Intro & 1977 dodge van electric choke question
- Posted: 05-20-2006, 07:43 AM
Post #1
Great board. I've owned several Mopars including two 1969 300s, a 1970 300, 1968 Charger, 1968 Newport, and a 1971 Demon 340. Just picked up a 1977 dodge van with a 318 and overdrive 4 spd. The electric choke was missing when I got it. The previous owner had the choke plate wired open -- they didn't need it in AZ. I installed an NOS electric choke control, so I assume the unit works. I plugged it into the the only available terminal, which is on a button
like unit with two terminals mounted on the intake manifold. I started the van and let it warm up, but the choke doesn't open over time. I need to check power at that terminal. But my question is, does the electric choke stay powered up the entire time that the ignition is on, or is it wired to a circuit that cuts out when the engine reaches operating temperature? I have the factory manual, and there is no information about the choke control, other than it helps open the choke faster. I can't find it on the wiring diagram either. Thank you. |
| Sponsored Links |
Post #2
Take a look in the "Emissions" section of the Service Manual and see if you find info on the Choke system.
Thank you
- Posted: 05-21-2006, 11:12 AM
Post #3
Found it.
| Sponsored Links |
| Thread Tools | |
| Dodge in Hot Pursuit of Police Car Market with HEMI®-powered 2006 Dodge Charger | FreeLantz | Chrysler LLC Press Releases | 42 | 06-04-2006 05:22 PM |
| 2006 Ram 1500 Info | FreeLantz | 3G RAM - General Talk | 120 | 02-20-2006 01:09 AM |
| 2005 Ram Pickups Press Release | FreeLantz | Chrysler LLC Press Releases | 7 | 10-10-2005 12:48 AM |
| Dodge Introduces the Largest Pickup Cab Ever | RAM MAN | Chrysler LLC Press Releases | 39 | 06-29-2005 11:09 PM |
| 2004 and Select 2005 New Vehicle Pricing | RAM MAN | Chrysler LLC Press Releases | 1 | 01-14-2004 11:29 AM |
| Sponsored Links |
