Tire pressure
- Posted: 05-10-2006, 01:23 AM
Post #1
I could use some help, since my van doesn`t have it`s sticker.
What`s the recommended pressure for a 1990 5.2L B250 conversion? Thanx, ![]() |
| Sponsored Links |
Posted: 05-10-2006, 06:47 AM
Post #2
I generally run 35psi in all of my tires. Don't go by what is molded on the tire sidewall...that is the maximum tire pressure and not recommended for everyday driving.
Nate the skate ![]() 1994 B250 Ram Van Conversion by Elk 5.2L Magnum 1972 B200 Royal Sportsman Maxiwagon 318/2bbl. 1985 B150 318/2bbl. Click HERE to view the complete signature... |
Posted: 05-10-2006, 10:09 AM
Post #3
Yeah, my tires have a max. pressure of 44 psi, I didn`t think that was right.
35 sounds good. ![]() |
Tire pressure
- Posted: 05-10-2006, 11:34 AM
Post #4
My tires have a max of 35 on the tires and on the van's sticker. I am running at 35 in all 4 tires and the ride is very bumpy. I am thinking about lowering the pressure by a couple of pounds. My next set of tires will be light truck or cargo. A lot of people have higher pressure in the rear wheels. Does anyone have an opinion about this?
thks. ![]()
_____________________________________________ 1999 Dodge Ram Van Imperial Conversion 5.9L with a/c
Posted: 05-10-2006, 11:14 PM
Post #5
I have seen the sticker say higher pressures in the rear.
BTW, Welcome to Dodgetalk!
Posted: 05-13-2006, 12:43 PM
Post #6
Mine says 51psi for both front and rear on my 2001 B2500. These are LT tires. It also says while towing inflate to 80psi! I've check the tire psi requirements on the RV forums too, and many people run as high as 65psi for towing with this psi for our vans.
Setting the psi around 35 seems too low. The mileage could suffer some. On our B1500, it uses a HD XL passenger tire. It mimicks much of an LT tire and it's rating is at 45psi. There are very few tires out there for the B1500 for the proper loading and size. I had to shop around many places to find it. Hope this helps. Stev
2000 Dodge-Ram-B1500 V6 3.9L, 3.55:1, RoadMaster MKII-XF -SOLD- 2001 Dodge-Ram-B2500 V8 5.2L, 3.92:1, RoadMaster MKII-XXF 1982 Coachmen Cadet 19-1/2 3000# Towable Camper *DodgeTalk.com 318 Enthusiast Member #(50)* *DodgeTalk.com Ram Van/Wagon Member #(1)* |
Posted: 01-01-2007, 07:16 PM
Post #7
1999 127"WB 5.2L #35 front, #41 rear according to factory sticker
| Sponsored Links |
| Thread Tools | |
| tire pressure monitor system ? | jpercival | Charger (06-Up) - General Talk | 3 | 08-12-2005 02:35 AM |
| Warning if you have a flat tire | MrMike | Magnum - General Talk | 11 | 07-16-2005 08:34 PM |
| Tire Pressure | skoshi | 3G RAM - Interior/Exterior Talk | 5 | 09-09-2004 02:17 PM |
| Tire pressure. | kev94mx | 3G RAM - Tire and Wheel Talk | 3 | 03-17-2004 01:18 PM |
| Quotes from experts on tire pressure | HankL | 2G RAM - General Talk | 1 | 05-12-2002 05:02 PM |
| Sponsored Links |
