Go Back   Dodge Talk Community Forum > Dodge Truck, SUV and Van Forums > Van and Cargo Truck Forums > B-Series Vans 1971 - 2003
mikezz29
  Question Trans Problem - Posted: 05-19-2006, 02:13 PM
Post #1
I have a '94 B150 cargo van with a 3.9 v6. While it seems to engage immediatly when shifted into forward and reverse, it barely moves when throttle is applied. There were no early warning signs, such as slipping, etc., but I did notice exessive white smoke out the exhaust just before this happened. Looking for any opinions on what the specific problem is likely to be before taking it to a shop. Thanks.
-Mike
Registered users do not see this ad or IntelliTXT ads. Please Register today! Its quick, easy and free!
jimdodgeram1500
 Posted: 05-19-2006, 04:10 PM
State: MA
Post #2
Check the cat to make sure it's not plugged up, that can make alot of people think the tranny is blown up. The motor will usually still rev up in neutral, but will have a total lack of power when in gear. You can check it by tapping it (when cold) with a rubber hammer and listening for stuff rattling around inside of it.
2000 ram 1500 sport
4X4 5.2L
33x12.50x15 BFG All Terrains
K&N FIPK genII
LOCK RIGHT
Custom Rear Bumper
Custom Front Bumper (TREE KILLER!)
Flowmaster 40 series - 45'd out before the rear wheel
Dodgevanman
 Posted: 05-19-2006, 10:23 PM
Dodgevanman's Avatar
Do It In A Van
City: Baltimore Hon!
State: MD
Post #3
White smoke generally means that coolant is leaking into the combustion chambers. It's possible that you may have a blown head gasket.
Nate the skate
5.2L Magnum
1972 B200 Royal Sportsman Maxiwagon
318/2bbl.
1985 B150
318/2bbl.
Click HERE to view the complete signature...
crazyinkc
 Posted: 05-20-2006, 06:43 PM
Post #4
Modulator? I had one go on a Pinto back in high school an it would barely move and I had to manually shift it into second. I had no third gear. Look for a vaccum line on the trans and unplug it. If it drips trans fluid, bingo.
kansasvanner
 Posted: 05-22-2006, 08:59 PM
Post #5
iam having the same with my 84 dodge b150 so there maybe 3 to 4 things wrong
the cat or coolant leakin or modulator thats alot of things too look for
Dodgevanman
 Posted: 05-23-2006, 07:06 AM
Do It In A Van
State: MD
Post #6
No vacuum modulator on Mopar transmissions.
Nate the skate
5.2L Magnum
318/2bbl.
1985 B150
318/2bbl.
93 Dakota Rebuilt Trans Problem gp376 Dakota 1st Gen (Pre-1997) Forum 3 03-22-2006 04:26 PM
trans problem jgoshow 1G Durango - Drivetrain Talk 7 03-07-2006 10:48 PM
Engine Codes P0336, P1693 ?? kg1216 Diesel Tech 12 04-21-2005 10:24 AM
Trans Problem and something else ddgcrvn Caravan Talk 0 08-22-2004 01:07 AM
Problem with the Trans sinastis 2G Dakota - Drivetrain Talk 2 07-13-2004 11:46 AM
