Front brake caliper removal - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums
post #1 of 9 Old 05-09-2006, 06:56 PM Thread Starter
PickupGirl
PickupGirl's Avatar
I am attempting to change my front brake pads on my pick-up which should be a "no brainer" but I can't seem to get the caliper off of the disk. It appears that I need to remove one or both of the 12-point bolts to do this, but I can't be them loose. I broke a socket wrench attempting to do so (yes I know I should have been using a breaker bar or impact wrench instead).
Are these bolts left-hand thread or just really tight or both? The last thing I want to do is break one off and then have to figure out how to remove it.
Thanks!!!!
2001 Dodge RAM 2500 4x4 Diesel H.O.
1989 Ford F-250 4x4 460
PickupGirl is offline
post #2 of 9 Old 05-09-2006, 07:02 PM
Jmw132001
Jmw132001's Avatar
Quoted: 2 Post(s)
they are just regular type but are probably on there very time. get a breaker bar and try to get them off. good luck
Justin
Resigned July 19th 2011
COIN HOLDERS ASSOCIATION MEMBER # 88
Beta tester for online games.
1998 Dodge Ram 1500 qc sport 360 4x4
208,300 original miles (as of 9-25-10)
new transfer case, brakes, shocks, radiator, water pump(twice cause of faulty parts), front balls joints, trak bar, front u-joints, tires, heater core.
Jmw132001 is offline
post #3 of 9 Old 05-09-2006, 07:04 PM
mocho
mocho's Avatar
I just did my brakes about a week ago, and I got them loose with a ratchet, it was a pretty big one however. There should be 2 big bolts 3/4 I think it was and 2 little ones.
2010 Ram 1500 QC SLT 4x4 Hemi
Gone but not forgotten.
2004.5 3500 4x4 CTD
With plenty of mods.....
mocho is offline
post #4 of 9 Old 05-09-2006, 07:17 PM Thread Starter
PickupGirl
PickupGirl's Avatar
Thanks for the info. I can't find my breaker bar so I guess I will go buy another one. I got the two torx bolts out, but it if the 12 point 5/8" bolts that are causing me the problem.
post #5 of 9 Old 05-09-2006, 09:30 PM
dwhuber
PB Blaster is your best friend....
Dave Huber
2001 Dodge Ram 1500 QC 4X4 SLT+
dwhuber is offline
post #6 of 9 Old 05-09-2006, 09:43 PM
bobem12
4x4, Straight pipe roar!
bobem12's Avatar
yep I used pb when I changed my rear shocks on sunday. WD40 was like pouring water on the bolts, didn't do a darn thing. PB got them loose, well that and a breaker bar but PB definitley helped!
'01.5 Dodge Ram 2500 CTD 4x4
QC Long Bed Auto 4.10 gears and GREEN!
Rebuilt trans, Edge EZ, 5" stacks, BHAF, no silencer ring, mechanical fp gauge, autometer pyro, boost, trans temp, Holley Blue lift pump, 2" leveling kit w/ 285 BFGs, Cobra CB, and a toolbox with a bunch of lights on it!
Gone but not forgotten>>>1998 Dodge Ram 1500 4X4 Laramie SLT Quad Cab 5.9l v8
bobem12 is offline
post #7 of 9 Old 05-10-2006, 09:24 AM
Davcruz
I disgaree...:)
Davcruz's Avatar
Whoa, stop where you are. The 5/8ths 12 points are for the hub, NOT for the caliper. There are 2 3/4 6 point bolts for the entire caliper, but you can remove just the pad retainer portion of the caliper by takling the slide bolts only, really simplifies things.
David
2001.5 - 2500 HD CTD 4x4 Sport SLT Quad Cab
Fabtech 5.5 Long Arm Performance lift
Toyo Open Country M/T 315/75-16's
AFE Stage II Intake
BD XMonitor pyro, trans, boost digital pillar gauge
Westach fuel pressure gauge
Edge Comp w/wire tap
Magnaflow 4" Exhaust
Airdog FP100 and big line kit
Davcruz is offline
post #8 of 9 Old 05-10-2006, 10:59 PM Thread Starter
PickupGirl
PickupGirl's Avatar
I see the bolts you are referring to and they are 12-points bolts, but the bolts that hold the calipers are also 12-point.
Unfortunately because I was short on time and HAD to have my truck functional for tomorrow I ended up taking it in to have the brakes done. (They managed to remove those bolts somehow). I am just still in shock that I ended up having to have something so simple done at a shop.
post #9 of 9 Old 05-11-2006, 11:36 AM
Davcruz
I disgaree...:)
Davcruz's Avatar
Oops, just noticed you have a 2500. I was telling you how to do a 1500. I suppose I should read a bit more bofore I open my big mouth....
Hopefully the shop didn't really nail you on the price though.
David
AFE Stage II Intake
Davcruz is offline
    front brake pulsation every 7k miles srt 4 re147 3G Dodge RAM - General Talk 7 02-26-2006 10:12 AM
    Got one! SRT8 qzking Dodge Magnum SRT-8 Talk 40 09-11-2005 03:33 AM
    Front / Rear Brake Distribution sctboat 1G Dodge Durango - Tire/Wheel/Susp Talk 10 12-09-2004 09:23 PM
    front left brake dragging brianwarner983 Dodge Caravan General Talk 1 03-28-2004 07:43 PM
    Brake Pads DurangoDude 1G Dodge Durango General Talk 0 05-08-2002 02:00 PM
