4x4 Wont ENGAGE NEED HELP!! - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 7 Old 05-21-2006, 07:56 PM Thread Starter
pudge_slugfest
Pudge
Hello, i was recenty fixing fence and i got stuck then i put it in 4wheel drive and it wouldnt engage and my light wont come on saying it is on, and i noticed that there is a hose that runs from the pump on the axle into the hood but it is not attatched to anything!! could that be the problem? need help
1997 DODGE RAM 1500 4x4 Sport package
3.55 gears
K&N FILTER
DUEL CATBACK EXHAUST
2- 4foot Whips
CHROME BUG DEFLECTOR
PUSH BAR
Alpine Deck[/COLOR]
*DodgeTalk.com 318 Enthusiast Member # 25
pudge_slugfest is offline
post #2 of 7 Old 05-21-2006, 10:30 PM
QCRam
The ~1/2" diameter hose that runs from the top of the CAD housing is the axle breather, and isn't supposed to be connected to anything. The actuating hoses are the red and black (nylon?) lines that come off the circular diaphram housing, which connect to steel lines, which make their way back along the frame, plug into more flexible lines and connect to a valve on the top of the transfer case, which supplies vacuum to either side of the diaphram to move it in and out. Check that there's a vacuum at one of the ports, if not there'll be a vacuum leak somewhere, if there is, probably the actuator shaft has stuck in place.
1999 1500 Quad cab, 5.2 4x4 Flame red/Driftwood 2" lift, 285/70/16 - sold
2007 Chevy HHR
2002 Navy Blue Metallic Camaro SS convertible
QCRam is offline
post #3 of 7 Old 05-21-2006, 10:42 PM Thread Starter
pudge_slugfest
Pudge
ya found out the problem right away, it was those 2 red and black lines, my black cover for the lines fell off so the front drive shaft rubbed on the black line a little bit and put a nice long hole in it, so i taped it up but it still leaks a but, but it still engages the front end just very slowly
3.55 gears
K&N FILTER
2- 4foot Whips
PUSH BAR
Alpine Deck[/COLOR]
post #4 of 7 Old 05-22-2006, 10:34 AM
BleedDodge
BleedDodge's Avatar
So did you finish fixing the fence?
BleedDodge is offline
post #5 of 7 Old 05-22-2006, 01:18 PM Thread Starter
pudge_slugfest
Pudge
haha no i did not, after i fixed my 4x4 i went out drinking instead. the fence can wait until tommorow
3.55 gears
K&N FILTER
2- 4foot Whips
PUSH BAR
Alpine Deck[/COLOR]
post #6 of 7 Old 05-22-2006, 01:48 PM
schmedly
I like that solution!
schmedly is offline
post #7 of 7 Old 05-22-2006, 08:59 PM Thread Starter
pudge_slugfest
Pudge
Thats pretty much the only way to celebrate the fact that something major didnt go wrong with a dodge that didnt require thousands of dollars being spent
3.55 gears
K&N FILTER
2- 4foot Whips
PUSH BAR
Alpine Deck[/COLOR]
    4x4 Won't Engage!! badshape 2G Dodge RAM - 4X4 Talk 8 02-27-2006 10:25 AM
    4x4 will not engage rosser4580 1G Dodge Durango - Drivetrain Talk 7 09-10-2005 08:59 PM
    Why does my 4x4 engage so fast? LS1POWERED 3G Dodge RAM - Drivetrain Talk 17 12-11-2004 10:26 PM
    2004 and Select 2005 New Vehicle Pricing RAM MAN Rumor Mill & Gossip Talk 0 03-21-2004 09:42 AM
    2004 and Select 2005 New Vehicle Pricing RAM MAN Rumor Mill & Gossip Talk 1 01-14-2004 10:29 AM
