Thread Tools |
Post #1
I have codes P0205 and P0206 showing. I found they are for Injector circuit malfunction 5 and injector circuit malfunction 6. What actions should I take? I am assuming the numbers 5 and 6 refer to the cylinders. I will first try reseating the electrical connectors at the injectors, then at the ECU and unhook the battery for more than a minute and see if they clear. The truck seems to be running okay with the exception of an unstable and sometimes high idle (600-1000RPM, varying).
David W. Mitchell 2001 Quad Cab Sport Plus 4.7L, 5-Speed, 3.55 9.25"LSD, 11" Brakes, HD Cooling, HD Electrical, Towing & Convenience Packages. TRIAD Security, Rail N Rack, JVC Tunes |
| Sponsored Links | |
Advertisement |
Posted: 05-19-2006, 08:32 AM
Post #2
Changing the throttle position sensor fixed both the fluxuating idle and those dtc codes.
2000 Dodge Dakota Sport - Black 4.7 L w/ 3.92 gears and LSD 4x4 |
| Thread Tools | |
| 2003 Ram OBD Codes, is there a list? | IronHorse | 3G Dodge RAM - General Talk | 1 | 03-14-2006 05:56 PM |
| Retrieving OBD codes. Is the dealer lyin' to me | riverdale | 3G Dodge RAM - General Talk | 4 | 11-15-2005 08:39 PM |
| Read YOUR Fender Tag: | RAM MAN | Mopar Muscle Talk | 3 | 10-07-2005 10:03 AM |
| OBD II codes P0201-8 on my scanner | dgagne | 1G Dodge Durango - Drivetrain Talk | 2 | 08-25-2005 09:28 PM |
| OBD trouble codes | tigertom | 1G Dodge Durango - Drivetrain Talk | 8 | 12-18-2004 04:30 PM |
Privacy Statement | |
