.7 Hemi, Crew - work in progress
2008 Chrysler Aspen 4x4, 5.7 Hemi, Loaded
Silver_DodgeRam is offline
post #4 of 6 Old 05-22-2006, 03:10 PM
edglock21
The Green Machine
edglock21's Avatar
Silver beat me too it
- looks like you need an oxygen sensor
ED
post #5 of 6 Old 05-22-2006, 08:11 PM Thread Starter
chrisk
Cool, thanks to you both. I'm looking on AutoZone's website and they have two sensor, one for before the cat and one for after. Any ideas which one it would be?
Edit: Well it looks like both links take me to the same part. I just need to see which one of them is bad...
chrisk is offline
post #6 of 6 Old 05-23-2006, 12:32 AM
knowplay
Team ASE
knowplay's Avatar
1/1 means Bank 1 Sensor 1. This would be the one closest to the engine on the driver's side.
Here's some info:
SYMPTOM
P-1195 SLOW 1/1 O2S DURING CATALYST MONITOR
WHEN MONITORED
With the engine running, coolant > 170 degrees F , open throttle, steady to slightly increasing vehicle speed > 18MPH < 55MPH , with a light load on the engine for a period no less than five minutes .
SET CONDITION
The oxygen sensor signal voltage is switching form below 0.39 volt to above 0.6 volt and back fewer times than required.
POSSIBLE CAUSES
* 1/1 Oxygen sensor ground circuit open
* Engine fluid consumption
* 1/1 Oxygen sensor connector observable defect
* 1/1 Oxygen sensor defective
* Exhaust system leaking
* PCM connector observable defect
Might not be the O2 sensor, though with a "slow" code it usually is. Hope this helps.
'97 Extended Cab 5.2L 5spd Black Ram
Quite a few mods. Pretty fast and loud only when I want it to be. Needs painting.
knowplay is offline
    1998 Caravan wont stay running JMDTOYS Dodge Caravan General Talk 3 05-05-2006 11:57 AM
    mass air flow sensor? kalen427 2G Dodge Ram Performance Talk 22 12-10-2005 04:47 PM
    mass air flow sensor in '02 T+C 3.8L? B1G BLEU Dodge Caravan General Talk 0 12-10-2005 02:08 PM
    360Airintakez Opinions needed... fischputza 3G Dodge Ram Performance Talk 8 09-02-2005 09:35 PM
    Engine Light on at 21,100 miles ColoradoQuadCab 2G Dodge Dakota Performance Talk 6 11-17-2003 03:25 AM
