rear end?
- Posted: 05-17-2006, 12:48 AM
Post #1
i am getting a strange noise coming from either the diveshaft or rear end. it sounds like clunking and ? . new u-joints about 4 months ago.
thanks!!! |
| Sponsored Links |
Posted: 05-17-2006, 06:59 AM
Post #2
Check them again just in case. It's possible that maybe one of the u-joint straps have come loose.
Nate the skate ![]() 1994 B250 Ram Van Conversion by Elk 5.2L Magnum 1972 B200 Royal Sportsman Maxiwagon 318/2bbl. 1985 B150 318/2bbl. Click HERE to view the complete signature... |
Posted: 05-18-2006, 05:18 PM
Post #3
also, the noise comes and goes
| Sponsored Links |
Posted: 05-18-2006, 08:32 PM
Post #4
Most likely the rear pinoin bearing. If you get slightly on the gas and then let off, does it have a sort of "moaning or whinning" sound? This is usually the pinion bearing. Check the drive shaft at both ends for any play. Is this a 2wd or 4wd?
If I could buy My truck as a Brand New unit today, I definately would! |
Posted: 05-18-2006, 11:01 PM
Post #5
my vehicle is a 1990 ram B350 2wd. how long till i have to fix this bearing?
thanks!! |
Posted: 05-19-2006, 07:09 AM
Post #6
Moving to the van section....
Do you have the 9.25" rear?
| Thread Tools | |
| Read YOUR Fender Tag: | RAM MAN | Mopar Muscle Talk | 3 | 10-07-2005 11:03 AM |
| Charger rear end housing? | '03 MOPAR R/T | Charger (06-Up) - General Talk | 15 | 07-08-2005 11:29 AM |
| Rear end CONFUSION | Jasonb61 | Dakota 1st Gen (Pre-1997) Forum | 16 | 06-04-2005 04:59 AM |
| Need Help On Rear End Axle ?'s | charger_2fast4u | Mopar Muscle Talk | 6 | 05-29-2005 09:19 PM |
| Rear end Durango drop | Phlexit | 1G Durango General Talk | 1 | 03-08-2004 06:47 AM |
| Sponsored Links |
