Trouble Codes for 96-97 Caravans - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 1 Old 05-18-2006, 10:54 PM Thread Starter
Jmw132001
Jmw132001's Avatar
Quoted: 2 Post(s)
Here is the trouble code list for 96-97 dodge caravans..
<LI>Code 11-Intermittent loss of either camshaft or crankshaft position sensors.
<LI>Code 11-Crankshaft position sensor target windows have too much variation.
<LI>Code 11-No crank reference signal detected during engine cranking.
<LI>Code 12-Direct battery input to PCM was disconnected within the last 50 Key-On cycles.
<LI>Code 13-No variation in MAP sensor signal is detected or no difference is recognized between the engine MAP reading and the stored barometric pressure reading from start-up.
<LI>Code 14-MAP sensor voltage too high or too low.
<LI>Code 15-No vehicle speed sensor signal detected during road load conditions.
<LI>Code 17-Closed loop temperature not reached-engine does not reach 50°F within 5 minutes with a vehicle speed signal.
<LI>Code 17-Engine is cold too long-engine coolant temperature remains below normal operating temperature during vehicle travel; possible thermostat problem.
<LI>Code 21-Oxygen sensor signal-neither rich or lean condition is detected from the oxygen sensor input.
<LI>Code 22-Engine Coolant Temperature (ECT) sensor voltage too HIGH/LOW-ECT sensor input above or below the acceptable voltage limits.
<LI>Code 23-Intake Air Temperature (IAT) sensor voltage HIGH/LOW-IAT sensor input above or below the acceptable voltage limits (2.4L engine only).
<LI>Code 24-Throttle Position Sensor voltage does not agree with the MAP sensor.
<LI>Code 24-TPS voltage above or below the acceptable voltage limits.
<LI>Code 25-Idle Air Control (IAC) motor circuits-short or open detected in 1 or more of the IAC control circuits.
<LI>Code 25-Target idle not reached-actual idle speed does not equal the target idle speed.
<LI>Code 27-Fuel injector control circuit-fuel injector output driver does not respond properly to the control signal.
<LI>Code 31-Evap purge solenoid circuit-an open or short detected in the duty cycle purge solenoid circuit.
<LI>Code 31-Evap purge flow monitor failure-Insufficient or excessive vapor flow detected during evaporative emission system operation.
<LI>Code 31-Evap leak monitor small leak detected-A small leak has been detected by the leak detection monitor.
<LI>Code 31-Evap leak monitor large leak detected-leak detection monitor is unable to pressurize EVAP system, indicating a large leak.
<LI>Code 31-Leak detection pump solenoid circuit-leak detection pump solenoid circuit fault (open or short).
<LI>Code 31-Leak detection pump switch or mechanical fault-leak detection pump switch does not respond to input.
<LI>Code 31-Evap leak monitor pinched hose found-plug or pinch found between purge solenoid and fuel tank.
<LI>Code 32-Exhaust Gas Recirculation (EGR) system failure-required change in air/fuel ratio not detected during diagnostic test.
<LI>Code 32-EGR solenoid circuit-open or short detected in the EGR transducer solenoid circuit.
<LI>Code 33-Open or short detected in the A/C clutch relay circuit.
<LI>Code 33-Air conditioner pressure sensor voltage too high-sensor input voltage is above 4.9 volts.
<LI>Code 33-Air conditioner pressure sensor voltage too low-sensor input voltage is below 0.098 volt.
<LI>Code 34-Speed control solenoid circuit-open or short detected in the speed control vacuum or vent solenoid circuits.
<LI>Code 35-Radiator fan control relay circuit-open or short detected in the low speed radiator fan relay control circuit.
<LI>Code 37-Torque converter clutch solenoid/Trans relay circuits-open or short detected in the torque converter part throttle unlock solenoid control circuit (2.4L engine w/31TH transmission and 3.0L engine only).
<LI>Code 37-Torque converter clutch (no RPM drop at lockup)-relationship between engine speed and vehicle speed indicates no torque converter clutch engagement (automatic transmission only).
<LI>Code 37-Park/Neutral switch stuck in PARK or in gear-incorrect input state detected for the P/N switch (automatic transmission only).
<LI>Code 41-Alternator field not switching properly-open or short detected in the alternator field control circuit.
<LI>Code 42-Autoshut-down (ASD) relay control circuit-open or short detected in the ASD relay circuit.
<LI>Code 42-No ASD relay output voltage at the PCM-open condition detected in the ASD relay output circuit.
<LI>Code 42-Fuel pump relay control circuit-open or short detected in the fuel pump relay control circuit.
<LI>Code 42-Fuel level sending unit voltage too low-open circuit between PCM and fuel gauge sending unit.
<LI>Code 42-Fuel level sending unit voltage too high-circuit shorted to voltage between PCM and fuel gauge sending unit.
<LI>Code 42-No movement of the fuel level sending unit detected over miles.
<LI>Code 43-Ignition coil #1, 2, or 3 primary circuits-peak primary circuit current not achieved within the maximum allowable dwell time.
<LI>Code 43-Engine cylinder misfire-engine cylinder misfire detected in one or more cylinders.
<LI>Code 44-Battery temperature sensor voltage too HIGH/LOW-battery temperature sensor input voltage above or below an acceptable range.
<LI>Code 45-EATX controller DTC present-an automatic transmission input DTC has been set in the transmission controller.
<LI>Code 45-Park/Neutral switch failure-incorrect input state detected for the park/neutral switch.
<LI>Code 46-Charging system voltage too high-battery voltage sense input above target charging voltage during engine operation.
<LI>Code 47-Charging system voltage too low-battery voltage sense input below target charging voltage during engine operation. Also, no significant change detected in battery voltage during active test of the alternator output circuit.
<LI>Code 51-Fuel system lean-a lean air/fuel mixture has been indicated by an abnormally rich correction factor.
<LI>Code 52-Fuel system rich-a rich air/fuel mixture has been indicated by an abnormally lean correction factor.
<LI>Code 53-Internal controller failure or PCM failure SPI communications-PCM internal fault condition detected.
<LI>Code 54-No cam signal at the PCM-No camshaft position sensor signal detected during engine cranking.
<LI>Code 55-Completion of fault code display on Check Engine lamp.
<LI>Code 61-Barometric pressure out of range (Key-On)-MAP sensor has a baro reading below an acceptable value.
<LI>Code 62-PCM failure SRI mileage not stored-unsuccessful attempt to update EMR mileage in the PCM EEPROM.
<LI>Code 63-PCM failure EEPROM write denied-unsuccessful attempt to write to an EEPROM location by the PCM.
<LI>Code 64-Catalytic converter efficiency failure-catalyst efficiency below required level.
<LI>Code 64-CNG system pressure too high-compressed natural gas pressure sensor reading above acceptable voltage (if equipped).
<LI>Code 65-Brake switch sense circuit-No release of brake switch seen after too many accelerations or no brake switch activation seen on several DECELS to RESET (OMPH).
<LI>Code 66-No CCD messages recieved from the Body Control Module (BCM) or the Transmission Control Module (TCM).
<LI>Code 71-5 Volt supply output too low-5 volt output from the regulator does not meet minimum requirement.
<LI>Code 72-Right rear (or just) catalyst efficiency failure-catalyst efficiency below required level.
<LI>Code 77-Speed control power relay; or speed control 12V driver circuit-malfunction detected with power feed to speed control servo solenoids.
Justin
Resigned July 19th 2011
COIN HOLDERS ASSOCIATION MEMBER # 88
Beta tester for online games.
1998 Dodge Ram 1500 qc sport 360 4x4
208,300 original miles (as of 9-25-10)
new transfer case, brakes, shocks, radiator, water pump(twice cause of faulty parts), front balls joints, trak bar, front u-joints, tires, heater core.
Jmw132001 is offline
    Trouble codes FireWalker 3G Dodge RAM Diesel Talk 0 04-19-2006 10:55 PM
    trouble codes Jmw132001 Vintage Dodge Car Forum 0 01-30-2006 03:02 AM
    Read YOUR Fender Tag: RAM MAN Mopar Muscle Talk 3 10-07-2005 11:03 AM
    Dodge Trouble Codes rickj Vintage Dodge Car Forum 2 09-27-2004 10:30 PM
